Question about Acer Aspire 1802WSMi PC Notebook
Arcade loading dvd
I load a dvd and it appeadr to move frame by frame with no sound.
  • 1 more comment
  • martin_c Feb 26, 2009
    I am using the arcade button on the front face.
  • martin_c Mar 01, 2009
    The Computer is only 4 years old and designed to have dvd player, it has an Aspire Arcade button on front of computer face
  • RescueTechLA
    RescueTechLA May 11, 2010
    Which program are you using to play it?
  • 80 Answers
Not enough power from your pc! you need a better pc!
Posted on Feb 26, 2009
I have a husqvarna122 HD 45 hedge trimmer and it will not stay running it is wide open all the time the only way to keep it running is to run the machine at 3/4 Choke. when running the machine sounds like...
While not being familiar with your machine, there could be several causes, the first that comes to my mind, based on your analysis ["...sounds like it is under load."], is that there IS SOMETHING CAUSING the system to "BE UNDER LOAD"!!!!!
Now, considering what could cause such a load on the system THREE things come to mind:
  1. An ACCUMULATION of trimming DEBRIS has gotten between the cutting blade and its support frame, causing the blade to severely bind / "drag"!, or
  2. The bolts or screws holding the cutter blade and its NON-moving support frame together have been OVERTIGHTENED, or
  3. A bearing, or bearings, in the engine are failing and are beginning to seize.
  4. On some machines, the connection between the engine and the blade involves an eccentric arm, with a BEARING. IF that bearing is beginning to fail, and thus seize, that could be the cause od the "unknown" extra load.
Aug 23, 2014 | Garden
SYNCANISATION OUT
It sounds as if the software is 'dropping frames'
Video consists of 25 frames per second. When capturing video, the computer has to read and compress each frame in real time. If your processor is not fast enough, it cannot keep up and will drop frames.
The problem is it only drops the video frames, not the audio frames, so over time the picture and sound go out of sync.
Make sure your computer meets the minimum specs. for the software. Also close any other programs that are running as this will lighten the load on your processor. If you've got loads of icons in the lower right-hand corner of your screen (these are all progrmas running in the background) close as many of these as possible as well.
Hope this helps,
Matt
May 01, 2010 | Pinnacle Dazzle DVD Recorder
No volume with dvd on acer arcade or windows
If there are no hardware issues most probably the following are the reasons:
1. Check whether the Media Player sound is not muted. 2. Check whether the systems sound is not muted. 3. If you encounter sound problems only with dvds most probably there is no driver issue, but there can be a codec issue, install the latest version of media player and if possible install a better dvd player software. Google AVS DVD player a freeware.
Mar 22, 2010 | Acer Aspire 8920-6048 Notebook
Philips lx3600d dvd surround home theatre system dvd player fault
when the dvd is inserted it shows up no disc so it is not loading
Jan 09, 2010 | Philips LX3600D System
Game stops loading new wolfenstein,store gave me another but same problem
Sounds like that your 360 dvd drive is going to break any moment....try to test with another 360 dvd drive, or buy and change a new 360 laser unit ...
http://www.diytrade.com/china/4/products/4807803/XBOX360_xbox_360_Laser_Lens_SF-HD63_SF-HD67.html
Sep 11, 2009 | Microsoft Xbox 360 Arcade
Arcade umplugged volume 1 wont play
i think iv had this one you put disc in then when its loaded goto arcade menu and i think the games are there rather then reading from disc
May 09, 2009 | Microsoft Arcade Unplugged Volume 1 for...
RE ACER ASPIRE 5735 No sound on DVD
You need to play DVDs through Acer Arcade. To do this you can turn off autoplay (use help function), or assign Acer Arcade to automatically play DVDs. If you still want to use Windows Media Player to play your DVDs you must uninstall Acer Arcade.
Jan 11, 2009 | Acer (91.AB193.021) Modem
Trys to load and skips from frame to frame
i would try and take off top cover then using q tips to manually clean the lenses dont worry about the laser it is made to move in all directions so go ahead and apply slight pressure when cleaning i usually use a wet one then a dry one to asorb excess moisture.
C
Oct 29, 2008 | Samsung DVD-V3500 DVD Player/VCR
Polariod tv flu 324 25a
i have a polaroid tv dvd cmbo and the dvd will not load a moving indicates it is loading sounds like it's loading,but nothing happens can yu help?
Aug 15, 2008 | Polaroid FLM-323B Television
Acer Aspire 1802WSMi PC Notebook Logo
26 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
