945GCT-M/1333 recognize Primary IDE Master as IDE 3 Master
I have ECS 945GCT-M/1333 Motherboard with 1 Hard Drive and 1 IDE DVD Drive for a while.
And the Motherboard recognizes HDD as Primary IDE Master and DVD Rom as Primary IDE Slave.
Yesterday, I install one more IDE hard drive and add SATA DVD RW Drive.
I made correct jumper setting on both hard drives (one as Master and the other as slave).
Also did correct connection on IDE cable (Blue to Mother board, Gray to Slave and Black to Master).
And connect SATA cable to SATA1 in the motherboard.
But when I boot, system recognize DVD RW Drive as Primary Master IDE and Hard Drives as IDE 3 Master and IDE 3 Slave. It took a while to boot up but successfully launch Win XP Pro.
Today, I went to ECS website and update bios to latest version but still same.
Since it boots it is not big deal but how can I correct this issue?
I would like to make HDD1 as Primary IDE Master and HDD2 as Primary IDE Slave.
I looked all over but could not find the answer.
Thanks in advance,
Hanool
  • 37 Answers
Hello. Some motherboards set SATA1 as IDE primary master, for compatibility. Try connect the DVD RW to SATA2 or SATA3 Port.
Posted on Feb 26, 2009
2 Suggested Answers
SOURCE: 945GCT-M/1333 recognize Primary IDE Master as IDE 3 Master
You can resolve this problem:
Go to the setup-then go to Advanced setup-and then go to hard disk drives- there put in 1st drive the hard disk you want to boot (where is locate the Operative System) this you can do it pressing ¨Enter¨ and selecting with ¨flecha arriba o flecha abajo´¨ in spanish lenguith. then you shuld press F10 and salve & exit.
That is all.
Posted on Mar 01, 2009
Where can I get a Gateway 945GCT-NM manual?
A manual for the Motherboard 945GCT-M/1333 (V3.0) can be found at the link below. Gateway's support site does not recognize 945GCT-NM as a valid Gateway model number.
http://download.ecs.com.tw/dlfileecs/manual/mb/eng/p4/945GCT-M1333_v3.0/22_945GCT-M%201333%20(3.0)_Low.pdf
May 26, 2014 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
When I push the start button of the PC, the fan of the processor of the motherboard ECS 945GCT start running and nothing appear on the screen. It seems that it hangs somewhere on the POST. Is there a...
one bad/faulty lead can cause a computer lots of problems
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty
hope this helps
Sep 30, 2010 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
Looking for 945gct-m2/1333 motherboard sound driver
Hi, try this link for your drivers: http://driverscollection.com/?H=945GCT-M/1333%20%28V3.0%29&By=ECS%20%28Elitegroup%29
Jul 30, 2010 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
ECS 945GCT-M/1333 HD Recognition
Hmmmm, that is very strange that the manufacturer would put the port on the motherboard and not provide support for it. Yo have set your BIOS properly, correct? ... and there is no issue with the drive being too large, correct?
Mar 19, 2010 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
Not decting my sata burner sometimes
i do not have the motherboard driver for this specification of motherboard
Apr 27, 2009 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
Ide channels not working right after updating dvdrw firmware Set on ide channels should be Primary ide Hard drive primary master. Primary secondary hard drive. Secondary master dvd (read only) Secondary...
usually when you update or re-flash the dvd rom.
it will state :- ensure that the drive to be flashed should be jumper set as master. if there were other drives connected to the same ide channel. this could have caused damage to the other drives connected. Or the IDE Channels themselves.
The only suggestion I have for you. is to remove all the drives. disconnect the power from the computer. and remove the cmos battery, for 10-15 seconds. resetting the computers bios back to defaults. then re-settup the drives ensuring that the jumpers are correct for each drive. i.e 1 slave and 1 master on each ide cable.
Mike @ Compurepair.
Mar 26, 2009 | ASUS A7V8X Motherboard
How set the hard drive and dvd-rom
first idea is to set the Hard drives on the primary controller on the same cable, having your hard drive with windows as the master and the other as slave ( do this with the jumpers).
Next put your cd\dvd drive on the other cable on the secondary ide (the name is usually IDE2).
turn on your PC and pres delete to go to the bios settings,
once there go to the basic cmos settings page, and make sure you see the settings there as you wanted,
Primary master first hard drive
Primary Slave second hard drive
Secondary Master your cd\dvd drive
helpful ? if not give me a reply for more help
Mar 23, 2009 | Computers & Internet
Problems with EliteGroup ECS 945GCT-M/1333 Motherboard - v3.0,sound drivers problem
This is the link for your mainboard driver
ECS 945GCT-M/1333
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=830&CategoryID=1&DetailName=Driver&MenuID=44&LanID=0
Feb 27, 2009 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
Start by simplifying the configuration. Disconnect the second IDE cable from the motherboard and disconnect the power to the DVD drive. Disconnect the SATA device. On the #1 IDE cable, connect the master drive to the connection on the end of the cable. Connect the Slave drive to the middle connection on the cable. Start the computer and press the key indicated to enter setup. Verify that drives are properly indentified as master and slave. If they are, shutdown the computer. Now add the IDE DVD drive to the end connection on IDE cable #2. It should be set as a Master drive. Start the PC again and go into setupand verify that the DVD is IDE #2 Master. Shut down the PC. Add the SATA device and start eh PC again. Go into Setup to verify that all of the drives are properly identifed. Restart the computer and let it boot into Windows. Open Windows Explorer to view the drive settings. If the drives are all present, but the letters are not what you want, click on START and then right click on MY COMPUTER and then left click on MANAGE. Under Storage click on DISK MANAGEMEN. The drives will all be displayed with their assisgned letters. If you need to change a drive letter, right click on the drive you want to change and select 'Change drive letter . . .'. Change it to a hight letter in the alphabet, then change the dive you want in the original postion to the now vacant letter. Finally change the original drive to the first available letter. Example: C:=IDE M1 D: E:=IDE S1 Change D: to H: then E: to D: and finally H: to E: they drives would then be: C:=IDE M1 D:=IDE S1 E:=IDE M2(DVD). Restart the PC and the drive should come up as you want them to be labled.
Good luck and please let me know how it works ouot for you.
Feb 26, 2009 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
Ide drive showing up as ide 3
Hi ,
Set the jumper for Primary IDE at the end of data cable the first two pins (not side by side,opp ) short
It is also wrritten on the HDD.
pl try it
Was this soultion useful?show ur appericiation by rating it
Apr 11, 2008 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
Computers & Internet Logo
635 people viewed this question
David Payne
David Payne
