Question about Sony VAIO FRV28 Notebook
The 'A' key came off my VGN-FZ140E keyboard. I can't get it back on. Two small interlocking plastic parts are on the back of the detached key. These parts appear to need to snap into position on the keyboard. Suggestion would be appreciated.
  • ftsc Apr 10, 2009
    I found that the two interlocking pieces of plastic should be positioned at both sides of the verical rubber holder that carries the key. I used two pairs of tweezers, one to keep up the key while it is attached to one of the pieces of plastic, one to bring the second piece in the correct position. If it fits, apply subtly some pressure on the key and it snaps!
    C.A. de Feyter
  • 78 Answers
Take extra care with these clips since they are very fragile however you just need to push the key in a swinging motion in order to snap it in. dont apply too much pressure though.
Posted on Feb 26, 2009
How can I import digital pictures from my digital camera when I get an error saying that thwere are no pictures to import
maybe the files are hidden. You need to check -show all hidden files. What windows version you are currently using?
Mar 05, 2015 | Sony Vaio Vgn-fz140e / Vgn-fz140e/b /...
Can you tell me where the cmos battery is located on my sony vaio laptop model PCG-384L; VGN-FZ140E
If it is not where you can see a slot on the side or back, I would bet it's under the keyboard. The Sony support page may have the answer.
http://esupport.sony.com/US/perl/index.pl
Jul 24, 2011 | Sony VAIO® VGN-CR190E/W PC Notebook
Sony VAIO VGN-FZ140E FZ does not turn on after spilling water on keyboard.No lights at all.
you have probably fried the cpu and motherboard. buy a new machine or claim on house contents insurance. it'll be in excess of £500 for parts.
Aug 02, 2010 | Sony VAIO FZ Series VGN-FZ140N/B Notebook
I need to know how to replace the keyboard on my Sony Vaio VGN-N320E. Can't seem to find the springs to unlatch the keyboard
You can't replace the keyboard of the laptop by yourself. Take a help from expert engineers or Service center experts.
Revert back for more assistance.
Feb 02, 2010 | Sony VAIO VGN-N320E Notebook
A key came off the keyboard
Hi eugpol,
Typically, the keys either have a small cross bow type of connection, or they some just snap back on. Look at the back of the key, if it has a round cylinder type configuration, then you can place the key back in it's position and with your fingers, just ad a little pressure until it locks in place.
Now if it has a cross bow configuration, when you look under the key, you'll find two plastic pieces that interlock with each other. What you do is hold the key face up, and sort of tap the sides to get the two plastic pieces to drop. On one of the plastic pieces you'll find two snap in ends. And on the other piece you'll find it's more of a circle that has a snap in bar across the top of the circle. The object here, is to take the one piece that has the two snap in ends and look on the keyboard, you'll find two teany tiny circle holes that those little ends go into. Plug those in first, then on the other side you need to snap the bar end up and back to snap it into place, and your done. It may take a couple of tries, but you'll get it.
Good Luck, and don't forget to leave a rating.
Mark
May 01, 2009 | Computers & Internet
How to change the keyboard on an acer sapite 5612z? Or the bezel part - the plastic strip above the keyboard which hide the 2 screws for the removal of the keyboard. Please, help. It's driving me mad...
you can detach the plastic strip with a very small screw driver.no screws to be removed because they are just clipped together. just be careful to avoid breaking it. after opening it remove also the ribbon cable connecting the keyboard to the motherboard
Oct 16, 2008 | Acer Computers & Internet
Key for keyboard on a sony vgn a417m laptop
its not easy ,,,but you have to look at the spring assembly and see how it works,look at the bottom of the key button and see how it attaches.Once you figure that out and get it set right you just press it into place.Sometimes you can look at one that is still connected to the keyboard and see how its hooked up and that may help reassembling it.
Apr 19, 2008 | Sony VAIO VGN-N130G/W Notebook
Removing the hard drive to a Sony VAIO VGN-S660PNotebook?
On this line of Sony models replacing the hard drive is a pain because the computer must be taken completely apart to get to the hard drive. It is located under the palm rest. I looked up the Sony manual for this model and it does not show how to replace the hard drive -- meaning it should only be done by a trained tech.
You'll have to remove all the screws from the bottom and underneath the keyboard. Carefully detach the keyboard and set it aside. Once all the screws are remove from the laptop you should be able to separate the top of the casing from the bottom, this usually requires a small amount of force but too much force will crack the plastic! Underneath you will find the hard drive cage.
Also, some laptop vendors like to pull the 'hidden screw' trick! There may be a screw underneath the CD-rom drive so that may have to be removed or under some of the rubber feat on the laptop.
I couldn't find a photos or manuals that show how to do this, but these guys say they have a manual for a small fee. http://www.9manuals.com/Vaio2.htm
They want $5.99 for the manual but that is much cheaper than paying a technician to do it for you.
Good luck and be careful!
Nov 13, 2007 | Sony VAIO® VGN-S660P/B PC Notebook
Sony VAIO FRV28 Notebook Logo
215 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
