Question about Xerox 5665 Copier
Copy stops halfway through 1st page
My Xereox XC1045 copier will only print half a page. If i turn the power off, it may print one full page, but then will show a jam and only print one half of a page and stop. I am wondering if it is a gear problem and if so, where can i get the gear and how hard is it to install? Thanks for your help.
    President:
  • 2,072 Answers
Yeah more than likely that gear has broken.
What I would suggest it google a business called " the parts drop".
Call and ask for Britt, he has the part. I believe it to be less than $20, and if he doesn't have instructions, let me know, I can tell you how to replace that. Its really easy. If you open the machine and look in back, just before the fuser, " the HOT area, You will most likely see the gear broken into 3 or 4 pieces. While your at it. inspect the condition of the rollers in the fuser, if any of them show wear replace them at the same time. There should be a cleaner roller, white, most likely black by now that would be a good idea to replace with the gear if the pink and aluminum roll are in good shape, that will extend the life of the more expensive heat and pressure rollers. Like I said if Britt doesn't have the instrutions, let me know. I will type them out for you.
Posted on Feb 28, 2009
Canon ir2520 copy only half page
it is normal, just mixing, continue printing, it will slowly cover the page till the entire page is printed or copied, dont worry, just reuse the half printed paper till when the pages print complete.
May 27, 2012 | Office Equipment & Supplies
In Print Preview my booklet looks like it will print correctly. When I print my book the 1st page of the 2nd half of the book prints on top of the last page of the 1st half of the book. I have tried...
rint Preview my booklet looks... Solve In Print Preview my booklet looks like it will print correctly. When I print my book the 1st page of the 2nd half of the book prints on top of the last page of the 1st half of the book. I have tried
Sep 11, 2009 | Microsoft Office Professional 2007 Full...
Print half of full page
If the printer starts to print and stop in the middle check the eletricity of your place, this may have a variation. If the printer prints a half page and give you the paper, with no jam, check the cartridges and then the main board.
Aug 13, 2009 | Lexmark X5470 All-In-One InkJet Printer
Sharp Al 1631 prints half a page
Sometimes the originals hesitate using the document feeder, which can cause the problem you are describing. Do you get the same rsults if you lay the original on the glass?
Apr 29, 2009 | Sharp AL 1631 Copier
Page prints half page then jams
I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed throught the printer. The reason for this, in some cases I have been able to clear the paper track of debris that was deposited there over time. Worth a try. I have fixed a number of printers this way saving costly repairs. Bud
Dec 04, 2008 | Office Equipment & Supplies
Xerox xc1045 copier machine
If it starts to make a copy and the light comes on then stops in the middle there is a problem w/the connection.
check the cable that turns on the light it may have a cut and is not making contact in a particular spot. If not then it may be the board that controls the lamp.
Oct 17, 2008 | Xerox 5665 Copier
Multiple page printing
if it's one original making 20 copies and doing the problem then you have a problem with the
a) Primary
b) Seperation unit
I would change the Sep 1st
Sep 08, 2008 | Canon PC-940 Black and White Copier
100 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
