Question about Brother MFC-5840CN All-In-One InkJet Printer
Ink Cartridges are full but keeps telling me they are not to then
I have a Brother MFC-5840CN and it won't print because it keeps telling me to change ink cartridges or even though they are in the it says no cartridge.
  • lrogers571 Feb 26, 2009
    I put new cartridges in and still says the same. Lynn
    Scholar:
  • 85 Answers
As a printer mechanic .i had got many customers coming at my work shop with this problem .and it gets soved by replacing the cartridge with new cartridge.as you said cartridges are full still it says change cartridges.but if the circuit of the cartridge is got faulty it will not print let it be full.so clean the brown colour metal circuit on the cartridge with a dry tissue.if its due to dust got stuck up on the circuit it will print otherwise the cartridge has to be changed in this case.
Posted on Feb 26, 2009
My brother printer not working well
Are you using Genunine Cartridges!!!!
ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Feb 03, 2010 | Brother MFC-5840CN All-In-One InkJet...
I changed all Print cartridges-Black, Yellow,Cyan,Blue
On this machine you have to install inks with power on and use the ink button and choose replace ink. If you just plug them in it won't register and reset the counts. You may need to run clean cycles at least twice to get proper colors.
Jan 29, 2010 | Brother MFC-5840CN All-In-One InkJet...
I replaced ink in my printer (mfc-830cln). but still can`t print .a message keeps coming on screen with demonstrations.
Make sure all the cartridges, do not have the strip over the hole, where the ink comes out.
Shut if off, for awhile, then turn it back on about 15 minutes. See if that works.
Nov 04, 2009 | Brother MFC-5840CN All-In-One InkJet...
Brother mfc 5840 won't print clearly
you need to check the maintainence kit and see if it's full. Also if it isn't, use some iso-proponal alcohol and some q-tips to clean the print section of the cartridge and the cartridge tray.
Aug 21, 2009 | Brother MFC-5840CN All-In-One InkJet...
All of a sudden, our printer won't print. Won't copy. Was working just fine the day before. Have installed new black cartridge.
We bo't a refurbished machine of the same model for $60 from Staples. We're hoping it lasts long enough to use up all the ink cartridges we have. However that works out, it will be last Brother printer we'll own.
tnx,
bobj
Aug 07, 2009 | Brother MFC-5840CN All-In-One InkJet...
MFC 5840CN - no print
you need to go to brother.com for the solution
Jan 08, 2009 | Brother MFC-5840CN All-In-One InkJet...
New ink cartridges not printing
hi,what kind of printer u used?,,,,i think u must repel the cartridges before using it.
Aug 19, 2008 | Brother MFC-5840CN All-In-One InkJet...
Brother MFC 210C series ink replaced
The brother machines require ink in all the cartridges as it is always flushing ink through the heads to "clean" it. This means you must have ink in all cartridges at all times unfortunately or the brother will not work. Even if you could somehow get it to work it could damage your printhead anyway.
Good Luck
Please rate my advice, good or bad.
Feb 06, 2008 | Brother MFC-5840CN All-In-One InkJet...
Print function stopped working. Brother MFC 5840CN
First things first:
press menu then start bk-copy then fourtimes arrow-up button. machine will display an error code no. plz post AS A NEW POST again.
BTW: The update has nothing to do with the stopping of the machine!
Jan 10, 2008 | Brother MFC-5840CN All-In-One InkJet...
Brother MFC-5840CN All-In-One InkJet Printer Logo
233 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
