Question about Bosch 24 in. SHU43 Built-in Dishwasher
How to replace electric motor
Motor is seized and I need to remove it, but don't know the sequence in how to get it out. model sch43c Bosch dishwasher 24 in.
  • 686 Answers
Take it out and turn it upside down outside and go from there. At the edge of the counter underneath should be 2 screws that fasten it to the counter
Posted on Feb 27, 2009
I have a Bosch WFL 1200 front load washing machine. I need to replace the brushes on the motor. This model only has an "oval" shaped panel at the back. The side and back panels are all one piece and c
ALWAYS disconnect electrics....You need to access the motor from the bottom of machine.as it is a pig to work on if you try to replace the bushes whilst in situ...what I do is empty the machines residual water from drain tube bottom front then remove back.... undo belt .... Then lean the machine at 45degrees to one side and undo the two retaining bolts on the pulley side .the whole motor will slide toward rear of machine but uncouple the electrics block first then remove motor.the brushes are spring loaded and the brass clip slides one way to release?there are plenty of YouTube tutorials on bosch washing machines that show brush replacement.good luck.
Jan 29, 2015 | Bosch Washing Machines
Bosch 4000 table saw motor does not turn, very stiff
Possibly something has jammed inside the motor housing although unlikely.
Electric brake seized perhaps?
Carbon brushes need replaced?
These saws (and the newer 4100) have a history of motor problems, with the field winding and electronic motor speed control being the most common points of failure. If you go to an online tool parts supplier like toolpartsdirect- Bosch 4000 saw you will see a list of the parts available, as well as the most commonly ordered parts.
Thanks go to Jason for his blog post at:
http://mypeculiarnature.blogspot.co.uk/2013/07/bosch-4000-table-saw-fix-momentum-lost.html
May 23, 2014 | Bosch 4000 - 07 Electric Table Saws
Replacing cord on Bosch Hammer Drill
I don't know what model you have but most Bosch hammer drills have three or four screws on the backside of the handle that, when removed, let you split the handle from the motor housing and gain access to the switch and brushes. The screws may or may not be covered by a rubber, non-slip covering that you'll have to peel back to get at them.
Jan 28, 2012 | Bosch Drills
Electric blade brake sounds like it is seized up. Upon starting table saw (bosch 4000), motor sounds like it is binding. How can I disengage the brake??
There is no electric brake on the Bosch 4100 table saw. If the motor sounds like it is being held back its possible the rear armature bearing has seized or the field coil is faulty. Both these problems cause the motr to not turn at full speed. The motor must be serviced.
Dec 08, 2010 | Bosch 4100 10" Worksite Table Saw
Saw blade seems to be seized, it is hard to turn manually.
could be a couple problems, first is the inner flange on correctly. and if so remove the blade UNPLUG SAW FIRST and see if you can turn the spindle by hand, it should spin freely, if not then you have a bearing problem or possibly the motor is burnt. did you notice any burning smell last time you used it and if so that is it. Let me know
Aug 28, 2010 | Bosch 4000 - 07 Electric Table Saws
Our bosch dishwasher runs but no water is spraying on the inside. Is there a water filter clean out or is there a water pump that might be broken? I checked the line coming in and it isn't plugged. I...
Hi, welcome to Fixya. By the description you've provided, it sound's like the wash motor is either seized or just stuck, let's hope it's the later. Bosch had issued a service tip about this problem several years ago titled "Loosening Frozen Impellers" strange choice of word's considering nothing is froze..at least you'd hope lol. Essentially what it say's is this...Remove the pump filter ( inside the tub under the bottom rack ) locate the hole to your right down in the sump well, you should be able to see it with a flashlight so it's a well lit area. Once you've located this hole ( it's providing access to the wash impeller without pulling the unit from the cabinet ) reach in with a 8mm nut driver and locate the end of the impeller and turn it clock-wise until it feel's to turn freely. Give it a test perhaps in a rinse cycle before you put all the filter and screen back together. It should be fine unless the motor is seized, we'll cross that bridge when we get to it, try the repair tip for now. Let me know how that help's and/or if you need further assistance. Thank's for visiting "fixya" for you repair tip's. If this is indeed helpful please rate the solution accordingly, if not let me know. Thanks again and good luck. Macmarkus :)
Jun 13, 2010 | Bosch 24 in. SHE43C05UC Stainless Steel...
Bosch Dishwasher model SHU66C soap door will not open
This is most likely the actuator for the soap door. Unplug and remove door covers to find it, and check it is not seized. Look at "wax motor" online to understand working, as they often use these (and may appear siezed - when actually ok)
Check cables are not broken and connectors not corroded.
Replace actuator if you are uncertain, and try again.
Further problems may be the contact to control it in the controller assembly or a broken cable between the two.
Jun 06, 2010 | Bosch 24 in. SHU6802UC / SHU6806UC...
Drum does not spin - doesn't wash either.
motor brushes could be worn out or it has a break in the motors wring & will need to be replaced!
Jul 21, 2009 | Asko W6441 Front Load Washer
My bosch table saw runs slowly backwards what part do i replace
Replace the field coil. I'm going to bet its a Model 4000. I have done about 100 of these saws in the last couple of years and my customers always complain of the same problem, "the saw was running backwards"
Change the armature back bearing while you have it apart, they always seize eventually.
Jun 23, 2009 | Bosch 4000 - 07 Electric Table Saws
Bosch 24 in. SHU43 Built-in Dishwasher Logo
133 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
