Question about Intel D945GNT Motherboard
Computer wont start!! beeps THREE times and doesnt load anything
The other day I did a very foolish thing by changing my BIOS settings for my RAM from normal to aggressive. Now, my computer will turn on, beep THREE times, and wont load the screen anymore.
I have an Intel D945 desktop motherboard.
Any suggestions??
    President:
  • 2,653 Answers
Don't worry, it's easy to get back in.
Posted on Feb 26, 2009
  • RescueTechLA
    RescueTechLA Feb 26, 2009
    Just open the case and remove the cmos battery for a minute or two.
    That will reset the bios back to default. Then you can get back in.
  • RescueTechLA
    If that doesn't work, try unplugging the power from the system then remove the battery and let the computer sit for a minute or two then re-insert.
    Make sure you ground yourself by touching the side of the metal case with one hand so that you don't shock your motherboard.
    Let me know what happens.
When i switch on my compaq presario V2000 laptop it beeps three times and then freezes giving me the option to press f1 or f10 but when i press f1 or f10 it still doesn't work and is still frozen
Hi....
Actually beep sound indicates hardware error or BIOS error.
Don't press F10 while starting.
Let your laptop to start wait for 10min....
If it will not starts..........
Press F1(BIOS Settings for some pc F2 is Bois Setting)
If it will load BIOS.......... then your BIOS is OK
Then you need to change hard disk...
If not you need to change BIOS hardware(IF you i will tell you the way restore BIOS but it's very difficult task.It needs a trained person.)
Thank you have a nice day............
Feb 06, 2011 | HP Compaq Presario V2000 Notebook
I get beeping when I start the computer, and it wont start?
This is called a beep code. It is used for troubleshooting when you are unable to boot your computer. Here is a listing of the Dell beep codes, depending on the sequence of beeps that you are hearing, you will find the problem listed here. How many beeps are you getting and what model of Dell do you have?
1-1-2 Processor Register Failure 1-1-3 NVRam 1-1-4 ROM Bios checksum failure 1-2-1 Programmable Interval Timer 1-2-2 DMA Initialization Failure 1-2-3 Direct Memory Access Page Register Read/Write Failure 1-3-1 - 2-4-4 Memory/RAM Not Properly Identified or Used 3-1-1 Slave DMA Registration Failure 3-1-2 Master DMA Registration Failure 3-1-3 Master Interrupt Mask Registration Failure 3-1-4 Slave Interrupt Mask Registration Failure 3-2-2 Interrupted Vector Loading Failure 3-2-4 Keyboard Controller (Input) Test Failure 3-3-1 NVRam Insufficient Power 3-3-2 Improperly configured NVRam 3-3-4 Video Memory(RAM) Test Failure 3-4-1 Screen Output Initialization Failure 3-4-2 Screen Retrace Failure 3-4-3 Failure Finding Video Read Only Memory 4-2-1 Lack of Time Tick 4-2-2 Shutdown Failure 4-2-3 Failure in Gate A20 4-2-4 Unexpected Interruption in Protect Mode 4-3-1 Memory Address Failure above 0FFFFH 4-3-4 Non Functioning Time Of Day Clock 4-4-1 Serial And/Or Parallel Port Test Failure 4-4-4 Cache Test Failure
http://www.bioscentral.com/postcodes/dellbios.htm 1-1-2 Processor Register Failure 1-1-3 NVRam 1-1-4 ROM Bios checksum failure 1-2-1 Programmable Interval Timer 1-2-2 DMA Initialization Failure 1-2-3 Direct Memory Access Page Register Read/Write Failure 1-3-1 - 2-4-4 Memory/RAM Not Properly Identified or Used 3-1-1 Slave DMA Registration Failure 3-1-2 Master DMA Registration Failure 3-1-3 Master Interrupt Mask Registration Failure 3-1-4 Slave Interrupt Mask Registration Failure 3-2-2 Interrupted Vector Loading Failure 3-2-4 Keyboard Controller (Input) Test Failure 3-3-1 NVRam Insufficient Power 3-3-2 Improperly configured NVRam 3-3-4 Video Memory(RAM) Test Failure 3-4-1 Screen Output Initialization Failure 3-4-2 Screen Retrace Failure 3-4-3 Failure Finding Video Read Only Memory 4-2-1 Lack of Time Tick 4-2-2 Shutdown Failure 4-2-3 Failure in Gate A20 4-2-4 Unexpected Interruption in Protect Mode 4-3-1 Memory Address Failure above 0FFFFH 4-3-4 Non Functioning Time Of Day Clock 4-4-1 Serial And/Or Parallel Port Test Failure 4-4-4 Cache Test Failure
Oct 18, 2010 | Dell Dimension 3000 PC Desktop
Computer Wont respond after the RAM was switched. 6 beeps.
