Question about Jl Audio 500/1 Car Audio Amplifier
I have a jl audio 500/1 going to 2 sony xplods
My power light on the amp is on but there is no output to the subs. theres only music coming out. I have a 2008 g6 with a rca converter in the back. factory radio. what should i do.
  • 80 Answers
Verify that the rca's are getting a signal with a volt meter! volt meter are $5 dollars and easy to use!
Posted on Feb 27, 2009
I have a JL Audio 500/1 that powers on just fine. But there is no output coming from the sub.
Did you check the fuse(s) on the amp itself ?
One or more of those fuses are for protection on the output side of your amp.
What about the 12 volt power from your battery, have you checked for 12 volts present at the input power side of your amp?
Don't forget that you need just as good of a ground as you need power supply!!!!!
Good luck !
Jun 24, 2010 | Jl Audio 500/1 Car Audio Amplifier
Amp comes on then shuts down JL 500/1
what do you have hooked up to it? Subs, Speaker, so on. it sounds like it is going into protection because of improper wiring... or it was improperly wired. if it is malfunctioning you need to take it to an authorized JL audio dealer. It's going to cost some cash unless you have a warranty on it and it was installed by a liscensed technician.
May 31, 2010 | Jl Audio 500/1 Car Audio Amplifier
JL Amp isn't powering subs and speakers
just go through ur connections man one by one ull find the prob soon.....check teminals on battery...power line to amp ....all fuses within prob area and obviously make sure u have a good ground.....really impotant.....ground is the most neglected thing people do from my experience bein a audio tech oh and if that isnt it check ur subs....stick a 9v batt on the back pos n neg of each sub n c if they pop in r out this will determine if ur subz r blown
May 14, 2010 | Jl Audio 500/1 Car Audio Amplifier
silly as it sounds, you may want to check your EQ settings on your headunit. Things like sub volume, SLA, loudness and balance. When they replaced your battery, those old settings were lost.
Mar 26, 2010 | Jl Audio 500/1 Car Audio Amplifier
Power light on, no sound through sub, I'm reading high ohm output
Contact Eric @ Capital Audio & Electronics Repair 850-339-1130 we repair all name brands & all models Located in Tallahassee,Fl
Mar 15, 2010 | Jl Audio 500/1 Car Audio Amplifier
How do i wire two audio pipe dvc woofers to this amp. do i use all four terminals on da amp. jl audio 500.1
Hello smoovek2008,
The JL Audio 500/1 outputs 500 watts RMS into a load from 1.5 to 4 ohms. Whether your subs have 2 ohm or 4 ohm voice coils, they should be wired in series and the subs paralleled to the amp. The final load to the amp will be either 2 ohms or 4 ohms, both of which the amp can handle. If you parallel the voice coils and then parallel the subs, the final impedance will be either 0.5 ohm or 1 ohm, both too low for the amp.
You can wire each sub to a separate set of terminals or both to the same set. The terminals are connected internally. It doesn't matter which of the +'s or -'s you use.
Hope this helps.
Sep 25, 2009 | Jl Audio 500/1 Car Audio Amplifier
JL Audio 500/1 Amplifier "Thermal" light flashing
Re-check all the connections to the speakers, The uPC monitors all the outputs and if any are taking more power than they should, the uPC shuts the amp down to protect the internal components. Don`t use tape joints alone, try to run the cable the full length without any joints. If you do have to piece the wires together, solder them and stagger the connections, in other words, make one lead shorter than the other so that if the tape does come off, the offending connection is well away from the other so they can never meet or connect to each other. Ian
Jul 24, 2009 | Jl Audio 500/1 Car Audio Amplifier
JL Audio 500/1 Amp, The green power light is on but no sound!
Check to be sure you are on the correct outputs on the head unit, and be sure the outputs do not have a separate volume control.
Mar 06, 2009 | Jl Audio 500/1 Car Audio Amplifier
500/1 sub amp stopped working, burnt rubber smell
It sounds like the power supply failed. Generally when the supply fails in that amp, you have to replace all 8 of the power supply FETs and all 8 of the 47 ohm surface mount resistors. Many times, the supply fails because one or two of the output transistors have failed.
If you want to have JL repair it, you MUST go through an authorized JL dealer.
If you have a good local repair shop, they should be able to repair it.
Let me know if you have any other questions.
Aug 06, 2008 | Jl Audio 500/1 Car Audio Amplifier
Jl audio 500-5
Assuming that you've confirmed that the speaker is in good working order and that the wiring isn't shorted in any way...
There are separate power supplies for the high and low amplifiers. It's possible that the one for the sub output has failed. If that's the case, the output transistors probably failed and that's what damaged the supply.
Generally, I'm willing to help people repair their amps but this is a large, complex amplifier and it should be repaired by a qualified technician.
Apr 18, 2008 | Jl Audio 500/5 Car Audio Amplifier
Jl Audio 500/1 Car Audio Amplifier Logo
155 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
hoyzee1
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
