Question about Frigidaire (FEB30S7D) Oven
Oven alarm cannot be shut off
Oven/range < year old.
After a standard baking cycle in finished and the "clear off " button is pressed the oven goes off correctly.
Then at some random short time interval the symbol , l "F 10 " appears and the alarm tone sounds. Pressing the "clear off " resets the stove until again at some random time interval the symbol "F 10 " appears again and the alarm tone sounds. Some times this occurs in the middle of a baking cycle. After repeatidly Pressing the "clear off " the stove will stop the problem.
reg501
  • 413 Answers
SOURCE: self-cleaning gas oven
Door lock motor has probably failed.....Self clean on many
ovens can be a self destruct mode. Door latch motors, sensor
probes and even the electronic controls can be destroyed by
this operation. On many freestanding stoves the lock motor is located in the right rear (looking from the front) with a long rod connected to the lock. remove the motor and unhook the rod from the motor cam. Sometimes bending a coat hangar into a hook and sliding from the right side into the lock you can unlock the door.
Posted on Jun 03, 2008
SOURCE: Instructions for Frigidaire oven missing.
I found the manual online. Apparently my unit is malfunctioning and should work by just pressing bake temp and then selecting the temp...
Posted on Dec 03, 2008
  • 1214 Answers
SOURCE: No Sound on frigidaire black smooth top stove/oven
Check in the manual, sometimes the alarms can be disabled.
Please reply the complete model number to see if that ability exists, or what the P/N is of the timer.
Posted on Feb 02, 2009
  • 189 Answers
SOURCE: Oven stops working and display screen goes blank
Hello The control has developed faults in one or more of it's circuits. This clock/timer must be replaced to solve the problem. The Good news is that this is not one of the really expensive controls. Found this one for about 70$ at a website. Worth fixing- but beware the 'self-clean' function after repair, and this control should last a lot longer.  Please acknowledge this post if info helps- have more if needed- Thanks- Ed
Posted on Mar 20, 2010
Testimonial: "Thanks for the great information. This WAS VERY HELPFUL."
SOURCE: Frigidale 10 years old stove bottom heating
Have 10 year old fridgidare elec.oven. Model no.FEF355ASE and both bake and broiler have stopped working have power and ohm's are good. Whats next ?
Posted on Jul 05, 2010
How to turn on electric frigidaire oven; fgf337gud?
Good Morning Friend,
I understand you want to know how to turn on the oven on your Frigidaire range, model# FGF337GUD. First, make sure you have set the clock. You will do this by pressing the "Clock Set" button and then press and hold down the up or down arrows, until the correct time shows. After you have set the clock, you are ready to turn your oven on.
To set the temperature for your oven, you will press the "Bake" button and three dashes will appear. Press the up and down arrows to change the temperature. Note: The temperature will begin at a default temperature of 350 degrees. Once you have released the up or down arrow, your oven will begin heating to the selected temperature. When your oven reaches the desired temperature, it will beep once.
To cancel the baking function, you will press the "Clear/Off" button.
If you wish to change the temperature after baking has begun, you will press the bake button again, and then change the temperature by pressing the up or down arrows to either increase or decrease the temperature.
I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your air conditioner status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 13, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
The teamperature on the digital display can say 350 degrees and the oven thermatore that is located in the oven reads 310. Does this oven need to be calibrated? The oven is 6 years old.
The thermometer that hang on rack are Whooly inaccurate. A good one is the TAYLOR brand. As long as things bake within recipe time no adjustment needed but to do it;
  1. Press BAKE
  2. Select the maximum temp. depending on model it either 500 or 550
  3. Quickly (within 5-seconds of setting 550) press and hold the BAKE button approximately 5-15 seconds until "00" or the previously entered temperature adjustment is displayed.
    Pressing longer could cause an F0, F1 or F7 error to be displayed.
  4. Press the UP/DOWN arrow button to change the oven temperature in 5° increments to a maximum of +/- 35°
  5. Press the CLEAR or OFF button to return to normal operation.
But before doing that i suggest a new high quality thermometer that you hang on oven rack
Aug 12, 2011 | Ovens
I was able to clear the locked door message, and get over working following steps above, but cannot get the lock mechanism to release, and therefore cannot close the door
Check out these steps at the following link... http://www.geappliances.com/search/fast/infobase/10004586.htm
Range - "LOC DOOR" flashes in the display
If "LOC DOOR" is flashing in the display of your range or oven, and the self-clean cycle has not been selected, follow the steps below to reset your control:
Motorized Switch
    1. With the door open, locate the door jamb switch on the face of the oven. It will look like a small black post or dowel.
    2. Push it in until the oven cavity light goes off, indicating that the oven believes the door is closed.
    3. While you hold the door jamb switch in this position, complete the following steps.
    4. Press the Clean pad, wait 10 seconds.
    5. When the cycle initiates, press the clear/off or cancel pad immediately to cancel it.
    6. Wait 10 seconds for the display to clear.
    7. The door should unlock and there should not be a need for service.
Manual Switch
    1. Press the Clean pad.
    2. Close the door.
    3. Slide the latch to lock the door.
    4. Hit the cancel button immediately.
    5. Unlock the door.
Motorized Switch
Manual Switch
    2. Close the door.
    5. Unlock the door.
Nov 24, 2010 | GE Profile JTP18 Electric Single Oven
Oven comes on for 5 min then shuts down everything even the keyboard
Same problem here on JKP15WOW1WW. The cycle starts like this:
1) Open circuit Breaker
2) Open oven panel and push ribbon connector to ERC. Replace planel.
3) Close circuit breaker
4) Run to oven, notice clock flashing some time but not 12:00 and start Bake. Bake button beeps and starts bake coil.
5) Within 5 minutes hear a beep and all buttons on panel are unresponsive. Bake continues. if oven light is on it continues to glow. Only button that responds with a beep (and not to clear bake or oven light) is Clear botton.
Rinse..wash..lather...repeat...
Nov 11, 2009 | GE JKP15 Electric Single Oven
GE wall oven display say F7, Bake and alarm sounds
F7 error code occures due to
A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Replace the ERC there are ten screws 3 on each side and 4 on the control leave the hex screws alone all you need is a phillip screwdriver.
REMEMBER TO SHUT OFF THE POWER FIRST lift and fold out the control panel remove the ribbon cable and remove the four screws that hold the control board . replace control panel in reverse order.
Good Luck!!
Thanks
Aug 06, 2008 | GE JKP30WMWW 27" Built-in Single Electric...
Whirlpool oven issue
Usually, when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Oct 26, 2007 | Whirlpool RBS305PDS Electric Single Oven
Frigidaire (FEB30S7D) Oven Logo
55 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal DeAngelo
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
