Question about Dryers
Dryer will not turn on
There is power to the start button, it makes a noise like it wants to start but it doesn't. The dryer door switch seems 2 b working any clues?
  • Dryers Master
  • 8,220 Answers
Get someone to hold in the door switch mechanism while you push the start and turn the drum to get her going. If it runs their may be a chance you can replace and/or oil wheels, slides, and idler. If not then motor replacement is emminent.
Posted on Feb 26, 2009
Dryer makes a buzzing noise when I turn it on but it doesn't come on, just buzzes.
Open the dryer door and slowly rotate the dryer drum in a counterclockwise (CCW) direction. Rotate the drum 2-3 revolutions and then shut the door and see if it will start. If it continues to just hum and not start could indicate a voltage issue, motor issue or a friction issue. Open the door again and locate the door switch plunger in the upper or lower corner on the hinge side of the drum opening. Hold the plunger in while someone begins rotating the drum counterclockwise. While turning the drum counter clockwise and holding the door switch plunger inwards press the start button. If it starts, there is likely a friction problem or motor problem.
What is the model number?
Nov 06, 2012 | Dryers
Makes a humming noise but doesn't turn
Try this, open the dryer door and hold down the door light switch. Turn on the dryer and press start.When you hear the motor humming, turn the drum clockwise with your hand to see if it will turn. If itruns, you have a bad motor and will need to be replaced. If it doesn't turn, something is jammedinside and you will need to disassemble the unit to find the jam.
Hope this helps.
Oct 31, 2011 | LG DLE2514 Electric Dryer
Fridgidaire dryer aeq6000es. won't start, beeps 3 times with error message dr
Hello
This code means the dryer door is not closed or the door safety switch is not making a good connection at times. The dryer door safety switch is in the opening of the door and when the door is closed the switch button is depressed. If the control circuit board doesn't get a signal that the dryer door switch is closed it will not allow the dryer to start.. Try firmly closing the dryer door a 2nd time when this happens, if that cures the problem you are good to go, if that doesn't cure the issue you must remove the front panel of the dryer and replace the switch. If you need a switch they are available from Sears Direct for about $15.00 Below is a picture of the switch that most likely used in your model and make, the button on top is what the dryer door depresses when closed..
Jul 12, 2011 | Dryers
Kenmore 80 series electric dryer Model - 110-60882990 The dryer won't turn on. Once the start button is pushed it makes a single clicking noise. If I open/shut the door and push the start button...
check the actual door switch,, you can jumper it to see if this is the problem, Just connect the 2 wires together , if this cures the problem replace the switch
May 25, 2011 | Dryers
Push button to start but it does not turn on. only a small noise and then fails to start.
I would take off the back cover or open it up, close the door, then use insulated tool to make across wire terminals. Just tap across the wires if the drier starts its the switch. If not check the drier door switch to make sure it is passing power to the push button switch. Let me know and good luck
Mark
Feb 07, 2011 | Kenmore 62602 Electric Dryer
The dryer wont show any sign of power. The plug works fine
Press and hold start button for 4-5 seconds.Make sure that the start button has been fully pushed down or turned far enough to activate the dryer.
After that plug something else into the same outlet. If it works, you know you have power to the dryer. If it doesn’t work, you’ll need to check for any blown fuses or tripped circuit breakers.
If the power is there, you need to check door switch, thermal fuse, thermostats, and start switch to see if one of these is faulty.
Make sure that the control settings are appropriate, and that any buttons are fully depressed.
Good Luck and have a nice day.
Jun 21, 2010 | Frigidaire Electric Dryer
Kenmore 64112 dryer wont start when I hit the start button
Check house fuses or circuit breaker.
Pull 220V cord from wall outlet and inspect the gold prongs.
If you see any burnt areas on the prongs the outlet is bad.
If the unit makes no noise when you press the start button check the dryer door switch and make sure it clicks when depressed.
Sometimes the door switch arm can break off so when the door closes
the door switch cannot be activated.
If you hear a growl noise when you press the start button 2 things...
1. The motor is bad and needs replacing.
2. An object fell down the lint trap and is preventing the motor from turning.
Also if the dryer vent has been plugged causing the dryer to over heat a saftey fuse may have blown and needs replacement.
Jan 16, 2010 | Kenmore 64112 Electric Dryer
My dryer doesn't run
If the dryer doesn't start or make any noise: 1) Be sure it is plugged in and turned on. If necessary, check the receptacle it's plugged into for power, using a working lamp, appliance, or voltage tester. Be aware that most electric dryers don?t plug into standard 120-volt receptacles?they operate on 240 volts. Make sure the door is closed completely, the timer is advanced to the proper position, and the correct cycle is selected. 2) If the receptacle is dead, check the circuit breaker or fuse that serves that circuit. 3) Unplug the dryer and check the power cord and the terminal block. If necessary, replace the cord. 4) Open the door and check the door switch. Press and release it: it should click each time. If it doesn't, it's probably broken. If you're experienced at home repair, you can remove the switch, test it, and replace it if needed; otherwise, call an appliance repair service. 5) If the dryer still doesn't work, a thermal fuse or other electrical or electronic parts may be faulty. Call a service person.
Jan 18, 2006 | AEG T57800 Electric Dryer
Dryers Logo
Top Dryers Experts