Hello
The beep code you are getting is faulty ram. There really is not anything you can do to fix this yourself. Sorry
Best regards
Andrea
Nov 05, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Acer travelmate 290 beeping, starts with blue screen and then black and beeping
See if there is an error beep. If there is an erro beep, then change
main board.
Power off. Then check if RAM CPU BIOS are well-connected.
Press Fn+F5 three times slowly
LCD FPC
LCD inverter
LCD
USB does not work correctly USB device cable is firmly connected into the USB ports. Test
Oct 29, 2009 | Acer TravelMate 290 Notebook
At start up, before windows loads, a consistent series of annoying beeping occurs....
If they're occurring right as you turn the computer on, it's your Power On Self Test (aka POST) letting you know. Since I can't be more specific, here's a synopsis of POST beeps:
One single beep followed by three, four, or five beeps -- System-board problems, possibly with DMA, CMOS setup chip, timer, or system bus. The computer usually won't boot when this is the problem.
Two beeps -- The POST numeric code is displayed on the monitor, usually nothing to be concerned about, but you might google the code on another computer and see what you get.
Two beeps followed be three, four, or five beeps -- First 64K of RAM has errors. Solution is to replace RAM.
Three beeps followed by three, four, or five beeps -- Keyboard controller failed or video controller failed. Either you won't be able to see or type with this error.
Four beeps followed by three, four, or five beeps -- Problem with serial or parallel ports, system timer, or time of day. Check your BIOS settings (usually F2 at start up) to make sure everything is correct.
Continuous beeps - problem with power supply. Probably won't do much with this error. At the very best, your computer will boot and run very, very slowly.
Hope that helped.
Sep 01, 2009 | Compaq Computers & Internet
Beep..beep..beep..(Three times)
check the new memory in all memory slot that u have. use thinner with a art paint brush just past it in the memory slots, just like cleaning them up. then place the memory about some seconds. switch it on. if doesnt work see your graphic card. or try a kingston memory. kingston memory works on almost all motherboard. some others even new, they dont work on some motherboard.
Aug 10, 2009 | Computers & Internet
F***ked up my BIOS settings for my RAM settings!! I NEED HELP
i think you may have burnt out your memory. try different sticks of ram or try the ones you have one at a time to see which one is affected.
Feb 26, 2009 | Intel D945GPM Motherboard
Unable to use my computer. Usb keyboard, mouse fail
See buddy
If the BIOS it self is not opening means that it is not getting started,at the timing of power startup it just goes off with out showing anything the issue might be with the BIOS cell check that out otherwise there might be any issue with the BIOS than u have to consult with the vendor,
Now in second case where it is not working after the POST is done than might be the first boot sector has gone faulty you have to reinstall the OS.
ANd in if case it is giving a long beep before shutting down the issue might be with RAM check that out.
Inshort the issue might be with three things
1) BIOS cell (change the bios cell)
2) BIOS itself (consult vendor)
3) OS (Reinstall the OS)
4) RAM (Swap or change the RAM)
PLz do rate incase this info is important or giving u any benifit it helps us...
Thanx
Gizmo
Dec 20, 2007 | Computers & Internet
I screwed up the MB BIOS and CMOS
well we have to reset your BIOS. you have to remove the CR2032 flat battery(the silver and circle shape thing) on the motherboard and put it back just exactly before you removed it then you would be just fine that if the problem is on the BIOS setup..i need to know how many beeps you can hear when you power on the PC.?
Dec 11, 2007 | Computers & Internet
Wont boot
seems contagious mine did the same thing!not sure how helpful this will be but the bios handles the starting up part and if it's corrupt then that wont happen.If you can get the bios flash that you need onto a floppy then that might help at the moment I'm waiting for a new bios chip.Did you receive any errors at all ?awdflash.exe? insert disc etc ?
Aug 16, 2007 | EliteGroup P4VXASD (P4VXASD-R) Motherboard
Intel D945GNT Motherboard Logo
182 people viewed this question
Top Intel Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
