Question about Hoover Self-Propelled WindTunnel Bagless Upright VacuumVacuum
Can't get bottom plate off hoover model
Can't get bottom plate off hoover model u4617-190 upright it takes belt#38528-027 thank you
    President:
  • 389 Answers
Am a bit confused because I can't find the model number you give on the Hoover website, so am not sure exactly which machine we're dealing with. However, the procedure for removing the bottom plate is common to most self-propelled upright wind-tunnel models, and it's simply a matter of laying the machine flat, turning it over and removing the four recessed screws that hold it in place. It can then just be lifted off. If this doesn't work for you, perhaps you could confirm the model number and I'll try again. It will also help if you say what country you're in. Good luck!
Posted on Feb 28, 2009
I need to know how to install the belt on a hoover elite upright, #38528027
There are two snaps underneath to release the bottom plate. Next remove the top cover by gently prying off the base with a flat screwdriver. this will expose the belt. Install the new belt on the roller nd then push through the hole to attach to the motor shaft. reinstall the cover and bottom plate.
Jan 14, 2010 | Hoover Elite U5061-900 Bagged Upright...
Describe how to replace belt on hoover windtunnel bagless
If you turn the vacuum so the bottom is facing up you will see the base plate that covers the roller brush. There will be four screws (usually phillips head), remove the screws and the base plate will lift off. You now have access to the roller brush and belt. Lift the roller brush up and remove the old belt. Place one end of the new belt over the motor shaft and the other end over the roller brush and put the roller brush back in place. Now simply replace the base plate and you're done! This models requires Hoover belt # 38528033 (single) or Hoover belt #40201160 (2 pack). You can get this belt at www.vacbelts.com.
Here's the pages:
http://www.vacbelts.com/hoover-40201160-belt.htm
http://www.vacbelts.com/hoover-38528033-belt.htm
Oct 15, 2009 | Hoover U5750-900 WindTunnel Bagless...
Help...can't replace the belt on a hoover upright ''futura''
You didn't say what the model number is, so, I will give you a link to a website that has instructions with pictures on how to change the belt. Once on this site, you will see two links for belt replacement. Click the one that is closest to your model.
http://www.info-vacuum-cleaner.com/hoover-vacuum-cleaners.php
I hope this helps.
Oct 02, 2009 | Vacuums
Hoover sweeper model U4263-930 belt change
undo screws on bottom of vac take out brush and belt put belt in then manewver brush in
thank you for useing fixya please rate me
Feb 07, 2009 | Hoover Vacuums
Belt change on savvy upright
Take off the bottom plate, also remove the screwsfrom the bottom to remove the top cover, also there is a screw under the Hoover emblem on the top cover, with these removed you can get to to brush roll and belt.
May 11, 2008 | Hoover U8171-900 / U8172-900 / U8173-900 /...
Changing the belt?
Take off the bottom plate covering the brush roll. The belt runs from the brush roll to the motor shaft. Get a new belt, it will strectch to go around both.
Apr 29, 2008 | Hoover U5163-900 Upright Vacuum
How to change the belt on a Hoover High Performance upright vacuum cleaner
Generic problem for all Vacuums
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Most of the Hoover upright vacuums service from the bottom and to start remove the bottom plate, that should expose the belt – if this is the case, some Hoover’s might be self propelled, if not the self-propelled vacs have 2 belts and the non self propelled models have one belt – so remove the belt(s) and then lift up on the brushroll and slide the belt onto the belt pulley then take a screwdriver tool with a hook on the end and stretch the belt onto the motor shaft – once this has been done the track the belt(s) and it should straighten out and run straight, re-install the bottom plate, plug in and test. If you cannot get @ the belt from the bottom the look for 2 or 3 screws – remove the screws and the top cover will lift off and then follow the procedure mentioned above… Questions? Please feel free to contact your local vacuum dealer in your area or in the yellow pages or contact the Hoover factory for more details.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Apr 22, 2008 | Vacuums
BELTS ON WINDTUNNEL VACUUMS
Greetings from GoVacuum,
Here's an instructional video that we made showing how to change the belt on a Hoover Windtunnel upright. If your model is not a self propelled model, basically follow the same insturctions, expect instead of placing the belt over the pulley, just put the belt through the roller brush, and stretch the roller brush back into the agitator housing.
Please feel free to send me an email if you have any other questions. My email address is chris.jones@govacuum.com.
Thanks,
Chris Jones
GoVacuum.com
Mar 16, 2008 | Hoover U5753-900 WindTunnel Bagless...
Beater Bar
Take off the bottom plate, then you can get to the brush roll and belt, on the model number plate, the number of the belt is on that, it is also on the belt if you can still make it out.
Dec 26, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover Self-Propelled WindTunnel Bagless Upright VacuumVacuum Logo
158 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
