Kidz Toyz American Idol FM Wireless Microphone Logo
A
Anonymous Posted on Mar 18, 2013
How do I use a kid toy American idol FM wireless microphone
Instructions for hello kitty wireless microphone
I lost it. Please give me a new frequency number. I need it for my kid,s micro.
How does the Mickey mouse fm wireless microphone work
my microphone had no "applause" button. i flipped the switch on and turned radio on. put microphone up to radio speaker. I pressed/waited auto scan button on the radio until I got the "feedback" squeal. no adjustment necessary.
Dec 30, 2011 • Toys
7helpful
What is the FM radio frequency to use the Hannah Montana Wireless Microphone?
FM 99.7 works best.... However if you have a local FM station using that freq your out of luck UNLESS your handy with a Jewelers screwdriver. Calling tech support will get you a "sorry" but there is nothing we can do. So if you are one of the unlucky ones with a Local 99.7 FM station here is what you can do.
1) Find a dead spot on the FM radio band either at the very low end or high end of the range. You should hear just fuzz (white noise) on your radio. However, on many newer FM tuners if there is no station broadcast there is nothing but silence.
2) Put batteries in the microphone.
3) Get a really really tiny flat head (Jewelers)screwdriver just like the kind in those eye glass kits they sell at the grocery store.
4) Sit right in front of the radio
5) Insert the screwdriver into the tiny hole in the microphone and tune the microphone until the radio goes quiet (no fuzz sound). Or.... you can keep pressing S to hear a beat and the beat is acutally heard through the speakers.
The hole is located just to the left of the screw that you undid to get at the battery compartment, but it's off center. Inside this hole is a small tuning screw. Slowly, slowly, SLOWLY turn the screw driver until you here a change or interruption in the fuzz sound on the radio speakers. This will indicate you found a compatible frequency. Then even slower - tune back to that "notch" until you hear nothing but silence on the radio. Test it by pressing the applause button "A" or by pressing the mic "M" button and talking.
There are multiple places on the FM dial that will "work" as you tune the little screw but you should have already manually selected where (the FM freq) you want to use your mic.
Once it's working it ain't perfect. I doubt you'd do a serious performance on it, but the kids love it.
The mic quality is not top notch for sure.
Fine tune as necessary....
Kelly
2helpful
4answers
Ps3 mic for american idol
u have to go to system setting and than go to accessories setting, and there go to sound,go to input switch to logitech, don't for get to press okay
Microphone not working on ps3 w two connections
you should be able to plug each mic into a usb port. (they are the holes on the front of the machine) they each need to be plugged in separately. If this doesn't work there may be a problem with the usb port.
11helpful
3answers
PS3 American idol encore 2 mic problem
I GOT THIS TO WORK.
First, make sure ur PS3 system update is full updated.
1) Turn on PS3
2) make sure all the mics were unplugged
3) plug one mic in
4) accessories setting -> audio device
5) select logitech as input
6) plug in the second mic
7) accessories setting -> audio device
8) scroll thru the input device, make sure it lists both logitech, this makes both mics are sync'ed to ur PS3
9) select the FIRST logitech device in input device
10) save setting, restart ur PS3
11) start the game as usual
12) in duet mode, both mics should show, if one is working and the second one doesn't, one forum suggests that u unplug the one that works and replug it while u are still in the menu.
Works for me, I hope it works for you. Cheers.
Top Kidz Toyz Toys Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Kidz Toyz Toy Expert? Answer questions, earn points and help others
