Question about Poulan/Weed Eater No. Bvm200le 711482 24cc Gas Blower/Vac
Poulan blower vac shocks me
Shocks when motor is running
  • Jeff Majewski Aug 21, 2012
    this is happening to me too, more noticably during the vac usage
  • 31 Answers
SOURCE: where do I find a carburetor assembly drawing for
Does the carburetor have a name on it like walbro. if it does just search for the name. and if its a walbro carb. they are all the same from the smallest to the largest.
Posted on Sep 23, 2009
Biggdex35
  • 333 Answers
SOURCE: Gas/oil ratio
3.2oz oil 1 gal gas 40:1
Posted on Jul 13, 2010
  • 100 Answers
SOURCE: How do I clean the air filter on my Poulan
warm soapy water then air dry if it is a foam one
Posted on Aug 14, 2010
HansPP
  • 2510 Answers
SOURCE: What is the oil mixture
The correct mixture is 16 oz. to one gallon of gas. That would be US.
Posted on Apr 23, 2011
bcharais
  • 278 Answers
SOURCE: how to change fuel lines in poulan pbv 200 blower/vac
im not familiar with those but donyboy73 on Youtube may be able to help. he does a lot of small engine work
Posted on Aug 07, 2012
How to repair power switch on Weedeater Electric Leaf Blower
It as simply as it can get. Other than that you need to be checking voltage along the circuit especially at the motor which has an internal fuse.
Jan 11, 2015 | Poulan Weed Eater No.Ebv215 Electric...
Why won't my Poulan leaf blower pull cord turn motor over?
If the recoil is spinning free and you feel no resistance either the engine is damaged or the recoil dogs are not engaging. Fixing either of these at a shop will likely cost more than buying a new unit.
Jul 29, 2014 | Poulan Bvm200vs/bvm200le Blower/mulching...
Poulan blower fuel lines
I would guess the fuel line you installed is kinked somewhere.
Jan 12, 2014 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Primer bubble wont expand poulan wt200
you have a clog in the line clear lines out and will work right line to tank and to motor both.
Mar 20, 2012 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
My Featherlite Weedeater shocks me when I touch the rod that the spool is attached to. ( I am a woman, can you tell, lol) The only thing I can figure out is the repairman took off the rubber sparkplug...
Yes, that is the problem if the metal loop is touching part of the trimmer. If it's not touching anything, I guess it's possible that the spark could be jumping; causing the whole trimmer to be electrified...Yikes!! Are you touching the spool while it is still running??!
Jim
Aug 25, 2011 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Poulan 21cc weedeater - starts but won't stay running. I've cleaned all fuel lines, cleaned plug and has plenty of gas - but still won't start. runs for 2 or 3 seconds and dies. appears to not be getting...
On these types of motors that could be the problem, another thing to check is the primer bulb. I have had a primer bulb that had a small crack in it which went undetected for a while. These types of motors do not have a fuel pump and they work on a siphon type mechanism, if there is an air leak dealing with the gas tank anywhere, that is your problem.
Aug 11, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Will not stay running act like it runnig out gas? and in back the motor real wet too. it a 450cxl poulan
The wetness, does it smell like the gas mixture. If so, one of the gas lines most likely has a crack keeping the gas from flowing to the carb which makes it quit running. When you prime the blower, this is when it will run for only a few seconds? This is because the primer bulb is taking gas and shooting it straight to the carb.
May 03, 2010 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Poulan pro weedeater will start fine run untill you pick it up then dies
poulan has a bad habit of the fuel breaking inside the tank if it breaks before the fuel filter that makes the fuel line shorter
Nov 05, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Gap setting poulan wildthing blower
buy an echo or a stihl... poulan rates this motor for 40 hours of use and then it is done.
head bolts came loose on mine piston slap wore out jug ring and piston. don't want to spend 40d on parts to repair a 100d unit
Dec 06, 2008 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Poulan/Weed Eater No. Bvm200le 711482 24cc Gas Blower/Vac Logo
145 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
