Question about Dometic Rooftop RV Air Conditioner
Don't panic, but I have a question about my 40 year old duo therm RV roof top AC. I know, it shouldn't be working, but it does. My problem is it will kick on, compressor starts to work and puts out cold air, then I hear the relay kicking out and it stops putting out cold air. This past fall I took the shroud off and cleaned everything and observed the operating system. Again, it starts, runs for a minute or so, than the relay opens. If I push on the relay, it will run again. A friend suggested a capacitor. Any ideas. I believe there are at least 3 capacitors in the unit, that I can see.
  • 1 more comment
  • wivrrat Feb 26, 2009
    Hi. Thanks for the input. I will have to re-try it. If I remember correctly, it runs for awhile then opens again. If it is low on coolant, would it put out cold air like it does?
    Hi. Thanks for the input. If I remember correctly, it would run for a little while and then open again. If the coolant is low, would it still be putting out cold air? I'll remove the shroud and try it again. Need to get #'s off unit.
  • wivrrat Feb 27, 2009
    Thanks, that makes sense to me. I will inquire as to re-charging the system. Thanks again, I sure didn't want to get into replacing capacitors, etc.
  • 144 Answers
When you say relay I'm assuming the contactor. Does it shut off again when you let go of the contacts (relay)? Most likely it's low on refrigerant and the low pressure switch is shutting it down.
Posted on Feb 26, 2009
  • Perry Putnam
    Perry Putnam Feb 26, 2009
    If it is low but not out of refrigerant then yes it may run for a short time and put out cool air. As it runs the refrigerant pressure would drop below the specified pressure and a low pressure control would interrupt the control voltage or voltage that tells the contacts to close and they would open again. It may happen that after the system is off for a period that the pressure rises again and the contacts will close and the cycle is repeated.
Can I recharge a Duo Therm 600315.001 RV Roof mounted air conditioner? It uses R22 refrigerant. If not, where can I find a replacement or can it be serviced somewhere?
I would suggest that you visit an ac specialist shop as all air conditioners( car, truck , house and yours all use the same principle of operation
because it is roof mounted in an RV may be a caravan repair shop that has an ac specialist in the workshop or a truck service shop that installs ac units in truck cabins would be a good place to start
Mar 13, 2016 | Dometic Heating & Cooling
Duo therm ac in my rv quit when the converter burned up does the ac need 12v to work?
there is a fuse located under the shroud on the roof AC on a circuit board that controls the thermostat to turn on the power to the Air Conditioner replace it it is marked F-1 or, on some F-2 etc.
the air conditioner works on both DC voltage for the thermostat and AC voltage for the compressor
Sep 08, 2013 | Dometic 3312024.015 Duo Therm Comfort...
RV AC is working fine, but the water is leaking from the ceiling Where is the drain tube on the unit, The AC unit is a roof type, Duo Therm serial # 43404934, Part # 3105459
Normally, the condensate will drain out of the unit onto the roof and off the edge to the ground. Remove your cover inside (probably 2 screws) and tighten the 4 bolts you will find inside. If they are tight, go to your RV supply place and get new roof gasket. Remove the AC and insert the new gasket and resecure the AC to your roof.
Thanks for your question @
Jul 26, 2011 | Dometic Rooftop RV Air Conditioner
Duo-therm brisk air AC unit leaks water into my RV when it rains
take the cover off and make sure the drain line is clear on top off RV.
Nov 15, 2009 | Ovens
Duo Therm AC/Heating not working at all after tripped breaker.
I had to get on the roof of mine, remove the cover and manually spin the fan. Add a little oil to the shaft where it goes thru the bearing. All of this is done on the roof side. Mine required this procedure every spring. Duotherm realizes they had a problem and have since corrected it but they don't deal with all of their customers that had the original problem.
Jul 20, 2009 | Heating & Cooling
I''ve been working on this thing for three weeks now. It is a Dometic Duo Therm model 57915.531 roof top ac on my rv. It will not run. This is what i have done so far: replaced the thermostat, there is...
check the compressor winding resistance from common to start
start to run
run to common
the two lowest should equil the highest
also check shorted to ground
check the capacitors the go bad a lot
May 16, 2009 | Dometic Rooftop RV Air Conditioner
Is an old unit worth fixing?
I recommend going with a new one. Both the coleman and the carrier are excellent and a whole lot more efficient that the 16 year old dometic.
May 01, 2009 | Dometic Rooftop RV Air Conditioner
Need to find a cover for duo-therm roof top ac model # 57915.622
I wish I could help you but my agreement with fix ya says I can recommend any names or addresses or phones or emails.
Is this an RV?
Mar 08, 2009 | Heating & Cooling
Dometic Rooftop RV Air Conditioner Logo
147 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
mike cooper
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
