Question about HP PAVILLION DV6841TX PC Desktop
Failure to load windows?
My computer will turn on, but windows won't load at all. it keeps trying to restart. we run windows XP. it tries to load, but shuts off and reboots.
how do i fix this?
  • rebecca_may2 Feb 26, 2009
    how can i contact you to write you back? it's not my computer, by the way, it's my aunts, actually. but she used my account. if you want, email me with a walkthrough at thanks so much.
    thanks so much.
  • 2,653 Answers
Turn on the computer.
Press F8 every few seconds.
You should get a screen with a ton of choices.
Choose Safe Mode with Command Prompt.
Write me back when you're this far.
Posted on Feb 26, 2009
  • RescueTechLA
    RescueTechLA Feb 26, 2009
    I'll do that. Thanks for the rating!
  • RescueTechLA
    RescueTechLA Feb 27, 2009
    After getting into Safe Mode with Command prompt it will ask for your Administrator Password.
    Just press enter. (hopefully you didn't set one)
    then type:
    chkdsk /r
    press enter
    A message will pop that says your drive is locked, blah, blah, blah.
    Just press the Y key, then enter.
    Press control+alt+del
    Check through the different tabs at top, one of them will give you the option to shutdown the computer.
    Power the computer back on and start Windows normally, you should see a box that says something about "Disk Checking".
    Don't touch the computer, just let it do it's thing.
    Hopefully that's all we'll have to do to get you back on track.
    Let me know if you get stuck.
Hi all , My HP laptop auto shuts down when i open microsoft words , why is this so ? can somebody pls help me ? I need todo some work on it urgently!! , Thanks !!
You will need to press the F8 key before windows starts to load then disable
the auto restart on error. That will allow you to read the error message and
someone may be able to guide you.
You could also try booting from the XP CD and run the recovery console (if
that's an option) once in the recovery console type chkdsk /r to correct any
errors & try booting again.
Disable automatic restart on system failure. This should help by
allowing time to write down the STOP code properly. Right click on
the My Computer icon on the Desktop and select Properties, Advanced,
Start-Up and Recovery, System Failure and uncheck box before
Automatically Restart.
Do not re-enable automatic restart on system failure until you have
resolved the problem. Check for variants of the Stop Error message.
An alternative is to keep pressing the F8 key during Start-Up and select
option - Disable automatic restart on system failure.
If you are using a wireless keyboard and the F8 key does not work
substitute a wired keyboard and mouse for this exercise only.
Please prost your feedback.
May 19, 2010 | Computers & Internet
My dell inspiron 1525 has a black screen with a white cursor showing
First, I want to know if you sees the Dell logo after turning on the laptop? If yes then this is no boot issue.
1. Immediately run the PSA. Make sure laptop is off. Press and hold down the Fn key, while holding down Fn key press the power button at the same time just once. Once the Dell screen loaded you can now let go of the Fn key. Check if the PSA will run short test for the LCD, RAM and HDD. When full color displays on the screen just press Y. PSA will continue. Just take note of any error code will appear on the screen such as 0141, 0142 and 0146 these are HDD failure errors which means HDD needs replacement. If the test says no errors found then proceed to step 2;
2. Try restarting the laptop once you see dell logo then keep tapping F8. Select last known good configuration. Press enter key. Just wait and check if laptop will load Windows. If not then, restart laptop keep tapping F8 try to select safe mode check if it will load Windows. If not then prepare the Windows OS disc the one came with your laptop.
3. While laptop is on insert the Windows OS disc. Restart the computer. On the Dell screen keep tapping on F12 to show boot menu. In the boot menu select CD/DVD ROM Drive. Press enter then keep tapping on space bar until it will say Windows loading files, please wait.
4. In the User Interface it will show you some options to select. Once the Install screen comes up look on the lower part select Repair Your Computer. If will ask you to do Startup Repair, please do start up repair. If fails try the System Restore. If fails then step 5;
5. If you have important files in your HDD then back up your files first. After backing up of files you can now install the Windows OS. Here is the process in installing the Windows OS. Insert the Windows OS disc, restart the laptop, keep tapping F12 on Dell screen, on boot menu select CD/DVD ROM Drive.Install the Windows OS. Just complete the installation.After the installation install the laptop drivers.
