Question about Yard Machines Tecumseh 148cc Front Tine Tiller #21a 251e000
I need a tecumseh small engine repair manual for a shredder - chipper made by MTD
  • George Mar 01, 2009
    Thanks Mrdixit-jerr :: Got my manual::
2 Suggested Answers
backwoodsctr
  • 169 Answers
SOURCE: Repair Manual
http://www.smallenginesuppliers.com/html/engine-specs/tecumseh-engine-specs.html......
this is where i go for parts breakdowns and service literature.......hope this helps.!
Posted on Nov 19, 2009
Is it hard to change a magneto on a 5.5 hp Tecumseh engine?
How old is the gas in the tank? If it is older than 2 months drain it out and put in fresh gas and try again. Have you seen spark jump across the spark plug gap? To check for spark I use a spark checker. One end goes to the plug and the other to the spark plug lead. If you have spark you see a light flash which is more easy to see.
Sep 16, 2014 | Tecumseh Engine 5.5hp Horizontal OHV MTD...
Have an MTD Chipper-Shredder Model 462B 5 H.P. lost the spark plug. What size do I need?
That model number is not helpful. I need the full model number on the manufacturer's label. Or even better, the full model number on the engine (separate label from the one for the whole machine). Need the make of the engine if you can find it. I have a Craftsman (that I think may have been made by MTD) that has a Tecumseh engine. But it was not stated on the machine, I had to find the brand by using the model number for the whole machine and looking it up from there to find the maker. If it is a Tecumseh engine, the label will be low and left on the engine shroud as you are looking at the shroud, spark plug points up.
If you can give me the label plate data, for both labels, then I will be able to tell you what the spark plug should be.
Sep 08, 2011 | Mtd Garden
Need new air filter for a tecumseh shredder chipper 10 hp
You can look up the air filter with the model number and order it over the internet from a website such as partstree.com, but there are others. Or, you can get the model number and go to your local small engine repair and parts shop. Mine had it on the shelf. If your chipper/shredder is like my 8 HP Craftsman with a Tecumseh engine, then as you are looking at the engine, look on the left side of the shroud or cover and way down low on the curved portion is a label with the model number on it.
I hope this is helpful for you.
Aug 22, 2011 | Tecumseh Heavy Machinery
I have a Yard Machine chipper shredder with a tecumseh motor with the 3 way feeding system ... I need the gas tank for this machine ... any idea where to find one?
If you have the same 8 HP Tecumseh engine that I do then if you look at the the engine, squat down so that you are looking at the recoil starter, then look for a label on the left side of the shroud (cover) down low and you should find the model number of the engine. Record that number and send it to me so I can check it. After I check it I will tell you what website to go to in order to order it or how to get the part number so your local small engine repair shop can order it for you. You can also just take the engine model number to the local small engine repair shop and tell them what you want to order and they should be able to get it for you.
If you go directly to the local shop, I hope you get it going soon.
Aug 05, 2011 | Yard Machines Electric Chipper/Shredder
Have a Troy-Bilt Chipper/Vac model # 47282 5hp sp, the Carburator needs to be replaced, I cannot find a part # for it, or where one can be purchased, please help
I believe the carburetor part number for your model is 632631. I have the same TroyBilt chipper/Vac. It has a Tecumseh H50-65582W engine. A good parts diagram can be found at
http://www.outdoordistributors.com/pdf/Tecumseh/TECUMSEH-MODEL-H50-65582W-PARTS-LIST.pdf
If this is the right part, you can buy it at Jacks Small Engine parts for $79
Good Luck!
Dec 12, 2010 | Troy-Bilt Chipper Shredder
Need owners manual for 2001 yard machine chipper schredder model #24A464B131
I have a operator's manual for 24a 463b129 5.5 hp. I also have an operator's manual for the engine (Tecumseh). I purchased the chipper new from Home Depot back in 2002. I think you will be disappointed at the lack of information. If still interested, e-mail me your e-mail address, and I can send you a PDF copy of these manuals. (wchan@bushbros.com)
Mar 27, 2010 | Yard Machines 24a 452g729 5.5 Hp Chipper...
I want to change the oil on my Yard Machines snow thrower with a 10hp Tecumseh engine and can't find the engine manual. What kind and how much oil should I use? Thanks - Zelmo
Zelmo use 10w30 weight oil and just put in enough to reach the full mark. In an air cooled engine I highly recommend you use Full Synthetic oil. It performs much better than conventional oil in an air cooled engine. Change the oil once a year.
Dec 31, 2009 | Yard Machines 24a 452g729 5.5 Hp Chipper...
Oil? Gas? Additives?
Small engines like to see SAE30 oil. This is assuming a 4 stroke engine of course (if you have an oil filler spout and dip stick you have a 4 stroke engine). Use regular unleaded gas, and personally I mix STA-BIL into ALL of that gas I use with my small engines. I have too many carburetors to take the chance of needing to rebuild them in the spring.
Manuals for MTD products are here: http://manuals.mtdproducts.com/mtd/public/list.jsp
You will need model and serial numbers
Apr 27, 2009 | Mtd Heavy Machinery
Yard Machines Tecumseh 148cc Front Tine Tiller #21a 251e000 Logo
1,366 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Phil Walker
Phil Walker
Dean Gruber
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
