Question about Panasonic Lands Phones
Panasonic TES824 program to pickup any available outside line
I would like to have my phone system acquire any open line when I dial 9 from one of our regular phones.
During the system off how to change the call landing code.
Posted on Feb 10, 2010
How can i pick up the call from my office phone when reception phone rings
Hello,Looks like you'll need to re-program your PBX unit. I would suggest looking up: 1.5.3.3 Outside (CO) Line Access 2.2.4 Operator/Manager Featuresin the Programming manual found here:
http://www.tongxun.com.cn/data/download/Feature_Guide.pdf
Hope this helps
Nov 27, 2012 | Panasonic KX-T7730 Corded Phone
How to turn on caller id on Panasonic KX-T7730. How to set outside line on Panasonic KX-T7730 so that a Panasonic cordless phone can call out
CID is part of the phone system and requires a -93 card and system programming. Panasonic makes different systems that the 7730 phone works on, but it was first delivered with the TA-824 or equivalent system. It also needs to be programmed to tell it how may lines are equipped. Then, when you dial "9" to get an outside line, it will grab the highest WORKING line, instead of just the highest line.
FInd the model number on the system cabinet and do an internet search for the installation manual of the system.
Carl
Sep 01, 2011 | Panasonic KX-T7730 Corded Phone
Forumla for adding speed dial numbers
Personal speed (the 12 F buttons on the right) depend on whether you dial "9" to get an outside line. Then the buttons are programmed by pressing PROGRAM the button and dialint the speed dial number with a 9+ then STORE. System speed dial number sare programmed in SYSTEM programming 001 and they have "9" also in front of them.
Carl
Jun 18, 2011 | Panasonic KX-T7730 Corded Phone
Would you please be able to tell me how to programme a number in this phone.... on a specific button down the side.
What happens when you dial "9" on the intercom? If you get an outside line, then your phone is programmed properly. If you get an empty line, then you need to disable vacant lines in system program 400.
To program the right side buttons for speed dial, press PROGRAM a button on the right side, and dial 9+ the number as you would dial it on an outside line, then STORE.
On the left side, a waste if you're putting speed dial number sin, you dial 29 instead of 9, but normally you reserve them for lines, extensions, and features that require lit buttons. The codes would begin with 0,1 and whatever the magic code for the features are.
Carl
May 05, 2011 | Panasonic KX-T7730 Corded Phone
Panasonic KX-T7730 Corded Phone programmed speed dial numbers not working. will not dial numbers programmed
When the system is installed, you need to make sure that only the lines equipped are in the access plan (program 400 in a TA series box). When you go to the intercom on a phone and dial "9" you should get an outside line every time. If that works, system and personal speed dials include that access code as part of the number. eg my test number is 914197845522 9+1+10 digits.
Carl
Apr 01, 2011 | Panasonic KX-T7730 Corded Phone
Cannot store numbers for One-touch dialing.
I can.
A lot depends on where you're trying to store these numbers and how you get an outside line. In my system, I dial "9" on the intercom and it gives me any available outside line. Also, IIRC a 7453 has 24 buttons with LED's on them. So, the Pana trick is the digit "2". Try this: PROGRAM 99, touch a button with an LED, and dial 2 + 9 + your number and STORE. The "2" tells the system to use the button as a "one touch" button. In other phones, the "F" buttons (ones without lights) already assume the "2" so it's programmed with just the access code "9" and the number.
Carl
Mar 11, 2011 | Panasonic KX-T7453 Corded Phone
How do I program a phone number to the one touch buttons on a Panasonic KX-T7730 phone?
It depends on what you get when you dial "9" on the intercom. If you get an outside line, then the 12 right side buttons on your phone can be programmed for one touch dialing like this:
On an idle phone, press PROGRAM a button and dial 9 plus the number and STORE. You can program more than one button by just pressing button numbers and STORE. Exit programming by picking up the handset and dropping it back down.
If you want a specific line, you may be able to dial the specific 8x code to access a line directly, or you can go into system programming and delete the open lines in program 400. Disabling would be the best, because if your 8x line is busy, you can't make the call with the auto dial button.
Carl
Mar 08, 2011 | Panasonic KX-T7730 Corded Phone
Can not get kx-t7885 to get a dial tone. The phone is paired with it's base, and will get the panasonic dial tone but not an outside line.
How are you trying to get an outside line? By dialing 9? If the host system happens to be a TA series, you have to tell it how many lines you have, or that you don't have lines that have hardware ports but no dial tone, since systems select outside lines from the top down.
From System programming, program 400 defines connected lines.
Carl
Nov 22, 2009 | Panasonic KX-T7885 Cordless Phone
I NEED TO STORE NUMBER ON MY PANASONIC KX T7730
The mechanics of storing a speed dial number on Panasonic phones is the same, even if the phone can be connected to one of 18 different model Key Service Units. It involves pressing PROGRAM a button, an access code, the number, and STORE. In the U.S. our access code to get an outside line is "9". You may be using something different, like '0'.
The differences are if you can dial "9" on the intercom and get a dial tone, which collumn of buttons you press, and/or whether you want this to be PERSONAL numbers or SYSTEM numbers.
In a TA-824, lines are accessed high to low. If you have 2 lines on a basic system and dial "9" to get an outside line, you will land on line 3 if you have not told the system that line 3 is disabled (system program 400). So, the fast answer is press PROGRAM, a button on the right side, dial 9+your desired number and STORE. If it's a left side button, dial 29 instead of 9.
System speed dials requrie access to system program 001.
If this does not work on your system, please comment back with your actual system model number.
Carl
Nov 09, 2009 | Panasonic KX-T7730 Corded Phone
How do I forward calls to an outside number on a panasonic kx-ta824 system. what is the line access code
Line access codes are the codes you dial from the intercom to get an outside line. 9 works.
Call forwarding to an outside line has to be enabled in system programming either 2.1 in the maintenance console or option 607 in system programming. There's also a timer that allows the CO connection to be maintaned. By default it's 10 minutes.
Once you get the program set up, you can dial 7139xxx-xxx-xxxx#
Carl
Oct 06, 2009 | Panasonic KX-TA824PK Phone
Lands Phones Logo
418 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
