Question about Blueant Z9i Bluetooth Headset
How do i get my Blueant z9i into pairing mode?
I just got a replacement HTC Tilt and i can't remember how to get my headset to go to pairing mode.
  • skaye_manic Apr 03, 2009
    what about hearing everything and know one can hear what u say for the same phone
  • 38 Answers
You put a Blueant Z9 into pairing mode by holding down the main (Blueant) button for 6 seconds until the light starts flashing repeatedly. On early models it will flash alternately red and blue.
Posted on Mar 26, 2009
Clear memory on blue ant z9
  1. To reset your Z9i it must be switched on but not connected to any devices.
  2. You should already have deleted the pairing information from your phone, but if you have not, use your phone's Bluetooth menu to disconnect from the Z9i and delete the pairing information.
  3. Now reset the Z9i by holding down "Vol +" and "Vol -" and then clicking the BlueAnt button.
  4. The Z9i will refresh its memory, delete all current pairing information and automatically go into pairing mode.
Mar 02, 2011 | Blueant Z9i Bluetooth Headset
Its not pairing, i previously paired it with 2 phones successfully,now i have 2 new phones and i need to unpaired it from the 2 previous phones so that i can pair it with the new phones
To reset the Z9i to factory settings; while in idle mode (not
connected to any device), Click Volume , Volume and MFB together (3 buttons). The Z9i will refresh its
memory, delete all current pairing information and automatically go into Pairing mode (LED will fl ash Blue) ready to pair
with a new device.
Aug 18, 2010 | Blueant Z9i Bluetooth Headset
My blueant z9i will not go into pairing mode ?
Start with your headset turned off. Then, press and hold the MFB until the LED flashes rapidly (some 6 seconds). It should be in pairing mode now.
By the way, if your headset's user guide happens to be missing, feel free to download it from this location.
Hope you are able to sort your problems out.
Cheers! Carlos
May 11, 2010 | Blueant Z9i Bluetooth Headset
How do I put this bluetooth (ant Z9i)into pairing mode? please be detailed as possible...
Pairing Procedure (This is an example only and may differ from your phone, but the process will be the same.)
1. First turn the phone OFF and then back ON again to refresh its memory.
2. Bring the mobile phone to about 30cm from the Z9i Dual Microphone.
3. Find the Bluetooth menu in your mobile phone. Turn Bluetooth ON. (Check your mobile phone user guide if necessary)
4. With the Z9i OFF, Press and Hold the MFB for about 6 seconds. The LED will appear a solid Blue, and then will start fl ashing. The
Z9i is now in Pairing mode and ready to be found in searches by other Bluetooth devices. Pairing mode will be active for 2 minutes.
5. Perform a Bluetooth device discovery on your mobile phone to add a new device. (It takes a few seconds to search for
and fi nd other Bluetooth devices around you).
6. When Bluetooth devices are found, the phone will display “BlueAnt Z9i”. Scroll to it and press OK to confi rm that you
want to Pair with it.
7. Enter Passkey “0000” when your phone prompts you. The phone and Z9i will now Pair.
8. An additional security setting in your phone may be needed to allow the headset and phone to connect automatically
without confi rmation each time you connect your Z9i. Generally in the options for the BlueAnt Z9i, it will be referred to as
“set as authorized”, “add to trusted devices”, ‘’allow connection’’ or similar.
9. If required for fi rst time connection, select the BlueAnt Z9i to connect with your phone. OR, Click the MFB on the Z9i,
to connect with the phone.
You can get the manual on link below. page 9 tells you how to pair.
http://myblueant.com/downloads/manuals/Z9i_manual.pdf
good luck and please rate 4 thumbs for the free answer
Mar 28, 2010 | Blueant Z9i Bluetooth Headset
Pairing my Z9i v1.1 headset with my new iPhone
I had a problem with this also, try this.
Turn off both devices then turn on your phone.
make sure your bluetooth option is "ON" on your phone
turn on the blueant z9i
press and hold both volume buttons, while doing that, press the ANT button.
Your blueant should be flashing fast right now and your iphone should be able to find it.
complete the pairing by selecting the blueant headset on your iphone and enter the code "0000"
enjoy
Jan 06, 2010 | Blueant Z9i Bluetooth Headset
What is the passkey for the BlueAnt Z9i?
The passcode for your Blueant Z9i should be 0000.
Jul 03, 2009 | Blueant Z9i Bluetooth Headset
My BlueAnt won't go into pairing mode anymore!
Have you tried resetting the Blueant Z9i? You push the Volume Up, Volume Down and Blueant buttons all at the same time (with the device on). This will eliminate all paired phones, then re-pair with just your phone (hold down Blueant button for 6 seconds or so to enter pairing mode).
May 07, 2009 | Blueant Z9i Bluetooth Headset
I have a Blueant z9i. The headset will not ring.
Go to this page, it will answer any question concerning the blueant .. including pairing to your phone .. activating your blueant etc http://www.blueant.com.au/index.php
May 03, 2009 | Blueant Blue Ant 091034 X3 Micro Bluetooth...
Z9i Connecting problem.
Feb 24, 2009 | Blueant Z9i Bluetooth Headset
Blueant z9i headset cannot locate push server
Often this is an issue with the phone pairing as a "handsfree" rather than as a "headset". Try resetting the Z9i (push Vol Up, Vol Down and Blueant buttons at same time), then re-pairing ensuring you chose "headset" mode on the Curve.
Dec 30, 2008 | Blueant Z9i Bluetooth Headset
Blueant Z9i Bluetooth Headset Logo
3,754 people viewed this question
Top Blueant Radio Communications Experts
Josh Whitehead
Josh Whitehead
Michael Vincent Cruz
aliasger yq
Are you a Blueant Radio Communication Expert? Answer questions, earn points and help others
