Question about Sewing Machines
I need a manual for an Eagle EA-156 industrial sewing machine.
I have an Eagle EA-156 industrial sewing machine. I am looking for a manual because I can't get the bobbin to work properly.
  • 12 Answers
SOURCE: Bobbin thread breaks
Things to check for thread breakage (top or bottom)
1. Good thread in the machine - not hand thread, cheap thread, quilting thread.
2. A burr on the hook - a small nick on the hook can grab and tear threads, however this usually causes the top thread to tear, not the bottom
3. Make sure a new needle is in the machine - one made for the material you are sewing
4. The bobbin must be installed to rotate in the correct direction in your bobbin case
5. And I'll say it anyway - tensions - the primary cause of thread breaking - Remember, there are TWO tensions in a sewing machine, top and bottom. Also, the thread you see on the bottom of the stitch is the top thread, and vice-versa.
Posted on Dec 04, 2007
SOURCE: Brother DB2-B755-3 industrial sewing machine
Seems this industrial machine is branded with several well known makes. I have purchased the machine direct with the manufacturerTamata and the model is a PF8500 which is branded as a Brother SL7553A or Brother DB2-B755 - Also known as Wimsew High Speed Lockstitch Industrial sewing machine.
Posted on Jan 13, 2008
SOURCE: I have a Consew 230
www.sewusa.com can provide a manual
Posted on Oct 09, 2008
  • 19 Answers
SOURCE: Bernina Bernette 65 sewing machine
Presumably neither of you has or knows how to adjust your bobbin tension so, I'm going to presume it's your hook. Make sure you are threading the machine coorectly then you'll need to remove your needle plate by removing the two screws, pull out your hook (this is the part your bobbin sits in) but make sure you note which way it sits inside your machine. Have a look at the plastic hook for any sharp edges or burs, you may need to replace your hook or try and gently sand (400grit) the plastic if possible. The key part of the hook is the small blunted point as this is what catched the loop of thread behind the needle. Please make sure that when you put your hook back in, that it is on the left side of that little guard sticking out on the lower right of your machine.
Posted on Dec 10, 2008
  • 37 Answers
SOURCE: brother xr-65 bobbin problem
Mine does the same thing with the cheap plastic bobbins. I switched to the metal bobbins and no more issue!
Posted on Apr 15, 2009
What kind of oil do i use for a Harrison industrial overlooked
THERE IS THE PAN UNDER THE SEWING MACHINE. LOOK FOR A MAX OIL FILL LINE. HERE'S WHERE TO PURCHASE INDUSTRIAL OIL.
https://www.google.com/search?q=industrial+sewing+machine+oil&es_sm=122&source=univ&tbm=shop&tbo=u&sa=X&ei=ipHOVIieHIWwyATT44LoAw&ved=0CIgBELMY
Feb 01, 2015 | Sewing Machines
SERVICE MANUAL FOR YAMATA FY8700 INDUSTRIAL SEWING MACHINE
my thread deeps bursting, tension is normal. what to do?
Sep 24, 2012 | Yamata Sewing Machines
Any information on chandler br-500-3 industrial sewing machines?
Ask Chandler direct. They are specialised machines. They have some manual on the site but not yours/
Chandler Machine USA
Sep 01, 2012 | Sewing Machines
Instruction manual for singer double needle sewing machine
Judy. AN647555 is the serial number of your machine. I'll need a picture to help you identify. Manuals are not found typically in the regular area at singerco.com
Picture please and I'll direct you to the right area.
Jul 28, 2012 | Sewing Machines
I need a pdf manual for the Brother Industrial sewing machine model DB2-B755-5. Hope someone has the manual
You can go to www.brother-usa.com and look for your model but I saw only similar as in DB2-774 and a couple of others under the industrial machines. Maybe they will be close enought to answer your questions. They are free to download, if that doesn't work call Brother at 1-877-276-8437 and I am sure that they can help you locate one. Good luck, you have to wait until Monday to call them.
Sep 17, 2010 | Sewing Machines
Looking for a operating manual for db2 b797 brother industrial sewing machine, preferable downloadable PDF
you can asked only the manual of your machine, to the store of brother sewing machine.
Mar 28, 2010 | Brother Sewing Machines
I have a Brother Industrial sewing machine model # LS2
http://www.mastersewusa.com/info_br_ls2-b837.html
Oct 15, 2009 | Brother Sewing Machines
Need a manual for a baby lock serger model EA-605
You might take a look on ebay item 160362974035
Jan 16, 2009 | Baby Lock Eclipse Serger
Sewing Machines Logo
250 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
