Question about SanDisk Cruzer Micro 4GB USB 2.0 Flash Drive
Cannot format flash drive
I have an 8 gb genx flash drive. i try to open it andit pops up that it needs to be formatted. i try to farmat it and i get all the way to the warning and click ok and it pops up that "this disk is write protected"
  • 14 more comments
  • gamin_maniac Feb 26, 2009
    i am using windows vista 32 bit on a dell inspiron 1521
    i get the options : eject, properties, and help and there is also change drive letter and paths bot that option is un clickable
    its assigned drive F:
    same prob again it says this volume is write protected
    ive got yahoo and myspace im.
    if you go to myspace.com and go to my profile you can use yahoo messenger on my profile just go to the "ping box"
  • gamin_maniac Feb 27, 2009
    same prob again
    still didnt work (sorry it took so long for a response my internet quit working on me)
    it said path not found. i have an xp at work but its slow as ****. if i cant get it to work here what can i try there?
  • gamin_maniac Feb 28, 2009
    i took the drive to work with me and went into the command prompt and everything and this is what came up: "the type of file system is raw please use the /fs switch to specify the file system you wish to use on this system" any ideas on how to do this?
    thanks ill give it a shot tomorrow and let you know if it worked
    do i type it like this format f:/fs:fat32 or do the file switch and then format or vice versa
  • gamin_maniac Mar 01, 2009
    it still keeps coming up volume is write protected
  • gamin_maniac Mar 02, 2009
    whats an iso file?
  • gamin_maniac Mar 03, 2009
    roxio
    i am actually deployed in iraq right now so it would probably cost a little bit for you to call me but ive got skype on my computer so i could call you but its kind of unreliable at times so the easiest way would be to instant message
    President:
  • 2,653 Answers
What operating system are you using?
When you reply I'll give you specific instructions.
Thanks!
Posted on Feb 26, 2009
  • 10 more comments
  • RescueTechLA
    RescueTechLA Feb 26, 2009
    OK we're gonna fix this problem using an invaluable tool built into Vista and XP. It's called Disk Management.First we need to get inside:
    Accessing the Disk Management console tool
    To access the Disk Management console tool in Windows Vista,
    you can either right-click on My Computer and select the Manage command from
    the context menu or you can access the Run dialog box, type Diskmgmt.msc,
    and click OK.
    Once we're in you'll see a box like this:
    You'll see your usb listed as one of the disks. Pay attention to the size, don't go deleting your hard drive!
    Right-click the disk and then report back to me what options it gives you.
  • RescueTechLA
    What drive letter has windows assigned it? If any.
    i.e. D: G: F: etc.
  • RescueTechLA
    great. now let's get into the command prompt.
    Go to START, Programs, RUN
    in the run box type: cmd
    press enter or click OK
    A black box will pop up
    type this:
    format f:
    If it works, great! If not we might have to add something.
    Let me know.
  • RescueTechLA
    have you got aim?
  • RescueTechLA
    Since you're using Vista you've go to START, Programs, then look for the command prompt this is the administration version.
    Open it.
    type:
    format f: /x
    press enter
    let me know.
  • RescueTechLA
    RescueTechLA Feb 27, 2009
    ok try.
    attrib -s -h -r f:
    press enter
    then format f:
    press enter
    Vista is always a pain to use when it comes to formating these thumb drives. You don't happen to have an xp machine around, do you?
  • RescueTechLA
    Pretty much the same steps, it's just that Vista for some reason isn't the greatest when it comes to Disk Management.
    I used to have a Vista laptop and I'd always run into problems like this with it so I switched to XP but my laptop wasn't supported so I had to deal with a ton of driver issues.
    It's like one problem after another, you know what I mean?
    Finally I got fed up and switched to Ubuntu which has been like a Godsend. Every program is free and open source, no viruses, all of my drivers were automatically detected and installed correctly and it's fast and responsive.
    Once in a while you run into a problem where you have to have XP or another operating system but there's an ubuntu program that let's you create a virtual os within ubuntu. So instead of dual-booting, I can use XP and Ubuntu at the same time and even share files between the two operating systems. It's really cool.
