Question about Microsoft Works 8.0 for PC
"out of memory" message appears when I try to print a spreadsheet
When the error message appears, the coumuter locks up completely and I must manually shut off the computer.
  • Tony Begenwald Mar 02, 2009
    My computer has more than enought memory, so it isn't that. I can print emails, files from Microsoft Word, and other programs. I was able to save the spread sheet I created in Microsoft Works Spreadsheet as an Exel file and was able to printit out. Therefore I'm convinced the the problem lies in the Microsoft Works Spreadsheet software. Thanks for responding to my problem.
    Problem Solver:
  • 11 Answers
Obviously, your PC is quite an older one with less than the required memory. You might also have run other programs that might be hindering your MS works 8.0 as these programs are memory intensive! Solution: Add more than 2 Gig bytes of new RAM ( shop around for a cheap/reliable one )to your PC system as the required memory! As for the page file ( find it under 'Control Panel - System/ System Settings - Advanced - Performance Options - Advanced - Virtual Memory - C: or D: or whichever your logical drives you might have' ), try to increase it to 2 Gig bytes!
A security factor worth taking note of: Use drive D: or whichever data drive your PC uses for its data as sometimes hackers try to hack into your System/ OS drive like C: so as to compromise the IT security.
Your MS works 8.0 might require a re-installation after the increase of the RAM and the page file!
Posted on Feb 26, 2009
Error message: communication error
I use a USB cable and never see a communication error
Jul 08, 2015 | Canon PowerShot SX520 HS Digital Camera...
Says: Unable to Clean Consult owners manual
When trying to use your Brother machine you get the message "Unable to _____". The blank may be the word Change, Print, Scan or Clean and these words may vary from model to model.
This message is a general message and will appear for different reasons. It often indicates a paper jam or a mechanical issue. Complete the following to determine the possible issue.
  1. Check for foreign objects, such as a clip or ripped paper, inside the machine.
    Open the top cover and remove any foreign obstacles from inside the fax machine. If you see jammed paper or another item inside this area, gently pull it out and then close the top cover securely.
  1. If the error continues to appear, the machine may have a mechanical problem.
    If the error message continues to appear, the machine will need to be reset. Resetting the machine will erase all faxes in memory and the Fax Journal Report. However, there is a way to transfer faxes in memory and the Fax Journal Report to another fax machine to print them out. Do the following to transfer the data and reset the machine:
Step1: Transfer the Fax Journal Report
  1. Press Menu/Set on the Control Panel of the machine.
  2. Press the up or down navigation key until MISCELLANEOUS appears on the LCD. Then press Menu/Set.
  3. Press the up or down navigation key until DATA TRANSFER appears on the LCD. Then press Menu/Set.
  4. Press the up or down navigation key until REPORT TRANS. appears on the LCD. Then press Menu/Set.
  5. The LCD will prompt you to enter a fax number. Enter the number of the fax that you want to receive and print the report. Press Fax Start.
Step2: Verify and Transfer faxes in memory
  4. Press the up or down navigation key until FAX TRANSFER appears on the LCD. Then press Menu/Set.
  5. If there are no faxes saved in memory, NO DATA will appear on the LCD. Continue to Step 3.
    If faxes are present, the LCD will prompt you to enter a fax number. Enter the number of the fax that you want to receive and print the faxes. Press Fax Start.
Step3: Reset the machine
After the Fax Journal Report and faxes in memory are transferred to another fax machine, disconnect the Brother machine from the power source for several minutes and then reconnect it.
If the message continues to appear on the LCD, please contact Brother Customer Service.
Dec 16, 2010 | Office Equipment & Supplies
Whenever I try to print a spreadsheet I get a message; "Out of memory. Save or close any open files or applications" - after I close the spreadsheet I get a message: "the document and printer setting do...
You could try a disk clean.
Start>all programes>accessories>system tools>disc clean up. this will make space on you PC, could also do a defrag to help speed up your PC.
