Question about Cyberhome CH-DVR1500 DVD Recorder
Can't load disc
Ch-dvr 2500 loading door will not open. tried recycling power, no help. display shows OPEN, or READING but door will not open nor will it 'reject' what isn't in there.
  • shellyicurn Mar 21, 2009
    The door won't open unless I push the button several times.
  • Anonymous Apr 25, 2009
    removed screws - but the disk drive is enclosed and cannot see any gears -- did dust carefully around the disk drive enclosure - but I believe that it is a defective drive as it alternates between "no disk" and "open" and "reading" -- nothing to do with the gears. I hear a thunk and when i opened the case I was able to open the drive 2 x -- but not when i had to put it back in the top and back body. it plays pal disks which I just got from abroad. Solution is to try and buy a replacement on Ebay -- forf another 200 -- bummer.
    Scholar:
  • 85 Answers
As there is a small gears on both the sides of the door which gets a command to spin when you press the eject button as that gears are either worn out or got craked internally or are getting blocked due to any dust collected in between .if cracked or worn out replacement is necessary.but if got blocked due to dust particles just will have to open the unit by removing the screws from its top and back body and then cleaning the gears which will be easily seen internally.
Posted on Feb 26, 2009
Bang & Olufsen Beosound 3200 CD Door won't open
Could be the PCB9 light and motor control have the problem its on the upper left side of the player.
Feb 25, 2013 | Audio Players & Recorders
On my CH-DVR 1500 THE TRAY WILL NOT OPEN AND THE MESSAAGE LIGHT STAYS OFF FOR A LONG TIME , THEN IT READS-READING. GOES FROM REAADING TO OPEN. AALTERRNATES FROM OPEN TO REAADING AND NEVEER DO OPEN,...
Hello
There are two fault possibilities for this problem. Both are not user reapairable. The first one is of 'sled' motor. Sled motor is one that spins the DVD disc inside the DVD mechanism. If it fails to rotate the disc, the laser reading assembly cant get any signal from the inserted disc and will show "Reading" display on the front panel for a long time, and finally stops. The second one is of Laser Pickup Unit Assembly itself. If it has got damaged, there will be no laser beam to scan the DVD inserted, and the same thing as described above will occur. In both cases the final displauy will be "Open". To replace both items, you have to take its mechanism fully outside and to disassemble it. It is really a skilled work. It is best for you to get it repaired by any experienced service technician you know very well, or get it repaired by any authorised service centers. OK.
Jun 02, 2011 | Cyberhome CH-DVR1500 DVD Recorder
Motorola dvr dct6412 locked channels
Check with your provider to ensure that you are in expanded services, or limited. Because being on limited services the box will lock you out of those channels. If you are in billing for those services and you checked the batteries on your remote and they are good and you get a solid red blink when you change channels not a double blink (indicating that your batteries are dying), Then try power cycling your DVR by, removing the power supply and waiting 3sec then plug it back in. Your box should shut off, turn itself back on, then go into the load screen, then, once the load screen display shows on your tv and on box display, wait for your box to completely load (don't touch nothing until the correct time shows up, meaning that it has completed the load process) Once the process is complete turn box back on and you should have you guide back up and (No Data) on your program schedule(Don't Worry!!) it will populate, with 15-20 mins.
Now try to ch. up and down and see if that fixed the problem. also make sure nothing is blocking the sensor. If all else fails and you changed the battery, called your cable provider and request a box swap, (be sure to watch all your recorded shows because they go bye, bye with the cable guy!)
Sep 22, 2009 | Arris DCT6200 DTV Receiver
Cyberhome dvd 1600
unplug the unit and wait 5 minutes and plug it back in. See if that helps
Oct 21, 2008 | Cyberhome DVR 1600 DVD Recorder
"LOAD" Showing on the display
Exactly the same problem myself. Try pressing open and then holding tight to a cotton bud, sweep inside the machine. The problem seems to be dust collecting. If it works then get a proper cleaning disc. My problem got so bad that the machine would spit out most discs as unable to read.
May 16, 2008 | Samsung DVDR120 DVD Recorder
Not reading any type of cd or dvd
I am French I can tell you that the repair of the lens is very costly. It is practically the price of nine. Guess ...
€ 250!. On the coup's my agitated. Decevant it from yamaha. Both buy another home cinema.
Dec 08, 2007 | Yamaha DVR-S150 DVD Player
After loading every disc displayes "wrong disc'
are they bootleg dvd's? if not try getting a lense cleaner because wrong disc means it's reading your dvd's as .mov files which only play on quicktime in a computer. if it reads your cleaner as wrong disk too then get yourself a refund cuz it has a motherboard malfunction.
Dec 02, 2007 | Cyberhome CH-DVD 300 DVD Player
The drawer on the unit won't open.
When the DVD player is plugged into power and switched on, and won't power up (nothing shows up in the front display panel), the power supply unit in the DVD is blown. the noise that player made was probably a capacitor going off. You will have to get the unit repaired.
Jul 28, 2007 | NexxTech DP3222 DVD Player
Froze at "Reading"
If you are lucky to have a normality relapse, maybe after resting the DVD recorder for a while, you could try 2 firmware updates found here - http://support.cyberhome.com/support_web.nsf/All_Docs/?SearchView&Query=(DVR%201500)%20AND%20(Downloads%20and%20Updates)&Start=1&Count=10 But theres a 99% chance that you're stuck in the initial setup mode(have you just puirchased it?) - if you wish to skip this setup press- > enter > return > enter - on the remote panel, make sure to press every button only once. If you wish to go through with setting up the date/time etc, then follown the instructions in this addendum to the manual: ftp://209.237.61.78/cyberhome/1500/manual/1500_add.pdf Good luck
Mar 27, 2006 | Cyberhome CH-DVR1500 DVD Recorder
Open Questions:
See all Cyberhome CH-DVR1500 DVD Recorder Questions
Cyberhome CH-DVR1500 DVD Recorder Logo
119 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