    OK but as far as your problem goes let's just go ahead and try using your XP machine at work to format the drive.
    Try formating the way you did before. In the meantime I'm going to throw a virtual copy of Vista on my machine too so that I won't forget how to use that stupid OS.
    Talk to ya soon,
  • RescueTechLA
    RescueTechLA Feb 28, 2009
    you've got to add this to it
    /fs:fat32
    that will do the trick!
  • RescueTechLA
    format f: /fs:fat32
    just like that.
  • RescueTechLA
    RescueTechLA Mar 01, 2009
    Do you know how to burn iso files?
  • RescueTechLA
    RescueTechLA Mar 02, 2009
    What program do you use to burn cds on your computer?
  • RescueTechLA
    RescueTechLA Mar 03, 2009
    OK great.
    Have you heard of Knoppix before?
    It's a live linux cd.
    Basically what we're going to do is download and burn a copy of the program.
    Afterwards we can boot your computer from the disc we made (it's independent of the hard drive so it won't affect anything)
    Then we'll take care of that pesky thumb drive once and for all.
    Go HERE
    There are a ton of places to get it, just pick one of the HTTP sites that's in English and close to you.
    They're all pretty much the same. We just need to download the ISO file that's named like this:
    KNOPPIX_V6.0.1CD-2009-02-08-EN.iso
    Try this direct link first.
    If that doesn't work just find the above from any of those sites listed.
    Once you've downloaded the file, it's about 650mb so it will take a little bit of time, open Roxio and see if you can find something that says, "Burn Image File"
    Then point Roxio to the file you just downloaded.
    Then burn.
    Afterwards email me @ rescuetechla@gmail.com I'll email you back my phone number ( or email me yours- I've got free long distance) and we'll finish over the phone so it's easier for both of us.
    Brigadier General:
  • 3,614 Answers
Here HOW:
THIS & THIS
further more instructions let me know
    Guru:
  • 832 Answers
Hi! thanks for using fixya.com!!!
I had the same problem before, from my side I tried so many times and so many attempts...
but you know, what I suggest that if its still under warranty it is better to return it to your dealer and tell them the problem...that's the same thing I did...Or just buy a new one...
Good luck!!!
Genx pe4ndrive.when I insert in lap top click to open it is displays not formatted.when I clic formatting button it is displayed that i will loose all memory of pen drive it's data.
Try it on an other computer... if that fails, it might have developed bad sectors (spots) reformat and do a scan, which writes and reads all memory locations... might be corrupted and/or broken, but try another computer first to make sure it is not a driver issue.
Dec 13, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
My genx flash is write protected
My Genx 8 GB Flash drive corrupts data and has very slow speed pls help me to fix it
Dec 02, 2010 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Mi pen driw not farmated
My pendrive not open and do not formate, but how can i do this formate?
Nov 26, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
How to remove write protection from usb device
i have genx 4 gb usb 2.0 how can i format this drive...i will try for formating but showing write protect message,,,
please give me the solution
from bijoy dubai
Apr 08, 2009 | iLO (2 GB) MP3 Player
I bought a brand new flask disk of 1 GB, USB 2.0 genx. I gave a friend of mine to download my photos onto it from his laptop, a FUJITSU. The space filled up so quickly, so he deleted the files that were...
Hi!
You can try to format the flash drive first. Go to My Computer > Right click the flash drive and select Format. Once the format window opens, select Quick Format and click START. Please note that formatting your flash drive will wipe out all data.
I hope that helps.
Have a nice day!
Nov 21, 2008 | Computers & Internet
How to formate my disk devices
I've GENX flash disk 2GB, I forget my password for Carry It Easy program, Now its capacity only 14.8GB, What can I do to fix and reformat.
Oct 14, 2008 | Electronics - Others
Flash disk displays No media in disk management.
format and see
plus try uisng on some other pc /device to confirm the defect.
u get replacement fm kingston as it has 5 yrs warranty
Jun 22, 2008 | Kingston flash memory card - 256 MB -...
SanDisk Cruzer Micro 4GB USB 2.0 Flash Drive Logo
65 people viewed this question
Top SanDisk Electronics - Others Experts
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
