Question about Hoover F6021-900 Steam Vacuum
Need replacement parts
Have a hoover steamvac model #6030-900 the tank that holds the water is broken on the bottom. i believe its a valve looks like a screw with a spring. is this part or parts to fix this available to order or do i just have to order a whole new tank
  • 294 Answers
Yes, the parts are available to replace under $5.00, however a dealer will want to sell you a new tank. (this is accurate as of 2 months ago)
Posted on Mar 01, 2009
We have a Hoover Steamvac F7452 that is leaking water from the bottom of the machine. If we place the water tank on the machine, water immediately starts flowing through to bottom of the machine. It'
When you put the tank on it connects with the unit and opens the valve on the bottom of the tank to allow the water to flow check for debris hair etc around the connection, it is possible the seal itself is worn or bad and needs replacement but I think the trigger only lets air in the tank so the water will flow out by gravity, I'm not positive on this but mine works that way.
Oct 19, 2014 | Hoover F7452-900 SteamVac Upright Vacuum
How do I cycle the valves on the bottom with the eraser end of a pencil on my hoover dual vac shampooer
The center part of the valve (stem) pushes up (spring loaded) to release liquid. If it leaks it can (and should) be replaced. Also, check the black valve seal (conical shaped ring around the outside) for cracks or splits as this can contribute to leaks. The entire valve assembly (similar to photo) should be replaced to solve both issues.
Oct 09, 2014 | Hoover SteamVac F5914-900 SpinScrub...
I have a Hoover V2 Steam Vac widepath and the
This is a notorious problem with the Hoover V2 SteamVac's. In fact the tank design by Hoover on your SteamVac was so bad, that Hoover redesigned this tank almost immediately due to the numerous problems customers were having.
For your particular problem, you really have two options. The first option is putting a bandaid over the problem, but will still fix it. We sell the entire gasket assembly on the bottom of the detergent tank as a replacement part. Unfortunately it's sold together with the seal, spring, and valve together as an assembly;
http://www.govacuum.com/hoover-steamvac-dual-v2-tank-valve-part-43513015.html
You also may wish to fix the problem completely by replacing the entire clean water solution tank. Hoover has redesigned this tank, and the new one I don't see near the amount of problems that I do on the older style tanks. The plastic is much more sturdy, and less prone to having the gasket and valve issues that the old tanks do. It's important to point out that the new tank does not come with the handle. You'll need to remove the handle from your old tank if you buy a new tank assembly complete. Rest assured that if you do purchase any part from GoVacuum, you'll have 60 days to return it for a full refund, just in case the repair doesn't work. Not only do we not deduct restocking fees or shipping charges, but we also include a return label with every order that you may use to return any item to us, and we'll even pay for your return shipping!
Here's the Hoover SteamVac V2 Clean Water Solution Tank, Part 12002549
If you'd like us to do a repair photograph series on this repair of the valve and gasket assembly, please just request a repair clarification here on Fixya, and we'll be happy to do so. If you found this helpful, please be sure to rate the review as helpful by clicking on the 4 Thumbs Up Icons in the top right hand corner of the repair.
Thank you so much,
Chris J.
GoVacuum
Mar 23, 2010 | Hoover F7425-900 SteamVac V2 Widepath...
Hoover Runabout steamVac -No return in Recovery Tank
There is a duct in the front of the water recovery tank that you remove to install the upholstery hose. If this duct is missing or not installed properly you will have no suction
Nov 11, 2017 | Hoover SteamVac Carpet/Upholstery Deep...
The water won't stay in the tank...
you will have to replace the complete water tank assy. i have tried without any luck to get this valve to stay in place.
Oct 01, 2008 | Hoover F6212-900 / F6215-900 SteamVac...
Need help!!!!!
Need help!!!!!
Hoover F7425-900 SteamVac V2 Widepath Upright
I read the manual and tried my new Hoover, the brushes spin, but the waters not going to the bottom tank, what does that mean and what can i do?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
You could have a bad water release valve on your water tank of which holds the water, the trigger assm might not be connected, bent or broken. Check the trouble shooting owners manual --- also there are hoses that could be crimped or bent, or clogged or not connected, but it is my guess it is the water release valve. Try to back track the water from the holding tank and test all the valves on the system and you might find the problem by the process of elimination. Feel free to contact you local vacuum cleaner dealer in the yellow pages or contact the Hoover Co @ the information listed below:
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Don – The Vac Man
Apr 22, 2008 | Hoover F7425-900 SteamVac V2 Widepath...
Water loss from tank before pushing dispense button
The part that the tank sits on, there is a round rubber seal(#40), is it in place? One of the rods in the handle asm. may be holding the Reservoir Assem.(39) down letting the water flow.
Is the valve at the bottom of the bottom ok and not stuck, oush in and let out, if it is moving up and down then it is ok.
Feb 21, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Trigger not working
Sounds like you need to replace the handle valve pieces, if they are available, if not then you will have to replace the hose asm. Just take the valve off and see if one of the pieces have a piece broken off. Then with your model number, you can see if that piece is available from someone that has Hoover parts.
Jan 07, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Replacing valve on water tank on hoover steamvac
buy the whole tank not worth the time to repair the valve
Oct 08, 2007 | Hoover F7205900 SteamVac V2 Wet/Dry Vacuum
Hoover F6021-900 Steam Vacuum Logo
88 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
