Question about Acer Aspire One PC Notebook
My powercord the charger for my laptop doesnt want to charge my computer
  • flybear83 Feb 26, 2009
    thanx 4 the suggestion. yes the jack feels loose and no i dont get any lights.
    President:
  • 2,653 Answers
Try another power supply. If you don't have one try visiting the place you purchased the laptop and using the power from one of their display units. If it works, then replace the power supply of course.
If not hopefully your laptop is still under warranty.
Does the jack feel loose, do you get an lights?
Let me know.
Posted on Feb 26, 2009
  • RescueTechLA
    RescueTechLA Feb 26, 2009
    If the jack feels loose then it's probably causing the problem. You can find people on craigslist or a local shop to replace the jack. Don't pay more than $100 or you're being ripped off.
    Let me know if you have any other questions.
    Best of luck!
  • RescueTechLA
    Best of luck!
My MSI GT680 Notebook charging system doesnt work. when I plug my charger into the wall the green light indicator comes on, then when I put the plug into the laptop the light turns off and it doesn
Hello! It seems that you have a problem with the laptop charger connector. It maybe in short circuit. You can try to look for some electronic workshop that works with reballing, BGA solder, etc., that might change it. In Portugal we have some, so I think in other countries you can find them to.
Apr 03, 2013 | MSI Microstar GT680R-008US 15.6" Notebook...
Battery not charging
you might have a problem with your computer battery or the charger is broken. mine is and it doesnt charge but it prevents it from losing battery.
Dec 30, 2012 | HP Compaq Presario CQ50-110US Laptop
Samsung R519-53S not charging
Please remove battery and connect charger and turn on computer. If on adapter working fine, now connect battery without removing charger , and check charging.
May 09, 2012 | Samsung R519-53S Notebook
I disconnected the PC today. When I reconnected it, the power supply green light flashes on the back of PC, but the PC would not turn on when I press the ON button on the front of PC. What may be the...
Hi, I would suggest that you powerdrain first your desktop before turnng it on again. What might cause this problem is you did not properly shutdown you computer or power interuption. To powerdraqin your computer you must unplug first the powercord on the back of your desktop then you should press and hold the power button for 20 seconds without the powercord plugin to your desktop, after that you can now plug in the powercord and turn on your desktop computer. If this troubleshooting step doesnt work you can try unpluging the powersupply itself into the motherboard and just plug it back, also while your doing this you might also try clean the
RAMS or the memory of your computer and make sure that they are properly seated. Hope this helps
Jun 03, 2010 | HP Pavilion a630n Notebook
Can a powercord go bad. My daughter has a Dell
It is unlikely that the battery of your Dell had to be changed in year and a half's time. Anyway now that you have a new battery and the laptop is still not functional means that either the charger is faulty (unlikely) or the power on switch is bad (most likely). When you used the new battery first time, did the laptop come on even for a short while. If it did then the charger is faulty. If it did not then the switch may be faulty. Please check and come back to me.
Dec 18, 2009 | Dell Inspiron 1525 Laptop
I have the hp omnibook 500 plugged into the wall but im not getting in response, do i need to have anything else plugged into the laptop
if the charge light doesnt turn on on the computer ..then you may have a broken wire from the charger .. that happens frequently right at where the wire enters the plug that plugs into the computer .. someone thats knowlegable about polarity and soldering can replace the tip .. or you could get a new charger ... if the charge light does lignt steady on the computer then thats not the problem .. often it is ..
Nov 12, 2009 | HP OmniBook 500 Notebook
Laptop won't charge
1, look at the bottom, there should a sliding switch use to unlock the battery, some have 1 or more sliding switch to remove the battery. 2. best reference is your user manual, if you dont have it, try googling on the net for your user manual of your laptop.
Mar 31, 2009 | Computers & Internet
When i plug in my charger to my laptop it doesnt work and i dont know whats wrong with it
This issue can be caused by any of the below possibilities. 1.- Computer AC / DC cable is bad not allowing the computer battery to charge.
2.- Battery is bad.
3.- Battery charger board is bad.
Solutions:
Verify that the AC and or DC cable is not bad by testing the computer only with the power plug connected and the battery out of the laptop.
2.- Battery is bad
It is possible that if the power plug is good that the computer battery is bad. Leave the computer connected to the power with the battery connected in the computer for at least one hour; if the battery does not charge, consider having the battery and/or the laptop serviced or repaired.
If the computer and/or battery is not in warranty consider just replacing the battery as it is very likely that it is just a bad battery.
If the battery has been replaced or an alternate battery from an alternate identical laptop does not work in the computer, it is likely that the power or charger board within the laptop is bad. It is recommended that the laptop be serviced or repaired.
This will fix your problem.
Don't forget to rate my help! :-)
Thank you for using FIXYA!
Pablo
Oct 14, 2008 | Computers & Internet
Dell Inspiron 2200 Charger Malfunction
Try to turn off the computer and remove the battery from the bottom of the notebook. Turn on the computer with just the charger plugged in. If it doesnt turn on. you may have a bad power port.
If it has no power/charging issue since that happened except that the indicator light doesnt turn on when you plug in the charger, you may just need a bios update. Click here. That's the bios update for the inspiron 2200 from dell's website. You should have at least 30% charge on the battery and the ac adapter should be plugged in so you can run it. The computer will restart and will come back normally after this. I'd suggest that you backup your files before running this.
Sep 28, 2008 | Dell Inspiron 2200 PC Notebook
Acer Aspire One  PC Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
