Question about Roper RAS8244KQ Top Load Washer
Will not pump out water on all cycles.
Washer agitates and fills but when it must remove water for spin cycle timer stops. This happens on all cycles, regular, permanent press, delicate.
  • Roper Master
  • 8,205 Answers
Broken lid switch
Posted on Feb 26, 2009
My 21882 top load Kenmore washer will start the cycle but stops after filling up; i can restart the cycle by pushing the knob in and going a little further in the cycle then starting again. But after a...
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jan 29, 2011 | Kenmore 24032\24036 Top Load Washer
    Washer will not cycle
    The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
    Oct 24, 2008 | Kenmore 15864/15862 Top Load Washer
    My wahser just stopped working it filled with water and then started agitating and then all the sudden stopped please help
    I have a GE washer model # WHDRR418GWW. It is about 19 months old. It stopped agitating and spinning. It will fill with water and the timer/knob will go thru the cycles. But when it reaches the washing...
    You have what is called "agitating dogs" there are usually 4 of them at the bottom of the agitator. They have small grippers which lock onto the agitator and agitates. If the washer is ever overfilled or over time filled to heavy this will wear down the nylon teeth on the "dogs". The top of the agitator will spin off, you will see a bolt inside at the bottom, remove bolt and the agitator will pull out. Google "agitating dogs on washer. It will give you pictures for a better understanding. If the belt was broken the washer would not drain, because the belt turns the pump. These dogs are about $5 and honestly easy to install. Good Luck.
    Dec 04, 2010 | GE WHDRR418GWW 35 cu. ft. Washer
    Stops in the middle of wash cycle
    Hi!
    If the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
    Please do rate this solution as FixYa and revert for further assistance.
    Thanks
    Rylee
    May 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    Frigidaire (LTF2940E) Washer starts, stops, starts, stops...
    May 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
    Will only work on cycle, will not agitate in the other cycles
    Thanks for your question You say it works on one cycle but not the other lets sat you start a regular wash ,the washer should fill ,wash for the minutes you have set, pump out the water #spin , Stop fills & rinse stop pump out water &spin If you try a delicate cycle and it does not do what it did on regular cycle . You have a timer problem . Thanks for your question hope i helped you solve it . THE APPLIANCE DOC
    Sep 09, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
    Kenmore stack washer and dryer
    gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
    Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
    Washer fills/agitates and stops prior to draining
    If pump works fine or still pumps out water, then it is a timer malfunction. Replace the timer and you should be fine. To locate a part number for your timer, refer to www3.sears.com with the model number off your washer.
    Mar 14, 2008 | Kenmore 24032\24036 Top Load Washer
    Roper RAS8244KQ Top Load Washer Logo
    103 people viewed this question
    Top Roper Washing Machines Experts
    Dan Webster
    Dan Webster
    Mike Cairns
    Mike Cairns
    Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
