Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Hooked up water line but does not work
The green light does not turn on when we hooked up water line. Is there a reset button?
  • 3 Answers
Yes.. hold down the water filter button for 5 seconds it will reset for 6 months
Posted on Feb 27, 2009
Have changed water filter, but indicatot panel calls for order h2o filter, and comes on every time we dispence water. why?
Most models also have a filter indicator reset button located in the same area. After changing the filter, reset the filter status light by pressing the Filter Indicator Reset button or by pressing and holding the Filter button for 3 seconds. The status light will change from red to green or the status display will change from "Replace" to "Good" when the system is reset.
If your model has a water filter indicator, but no reset button, press the light switch in the refrigerator compartment 5 times within 10 seconds to reset the system. The status light will change from red to green when the system is reset.
Oct 16, 2012 | KitchenAid KBFA25ER Bottom Freezer French...
I am replacing the water filter how do I reset on the outside door
The Water Filter Status Indicator Light serves as a
reminder to replace the water filter. A green light
indicates that the filter is in good condition. A red light
indicates the filter should be changed. Once light turns
red, it will remain red until function is reset.
To Reset Indicator:
• Press and hold both the Lock and Water
buttons simultaneously for four seconds. The
green filter status indicator light will flash
three times when the function has
successfully reset.
Thanks, Sea Breeze
May 17, 2010 | Jenn-Air JCD2295HES Side by Side...
Trying to reset filer light after changing filter-locked up
Here is a link to the manual for your unit. Copy paste into your browser.
http://shop.amana.com/assets/pdfs/literature/12591321.PDF
Page 20 shows how to unlock the dispenser and reset the filter light and I have pasted them here.
There are products at Lowes or Home Depot near the appliance for odor removal, I like to put a bowl of cotton balls on a couple of shelves, soak the cotton in vanilla once a day. The odors will be gone in a couple of days.
DISPENSER LOCK
(SELECT MODELS)
This feature prevents ice or water from
being dispensed.
To lock dispenser:
➢ Press and hold DISPENSER LOCK
button for 3 seconds. A green
indicator light above button confirms
dispenser is locked.
To unlock dispenser:
➢ Hold DISPENSER LOCK button for 3
seconds. Green indicator light above
button will go out.
Filter reset
The filter status indicator light
serves as a reminder to replace the
water filter. A green light indicates that
Once light turns red, it will remain red
To reset indicator:
➢ Press and hold both DISPENSER
LOCK and WATER buttons
simultaneously for 4 seconds. The
flash 3 times when the function has
successfully reset.
Apr 18, 2010 | Amana ARS266ZBS Side by Side Refrigerator
Red light stays on after changing the water filter and running about 2 gallons through it
Light (select models)
To Reset Indicator:
successfully reset.
Nov 27, 2009 | Maytag MZD2665HE Side by Side Refrigerator
Change filter light
To Reset Indicator:
successfully reset.
Sea Breeze
Nov 25, 2009 | Maytag MSD2650H Side by Side Refrigerator
Water is not filling ice cube maker
Is the freezer cold enough? Should be close to 10 degrees.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Once the ice mold has water in it, it may start cycling when it freezes.
If the fill tube is blocked with ice, the water inlet valve is leaking and needs to be replaced.
Aug 21, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Changing light after installing new water filter
(select models)
To Reset Indicator:
• Press and hold both the LOCK and WATER
successfully reset.
Aug 12, 2009 | Jenn-Air 21.6 cu. ft. Side-By-Side...
Changed water filter red light stays on
Afer you change the filter and have run the water for about 1 minute you then hold down the light & lock button together and this should turn the change filter light off.
Apr 23, 2009 | Refrigerators
Water Filter Red Light
Press and hold "ICE MAKER LOCK" button, and while holding it shortly press "LOCK" button, and the light will change to green LED.
Jan 12, 2009 | Jenn-Air JCD2290HES Side by Side...
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
64 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
