Question about Averatec 2371 AMD Turion Notebook
Computer does not turn on when I press the power button
I have an Averatec 2300. The green battery klight is on but when I press the on button, nothing happens.
  • 29 Answers
Do u have the power adapter plugged in, or are you using battery power? the first thing i would try is disconnecting the battery. just compleatly remove it and set it aside. then try starting it with the adapter plugged in. sometimes the batteries go bad and are corrupt. i had this happen to a compaq laptop a few years back. after i got rid of the battery it worked fine. if it works u can always buy a new battery.
Posted on Feb 27, 2009
My averatec lap top os stuck in sleep mode
Hi. I suggest you try pressing the power button to wake it up or you could also try power draining it and turting it on. To powerdrain your computer you must remove first the battery and unplug the ac adapter then press and hold the power button for 20 seconds, after that you must place back the battery and plugin the ac adapter then turn on your computer. Hope This Helps
Jun 02, 2010 | Toshiba Satellite M100 Notebook
Averatec 2300 series
Does it feel loose where the power cord plugs in? Did this happen overnight or were there more symptoms?
May 05, 2010 | Averatec 3200 Notebook
Averatec 3150 will not boot. Blue LED blinks
remove the battery and adapter. press power button for 30 sec. then connect the adapter. press power button. if this didnt work. you need to ask for an help of a local tech to check for the video card and cable.
Mar 09, 2010 | Averatec 3200 Notebook
Travelmate 2300 does not boot up ... pressing the power button (with battery installed and with AC adapter plugged in) momentarily starts the internal drive ... then it gos quiet. Power light remains on...
Turn the system off....remove the battery from the system...connect the system to power adaptor ONLY.. the keep pressing the power button for about 15-20 seconds...then try to turn on...check if the system boots... let me know if the system works or not
Jan 15, 2010 | Acer TravelMate 2300 Notebook
Battery indicates full charge but laptop not booting up.
take out the battery if you are comfortable then press the power button continously for 30 sec.put back the battery in then turn on the computer
Jan 06, 2010 | Averatec 7170ec1 Laptop
Averatec 2300
My 2300 started same problems in Dec 08 (almost 2 years old) Its an overheat problem! With black screen the two blue lights an bottom left are on. Leave powered up and in an hour or so will shut down on its on, then will start back up normally but shut down again in about an hour.Correction 1. pull off back cover, blow out the dust. 2.Go to set up (F2 on power up and run fan cal) 3. Take the back cover off you will feel how hot the CPU and hard drive are that is because vents are too small for an aging laptop. Now take the cover and drill a double line of holes on each side of the hard drive vents, Next over the CPU (where the fan blows in air, drill a triple line of new vent holes in the cover). A 5/32 drill will be about right. You may also wish to purchase an inexpensive Belkin laptop cooler. About $19 at Best Buy. This solved my problem as I do like this little one for travel
Glenn New Mexico
Jun 22, 2008 | Computers & Internet
Averatec 2300 laptop will not power on.
The problem is that the computer does not get enough power when you turn it on and that's why it doesn't boot.
Try to put a random CD in it and leave it there for an hour maybe two. By spinning the CD, more volts get through the mainboard. Then shut it down by pressing the power button and then press it again and see the results. If this wouldn't work the first time, try it again.
May 13, 2008 | Averatec 3200 Notebook
We need to determine if the problem is your graphics chip or if the laptop really isn't booting. Do you get any kind of hard-drive activity light when you boot it up?
Start my notebook averatec 2300
hi dear
Ouch! Have you tried taking the battery out to see if it will run on AC power when the battery is not installed? Sometimes a bad battery can kill the system.
Do you have a meter that you can measure the output of the AC adapter with to see if it is correct? If not, any chance you could swap adapters with someone for a while to see if theirs works on your computer and vice versa? A local shop may also be able to test your adapter to see if it's working.
oke
regards, cropp
Mar 28, 2008 | Computers & Internet
It won't turn on!
Flashing green battery means it is in suspend mode. Pushing the power button should bring it out of suspension, however, one of the reasons I deactivate both suspend and hibernate mode is because the seldom work right. I would disconnect your A/C power cord and remove your battery from the laptop. After about 30 seconds plug them back in and your commuter should start again. Let us know how things go.
Dec 31, 2006 | Averatec 3200 Notebook
Averatec 2371 AMD Turion Notebook Logo
177 people viewed this question
Top Averatec Computers & Internet Experts
Rommel Balcita
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
