Question about Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping
Lazer 73: blower making a lot of noice
My heater is about 12 years old. It has never been serviced. Lately it has been making a lot of noice, particularly when it first starts up. A load hoarse whirling noice. Once it is running, the noice pipes down to just a loud, steady vibration sort of racket.I know it needs to be rebuilt, so what should I order for a complete rebuild? Can the bearings be replace in the blower, or do I need to replace the entire motor. The circulation fan seems to be fine.
  • g_m_urban1 Feb 27, 2009
    Sounds like Tom is smack dab on the money. Thank you. Mike U.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 126 Answers
G M,
Your stove does need to be overhauled. The vibrations are the blower exhaust wheel being out of balance due to carbon build up. If it has been vibrating for a long time you will need to replace the motor. The L73 motor bearings are hard to get off without either bending the shaft or breaking the rev sensor. The burner pot will be another part that may need changing. It may have a warped or cracked bottom. If this is so it needs to be replaced with a new one. The burner ring will have to be replaced as will the mat. Several gaskets will need to be on hand in case you break them. All toll the above will run around $400 or so. It's well worth it considering a new one is $1750 or so. The first thing you need; though, is a service manual. Get in touch with your local dealer and get one. It will make your repair much easier.
Tom Hawkins
hawkins111@gci.net
Posted on Feb 27, 2009
Do you know if they sell a replacement for the front louvered grill in the lazer 73? Mine is damaged and I removed it from the frame and need a new one.
Parts are available. Contact Valley Power Equipment, Customer Service Dept 1-877-360-3507
Monday - Friday 8am - 5pm ET, Saturday 8am - 1pm ET .
Hope this helped you.
Jul 01, 2011 | Rinnai Toyostove Direct Vent Heater:...
My lazer 73 is giving me a fan motor error code (EE 8) but I think my fuel pump might be out also. before I take apart the whole stove; is there a way to diagnose the fuel pump?
The fuel pump will make a loud thumping noise if it isn't getting any fuel to it. You can use a long screwdriver like stethoscope and listen to it to see if it is running. It won't start until you see the burner lights come on (about 3 minutes after you turn it on). There is a way also to hook 120vac to it with the fuel line off, but I will have to put that on here tomorrow after I look at one. As far as your fan goes, either take the exhaust hose off the back or remove the front and remove the black rubber boot from the blower motor (easiest). Then use your finger or a pencil and reach in and try to turn the fan. You may hear a slight crunching sound from carbon breaking loose. Keep turning until it turn free. You can use a shop vac to clean some out.
Jan 18, 2011 | Rinnai Toyostove Direct Vent Heater:...
It saying ee8 blower on da laser 73
EE-8 is for a blower motor malfunction. It could be due to carbon build up on the exhaust fan blades. Remove the front cover of the heater. Now locate the blower. There is a black rubber boot that goes from the bottom of the heater to the blower. Remove that boot. Use your finger or a pencil or whatever to reach in the hole and turn the fan blades. You may here a crunching sound from the carbon breaking up. Turn it until it frees up. If it turned freely to start with, you probably need a new blower motor. If it was hard to turn and you free it up, you will probably be OK.Let me know what you find. I have a used blower for a Laser 72 that should work for your Laser 73.
Dec 31, 2010 | Rinnai Toyostove Direct Vent Heater:...
My puppy ate the room temperature senser off of my toyostove lazer 73,could you help me with where i can find one online or else where?thanks,carolyn
If the dog Just chewed the wires you can splice them back together
But if you need a new one I can Mail you one.
Call me
Total Toyo
(907) 488-9179
Good Luck
Dec 12, 2009 | Rinnai Toyostove Direct Vent Heater:...
Color loss on mitsubishi 73" medallion hd1080
TRake the fron grill off and the front board 6- screws on my 65inch there are three adjustment knobs one of them wil adjust the huge
one the whole screen,if not that,I have heard mold growing on and the inside of the blue bulb because it runs the coolest out of the three.
Jan 31, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Toyostove l73
Remove the front panel. Look for the "L" shaped rubber hose near the bottom that goes to the metal blower box. Remove the end of the hose at the blower box. Inside the opening you can see the blower fan blades. Using a pencil or other slim object, gently rotate the fan while the power is on. The blower should start on its own after you get it going. Let the blower run a few minutes to loosen itself up. Replace the hose and front panel. The blower fan tends to stick if the unit is turned off for long periods of time, such as from Spring until Fall. My Laser 73 blower sticks almost every year and I cure the problem doing the above procedure. HTH
May 01, 2008 | Rinnai Toyostove Direct Vent Heater:...
Toyostove Laser 73
There are 2 fuses on the mother board. You can go to the Toyotomi website download the Owners Manual and look at 49 and 50 in the parts list and picture.
Mar 05, 2008 | Rinnai Toyostove Direct Vent Heater:...
Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping Logo
289 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
