Question about Dynex Wireless-G Broadband Router
Dynex Wireless G Router
Will you experience problems with this router if its not hooked up directly to your laptop? I like the portability of the laptop. I no longer need to be attached to my desktop since I becamed wireless with the laptop. I've been losing my connection to the internet. I've worked with my provider, testing their modem, whick is working. When I unplug the router from the modem and attach the modem directly to my laptop, I get connected Any ideas? Thank you.
  • 611 Answers
Check the configuration of the router then re-configur the router it
Posted on Mar 03, 2009
My computer is not connecting to my Dynex wireless router. I've called my locate cable subscriber and they told me that it's a router problem. I've disconnected the router several times and it shows that...
First off, verify that you can connect to your cable modem directly. After that, hook up your Dynex wireless router and reboot your cable modem. After this, directly connect your computer to the Dynex router (using a cable). If you cannot get an Internet connection, then there is some issue with your Dynex router configuration. It's possible that there might be an IP address conflict with the cable modem. It would be best to contact support for configuring the Dynex.
If you can connect to the Internet with your computer connected directly to the Dynex router, then there must be some router configuration problem affecting your ability to connect wirelessly. You'll have to check the configuration--might be a good idea to completely reset the router and start over. If that doesn't help, you should contact Dynex customer support, as each router has its own configuration specifics. Good luck.
Nov 07, 2010 | Computers & Internet
With the router hooked up getting on the internet is slow. hooked to cable one direct it's o.k.
Your Wireless speed is all down to the quality of the router and wireless card, and where you are in relation to the router.
Hooking up direct is always going to be faster.
You could experiment with the position of the router in the room.
Check your speeds wired and wireless, use www.speedtest.net.
You could buy a better antenna for the router
Aug 25, 2010 | Linksys WRT160N Wireless Router
Looking to hook up wirelees router
You should have one plug that is marked WAN - this connects to your modem with a standard Ethernet cable. If you cannot read the labels, it will be the plug, slightly removed from the other four plugs.
You need to connect the power adapter to a power strip to avoid unnecessary power entering your network and to protect the router.
You should be able to start the router without a PC attached. Just look for Dynex being broadcast wirelessly. Your network is not secure wirelessly until you add a password to the network.
See if you can get to fixya.com from your laptop. If so, things are going pretty well. You now want to add security to the wireless network.
Write back if you need help.
May 24, 2010 | Dynex 4-Port Ethernet Broadband Router...
Computer cabled to Dynex enhanced G wireless will not connect
Unplug the router for ten seconds and plug it back in, it needs to reset. Some routers have a reset button. I often wait longer than ten seconds, I find a beer is usually the right amount of time. Sometimes the modem needs a reset also; unplug everything, then plug back in sequence, with the modem first, the wait, then the router, wait, then turn on your computer. That system works for any brand modem and router.
Jun 09, 2009 | Dynex Enhanced-G Wireless Broadband Router
Dynex Router problem
try to reset your wireless router...look for the reset button and press it with a small pin for at least 10 sec. see if it will recognize the router after reseting...
Apr 06, 2009 | Dynex 802.11g Wireless-G Laptop Card
Laptop cannot find access of newly installed dynex G Router
Follow the tip I prepared
Find the radio swith on your Think pad and activate it (model?)
try FN + F5 to activate the radio config.
Be sure radio is ON.
Before every radio test check your internet configuration connecting to router with LAN cable and browse.
Jan 08, 2009 | Dynex Enhanced-G Wireless Broadband Router
Wireless signal keeps dropping/dissapearing
Check my tip
Using Router and Wlan adapter from different brand (Dynex + Belkin) is sometime calling for trouble: you must configure both to be sure to be on same standard (or change Both).
I'm using Netgear + Belkin and tune is not easy
On router config check radio power, reduce the used standard (B/G A/N) to the only one used by Belkin adapter (N).
Be sure you removed Windows zero wireless configuration (= use windows to manage my connection= OFF)
edit your belking wireless networking utility to automatic reconnect:
try downgrading to G standard from router side
Check your network connection plugging your laptop to router via lan cable.and check network params (DHCP DNS etc.).
Then check wlan connection near router, if you experience wlan drops only when far from router, find any possible interferences source (Microwave, cordless, remote) remove it or be ware you cannot have wlan when your wave is working.
Dec 13, 2008 | Dynex Enhanced-G Wireless Broadband Router
Want to hook laptop up to home computer via cable modem
You need a router or a wireless router to do that.
If your cable modem is wireless you can set directly via wireless network a connection with your laptop (the laptop also need a wireless card (if dont have any built in))
The connection must be done in this way
ISP ----->> Cable Modem ---->> Wireless Router o Router ----->> Computer ( 1, 2, or more)
Nov 19, 2008 | Computers & Internet
Wep key for dynex router?
put new router dynex good signal no internet on laptop
Sep 27, 2008 | Dynex DX-E401 Router
Need help with best connection type for college student in dorm
The enhaced version just give more range of signal over the normal dynex, regarding the internet provider it depends because sometimes you'll need a password and user to connect to the wireless signal. The dynex is used to connect from a cable signal (RJ-45)internet and then it will transfer the connection to wireless so it can be use from any laptop with wireless connection. So for example you DSL internet connection is a cable (RJ-45) then you connect that cable to the dynex router, then the router will automatically transmit the signal to wireless so any nearby pc can connect to it. If the laptop doesn't have wireless, then you'll have to buy a card to be able to connect to wireless signal or you could by also a (RJ-45 straight-through cable Cat 5e) to connect from one of the ports from the DYNEX to the laptop. Hope it helps.
Aug 19, 2008 | Microsoft Xbox 360 Console
Dynex Wireless-G Broadband Router Logo
154 people viewed this question
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
