Question about RoadPro Road Pro 12 Volt Dc Portable Battery Jump Starter & Air Compressor 12V Dc Portable Battery Jump Starter & 260 Psi Air Compressor
Need a replacement wall charger for a RoadPro RPAT-774.
This is the RoadPro brand portable, 12V jump starter/aircompressor/power outlet model RPAT-774.
I have lost the wall charger and need a factory replacement or the specs so to find a generic replacement.
I wonder if the (John748, 1/17/09) answer to a similar question for the Duralast DP-DL (120VAC 60mHz input, 12VDC 450mA output ) will be the same for mine?? THANKS!!
4 Suggested Answers
SOURCE: I have a duralast jump
Adaptor for DURALAST BP-DL
Model HB-208b
Input AC 120V 60Hz
Output DC 12V 450mA
Posted on Jan 17, 2009
anil_valayil
  • 218 Answers
SOURCE: I have a Duralast Jump Starter BP-ELG and the
Since you say, it is a 12v DC portable Jump starter, the battery inside it is also a 12V battery. You need a 12V charger (eliminator, wall adaptor or whatever you may call it) Regarding current, it could be anything above 500 mA. Better if it is a 1A or 2A or even 3 A depending on the amount you are willing to spend. Now is the most important part. The polarity. I do not know it since i do not have this equipment. Most chances are that you will find (on the RoadPro) a circle and a dot (along with a +VE and -VE marked near it) around where you plug in the adaptor. For most equipments the outer circle is the -ve and the inner dot is the +ve. (unfortunately this could be reversed in some equipments) If you can find this notation on your RoadPro you are lucky. Just go to any electronic shop and buy an adaptor (12V) that matches this circle and dot notation. The same symbol representing polarity will be marked on the adaptor also. Else, you will need the assistance of someone who can check the continuity using a multimeter. This way you can find the polarity. It is pretty easy. Hope this helps.
Posted on Jan 20, 2010
  • 4088 Answers
SOURCE: I received RoadPro RPAT 774 as a gift sometime
It should have an AC cord that plugs into the case, but if the battery inside is a lead acid type, it may have sulfated to the point that it won't accept charge. You may have to remove the battery from the case and try to charge it with a small external charger overnight. Hope this helps!
Posted on Feb 15, 2010
  • 23 Answers
SOURCE: My Duralast jump starter is dead and when I tried
It will not charge without an adapter suitable for the rated charging amperage. Also,
it must have a ground.
Posted on Dec 18, 2010
Where to find adapter
stores that sell the brand and model may have the available adapter but I doubt it if they sell them as separate parts for they all come from the manufacturer as a set. or else you may order directly from the manufacturer for the adapter.
Dec 28, 2013 | RoadPro Road Pro 12 Volt Dc Portable...
MY pEAK 450 BATTERT CHARGER WONT RECHARGE WHY
The internal battery may be too old to be useful any more.
Nov 18, 2013 | RoadPro Road Pro 12 Volt Dc Portable...
Instructionmanaul2in1jump/aircompressor
Do you want the instructions or someone to tell you how to use it?
Jan 18, 2013 | RoadPro Road Pro 12 Volt Dc Portable...
Can a Duralast jump starter kit start a car while plugged into an outlet?
The charger to a Jumpstart charges at a low rate (300mA to 500mA) and will not push enough current to start a car. Best to have Jumpstarts recharged every 6 months to be ready for emergency.
Nov 26, 2012 | RoadPro Road Pro 12 Volt Dc Portable...
Need a charger to charge my Jump Starter BP-DLG
Need confirmation that the AC adaptor for Duralast jump start model BP-DLG is a 12volt 450ma. Is this correct or do I need something else?
Nov 06, 2010 | RoadPro Road Pro 12 Volt Dc Portable...
I received RoadPro RPAT 774 as a gift sometime ago. Never used it. it is now dead. How do I charge it? Is there a separate cord or accessory that I am missing?
Feb 14, 2010 | RoadPro Road Pro 12 Volt Dc Portable...
I have a Duralast Jump Starter BP-ELG and the power cord got thown away I need to know the voltage, the current and the polartity.
Jan 11, 2010 | RoadPro Road Pro 12 Volt Dc Portable...
Where can i get a manual?(duralast jump starter)
They don't have a web downloaded manual.
Phone:
Toll Free (866) 622-7979
(Monday-Friday — 8:30 am - 5:00 pm e.s.t) Mail: RoadPro
1875 Zeager Road
Elizabethtown, PA 17022 E-Mail: support@das-roadpro.com
Nov 28, 2009 | RoadPro Road Pro 12 Volt Dc Portable...
RoadPro Road Pro 12 Volt Dc Portable Battery Jump Starter & Air Compressor 12V Dc Portable Battery Jump Starter & 260 Psi Air Compressor Logo
679 people viewed this question
Top RoadPro Air Tools & Compressors Experts
Archaeology
Archaeology
ray gallant
Lawrence Oravetz
Are you a RoadPro Air Tool and Compressor Expert? Answer questions, earn points and help others