Aug 30, 2010 | HP Office Equipment & Supplies
49.4co2 service error will not clear
Error 49.xxxx - this type of error can be caused by invalid print comands, corrupt data or invalid operation...try this steps to resolve... :
1 Turn the MFP off, and then turn the
MFP on.
2 Upgrade the firmware.
3 Try printing a job from a different
software program. If the job prints, go
back to the first program and try
printing a different file. If the message
appears only with a certain software
program or print job, contact the
software vendor for assistance.
4 If the message persists when using
different software programs and
attempting specific print jobs,
disconnect all of the cables that
connect the MFP to the network or a
computer.
5 Turn the MFP off.
6 Remove all DIMMs and flash-memory
cards. Do not remove the firmware
memory card that is in slot 1.
7 Remove all of the EIO devices.
8 Turn the MFP on.
9 If the error message disappears,
reinstall each DIMM, flash-memory
card, and EIO device individually,
making sure to turn the MFP power off
and then on again as you install each
device.
10 Replace the component that caused
the error message.
11 If the error persists, replace the
formatter
Jan 06, 2010 | HP LaserJet 4650 Color Printer Manual...
Printer "out of memory"
The problem isn't your printer. The problem is with your Microsoft Works software. I know of six solutions that may work.
1) Download the latest service pack for .NET Framework 1.1. http://www.microsoft.com/downloads/details.aspx?FamilyId=A8F5654F-088E-40B2-BBDB-A83353618B38&displaylang=en
2) Go to this website and download the update. http://www.microsoft.com/downloads/details.aspx?FamilyID=65f5b806-e6a1-4f92-a656-e56eeda67e3d&displaylang=en
3) Uninstall printer completely (again). Unplug the printer from the computer. Reboot computer. Download the lastest driver from HP website. When installing the driver software, choose (type)a different directory,( ie. C:\MYHP\HP4180\ ). Plug Printer back to computer.
4) Go to this website. http://support.microsoft.com/kb/841220
5) Click START, click RUN, type SPOOL. Double click printer folder, clear (delete) any files in this folder.
6) Download the latest version of Microsoft Works 9.0.
Let me know if this works.
Feb 03, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
So which printer are you wanting help with?
Nov 23, 2008 | Office Equipment & Supplies
Printer will not print
    Open the scanner cover by pulling up on the lower right corner of the cover. Look inside the machine and remove any foreign objects. If you see jammed paper or another item inside this area, gently pull it out and then close the scanner cover securely.
  2. User's manual:
http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=mfc420cn_us&type2=5&flang=English&dlid=
You may have to copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 11, 2008 | Brother MFC 420CN All-In-One InkJet...
"remove and check cartridge" error message
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=buu02180&cc=in&lc=en&dlc=en
I resolved the "remove and check cartridge" issue after reading the instructions at the above address. Most importantly, I replaced both cartridges and the problem was resolved.
The color cartridge appeared to be the issue. It had been in for months and used infrequently.
May 30, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Cleaning troubleshoot needed
When trying to use your Brother machine you get the message "Unable to _____". The blank may be the word Change, Print, Scan or Clean and these words may vary from model to model. This message is a general message and will appear for different reasons. It often indicates a paper jam or a mechanical issue. Complete the following to determine the possible issue. 1. Check for foreign objects, such as a clip or ripped paper, inside the machine. Open the scanner cover by pulling up on the lower right corner of the cover. Look inside the machine and remove any foreign objects. If you see jammed paper or another item inside this area, gently pull it out and then close the scanner cover securely. 2. If the error continues to appear, the machine may have a mechanical problem. If the error message continues to appear, the machine will need to be reset. Resetting the machine will erase all faxes in memory and the Fax Journal Report. However, there is a way to transfer faxes in memory and the Fax Journal Report to another fax machine to print them out. Do the following to transfer the data and reset the machine:
Jul 28, 2007 | Brother MFC-5840CN All-In-One InkJet...
Microsoft Works 8.0 for PC Logo
404 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
