Question about Canon NP 6050 Copier
Noise while printing with copier
While printing with the NP6050 I am experiencing some fluttering noises that really sound like the whole machine is comming apart, it's comming from the back side or the opposite side from where the paper comes out at, the copies i'm referring too. the noise sounds like something is grinding or rubbing up against something on the inside loud and obnoxious, please help
....whatever it is, understand that you need a technician
Posted on Feb 26, 2009
How we can solved the hp lj p2055dn printer noise
Hopefully one of the first four suggestions helped you. If not if you could post more detail as to what kind of noise is the machine making: a grinding noise, a squealing noise, how loud is it. descriptions such as that would be helpful in diagnosing the issue. Without a description of the noise any of those first four posts could be relevant. The easiest thing to try first would of course be a toner cartridge I have experienced them many times making noises especially if they're aftermarket cartridges. Other than that grinding noises are typically fuser related in that machine, with squealing and high pitch noises the description of the noise is very important because it could be a fuse or it could just be dirt in a gear cluster rubbing on a shaft or it could be the laser assembly. Ireally hate to post absolute diagnosis without enough detail especially when it comes to you having to spend more money. Hope this helps.
Sep 24, 2014 | HP P2035N LaserJet Monochrome Printer
I have HP laserjet 1018 printer and it makes noisy sound when it prints. But it prints fine though. What causes making this noise?
The noise is probably due to the print heads aligning and clicking. To try to make this noise a little quieter, clean and align the print heads.
Mar 23, 2011 | HP LaserJet 1018 Printer
Noisy printer
yha u have to change taplone tap on rollers.it is broken so create noise.
Mar 25, 2009 | Epson AcuLaser C900 Printer
I was having problems with dark spots on the copy of as it was being printed, I was told to replace the glass, and I did, and today I am still having the same problem, it looks as though the copier itself...
this is a very mechanical machine that does require a good tech to see it every once in a while. the fluttering is most likely the fixing unit rollers. This machine if not used alot can flatten the fixing roller and cause a noise like you describe. Plus corona wires need changed when this happens to the quality. It not a DIY fix, sorry.
Mar 10, 2009 | Canon NP 6050 Copier
Fluttering noise in engine while accelerating at a fast rate
I believe you may be referring to 'pinging', Try a tank of premium gas and see if it stops. Check your timing, and when was it last tuned? Let me know what u find. countrycurt0
Oct 02, 2008 | 2002 Ford Explorer
Fan flutter noise with air conditioning on
I WENT TO THE VW DEALER...HAPPENED TO PASS BY. THE PROBLEM WAS SOLVED WHICH WAS FLUTTERING SOUND FROM THE AIR CONDITIONING FAN.
IT WAS COMING, I WAS TOLD, FROM THE MECHANISM THAT ADJUST THE TEMPERATURE, AND NOT THE FAN
THANKS FOR THE FOLLOW UP
Sep 08, 2008 | 2000 Volkswagen Golf
Load Noises
If the HP LaserJet series printer is experiencing a grinding or odd noise when printing or on power-up, open the printer and remove the print cartridge. Close the printer door.
If the noise does not recur with the print cartridge removed, replace the print cartridge.
If the noise persists, this may indicate a hardware failure. If possible, isolate and identify the location of the noise and contact a local HP sales and service ofice at the number noted in the product User's Guide . A list of phone numbers can be found at
http://www.hp.com/support .
Feb 15, 2008 | HP LaserJet 1320 Printer
Canon NP 6050 Copier Logo
120 people viewed this question
old marine
old marine