Dec 10, 2009 | Dell Inspiron 1525 Notebook
Boot failure self HDD test #1-7 XP PRO.
Hi this Alex You can use Ntfs for dos programm which allow you to access ntfs partions on while dos loaded. then you will be able to get you data copied
Sep 23, 2009 | HP Pavilion dv4000 Notebook
Everytime ,I try to turn on my computer this keep popping up.c:/P
Windows XP
Start > Run > msconfig > Click on 'Startup' Tab > Untick the option that loads up MyWebSearch > Apply > OK > Restart
Windows Vista
Start > All Programs > Accesories > Run > 'msconfig' > Click on the 'Startup' Tab > Untick the option that loads up MyWebSearch > Apply > OK > Restart
Aug 06, 2009 | Intel Motherboard
Laptop restarts over and over
Is it Win XP or Vista? hit F8 and see if you can get into Safe Mode, if you can goto start , run and type msconfig, disable all and reboot.
If you cant get into to safe mode, hit F8 when computer turns on and scroll to Last Known Good Configuration. see if lets you in.
If you are running Win XP and none of that works. You will have to run your XP CD and do an OS repair, just load the XP CD at boot when setup starts hit ( Enter F8 then R) let it do its thing. Hope this helps Good Luck.
Jul 24, 2009 | Computers & Internet
Windows won't load
Try booting to "Safe Mode" (tapping the "F8" key on boot), or however you can get to your Desktop, click start, right click "My Computer", select "Properties", then "Advanced" tab, then click the "Settings" button under "Startup and Recovery", then uncheck "Automatically restart" under "System Failure", click "OK" then "OK" again and restart your PC.
That should allow you to run without the instant restarting on BSOD, so you can repair/remove Mcafee.
Feb 18, 2009 | Acer Aspire One Netbook 8.9" Notebook
Cannot start up
Do you have a copy of your OS disk:
Try This:
insert your Windows XP Setup CD, and restart your computer. 1.
When the Press any key to boot from CD message is displayed on your screen, press a key to start your computer from the Windows XP CD.
Press ENTER when you see the message To setup Windows XP now, and then press ENTER displayed on the Welcome to Setup screen.
Do not choose the option to press R to use the Recovery Console.
In the Windows XP Licensing Agreement, press F8 to agree to the license agreement.
Make sure that your current installation of Windows XP is selected in the box, and then press R to repair Windows XP.
Follow the instructions on the screen to complete Setup.
Feb 16, 2009 | Toshiba Satellite A35-S159 Notebook
My computer won't shut down it just keeps restarting
The most common shut down problem is that the system will reboot rather than shutting down. In most cases, the reboot is triggered because Windows XP is designed to reboot after a critical failure. To stop windows from rebooting in case of a failure, you need to take the following steps:
Right click on My Computer, Select Properties, Click on advance tab, Click on Settings under Startup and Recovery, Uncheck the option Automatically Restart under System failure, Click Ok twice and try to shutdown the pc. If it shows any error code then let me know
Nov 24, 2008 | Toshiba Satellite M65-S809 Notebook
Shuts off at boot up screen?
Start the computer in safe mode (tap F8 immediately after turning it on until you see the option of how to boot)
If it successfully boots into windows, you have an issue with either driver conflicts and/or viruses. If it still restarts itself, you most likely have a hardware issue (bad hard drive, motherboard, etc)
Jun 24, 2008 | Acer Aspire 5000 Notebook
Computer won't load Windows
1. What the motherboard you had been using
2. Whats the HDD
Check that your motherboard supports the higher HDD
Upto 80GB HDD Windows can load the XP with servicepack 1
But after 80GB HDD supports the WIN XP with service pack 2 CD only.  Try to install with the winxp having above sp1.
Let me know if your problem is solved and rate me as FIXYA!
May 16, 2008 | Computers & Internet
HP PAVILLION DV6841TX  PC Desktop Logo
128 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
