Question about Black & Decker SpaceMaker ODC325 Coffee Maker
Black & Decker SpaceMaker leaks badly.
We are on our third Black & Decker SpaceMaker. Each one has started leaking after about a year of service. I don't think we will get another one. We like the style, the coffee is good, and does not taste like plastic as it does with some coffee pots. But the leaking is a mess - all over the counter, running on the floor, not only very annoying, but probably hadazdous. Three times this has happened. We kept the receipt, called when it started leaking. They had us to cut off the cord and mail in in - which we did and they sent us another one. When that one started leaking after about a year, I bought another one - over my husbands objections. He was right. After 20 months of good service, it has developed a leak and pours all over the counter. You cannot get into the cabinet to find the problem. Weird screws that nobody has a tool to match. I am taking a hammer it to it this time.
It has nothing to do with the spring or its tension. I have had 3 of these coffee makers now. Each on has started leaking water from the reservoir after some amount of time. If you carefully look at where the rubber washer/spring thing is, right above the hole where it goes in, you will see a small "crack" in the plastic that develops after repeated use of this coffee maker. That's where the water is coming from. Each one of the reservoirs I have had has developed this crack in the plastic right there. It is a design flaw. I will never buy one of these again.
Posted on Jun 21, 2010
  • Peter Bresler
    Peter Bresler Nov 12, 2014
    The spring on the valve on the water reservoir was completely broken after about 3 years use. Replacing the spring solved the problem. You need to remove the rubber washer at the end of the plunger, remove the plunger and find a new spring that fits.
I have not solved the leak as of yet but I suspect it has to do with the rubber washer/spring assembly at the bottom of the water reservoir. If it does not create a perfect seal, not only will the water leak, eventually, the water will not cycle thru the pot - where I am at now. As for getting the cabinet open, you need a number T15 Tamper Proof Torx bit. You can buy it for about $4 at NAPA auto parts. Ask for Ultrapro 67615.
Posted on Sep 15, 2009
  • Steve May 09, 2014
    So that's what the proper 'temper proof" torx bit is. To save yourself the driive down to NAPA and $4 just put an electric drillng into the the bottom of the torx screw hole's center and drill/reem out the tiny protruding metal bump, the an ordinary T15 bit will take out the screw just fine.
  • deakinsd Apr 05, 2017
    Or place a nail/center punch on an angle over the metal post and tap it with a hammer. It will break off and can be removed.
    New Friend:
  • 47 Answers
The screws on mine are torx, size T15.Try that.
Posted on Sep 04, 2009
  • 30 Answers
This sounds like the infamous coffee basket spring issue. You don't say what model spacemaker you have but most of the recent models have had this problem. Watch the basket when you insert the carafe and see if it moves towards you. If it does then this solution applies to your problem.
The spring tension on the lever that places the gasket against the bottom of the basket to enable the sneak a cup feature is too strong. When you push the carafe in, sometimes it will move the basket outward, closing off the outlet hole on the bottom of the basket. The water and coffee then have no place to go but over the top of the basket and all over your kitchen rather than into the carafe.
Try removing and stretching the spring on the lever somewhat to weaken it's tension. If that doesn't solve the problem take the spring to ACE Hardware and see if they have a spring with the same diameter but made with thinner metal. It doesn't take much force to keep the lever open so a light tension on the spring will do just fine.
Posted on Feb 07, 2010
I have a spacemaker that leeks at resover
Used/Cannibaliized Replacement parts for ODC 325 B&D Spacemaker Coffee Makers are regularly sold on eBay, including the entire water reservoir or even the water valve in bottom of the reservoir (the leaky old one can be pushed out from the inside of the reservoir, and a non-leaking used replacement valve can be pressed in in its place).I sometimes buy an old broken ODC 325 cheaply on eBay as a source of parts.
Dec 30, 2013 | Black & Decker SpaceMaker ODC325 Coffee...
My toaster oven TROS1500 Black and Decker Spacemaker, the top heating element is not working. Can I buy a replacement part for this? I have looked everywhere on the internet and can not find anything.
Contact Black and Decker customer service and ask them for replacement parts department. Depending on how old the oven is; some parts are not available after 5 years.
May 11, 2011 | Black & Decker TRO910W Toaster Oven with...
Order parts for 172165
Hello. If you are hoping to repair this and can see the crack that is causing the leak you can repair it with a marine grade epoxy. This can be found at Home Depot and most hardware stores. J.
Jul 10, 2010 | Black & Decker SpaceMaker ODC150 Coffee...
Leaking black and decker under counter coffee pot
the 90 degree red elbow has worn away of hot water temps and will leak some but all hot water to the bottom of machine. needs to be replaced or retrofit one
Jan 03, 2010 | Black & Decker SpaceMaker ODC440B 12-Cup...
Water resevoir leaking
Replacement ODC 325 water reservoirs no longer for sale.
I keep a second ODC 325 machine for canibalization. The black rubber water valve assambly can be repaired (I did it 2 weeks ago) but it takes some creativity.
Nov 10, 2008 | Black & Decker SpaceMaker ODC325 Coffee...
Black&decker smartboil leaks
I work for Black and Decker customer support. Our customer service phone number is 1-800-231-9786.
If the unit is leaking, it needs to be replaced. Unfortunately, the unit can't be repaired. The unit comes with a one year warranty from the date of purchase. Please call the number above so that we can determine your warranty eligibility.
While this doesn't actually solve your problem, I hope the information allows you to make an informed decision as to how to proceed from here. Please let me know if I can be of further assistance.
Dec 09, 2007 | Black & Decker JKC450 Cordless Electric...
Black & Decker SpaceMaker ODC325 Coffee Maker Logo
1,065 people viewed this question
Top Black & Decker Coffee Makers & Espresso Machines Experts
eyecam
Henry  Thomas
Henry Thomas
Are you a Black & Decker Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
