Question about Whirlpool 30" Self-Cleaning Freestanding Electric Range - White-on-White
I have a whirlpool/kenmore plus range that came with our house when we purchased it. Former owners did not leave a manual for it. The numbers on it are 95779890 and serial RJ3516457. I wanted to "auto clean" the oven so I selected it and then pushed start/enter. It first said "cln door" and then the following appeared E1 -F5-. The door is locked and won't come open. I thought it would eventually release but it has now been 24 hours and the door is still locked. Can you help?
  • 15,935 Answers
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@#$TERGD
Posted on Oct 01, 2010
When cooking F-5 will come on and oven will stop, once oven as cooled down somewhat i can start cooking again
Posted on Apr 02, 2011
Whirlpool owners manual gas stove W10198615D
Most Whirlpool model numbers start with two or three letters and have another two letters later in the number. W10198615D may be your serial number or a Lowe's product number, not the Whirlpool model number.
Usually though the model number and serial number aren't on the back of the stove. The plaque with this data is on the rim of the oven behind the warming or storage drawer.
The manuals that are available are here: https://www.whirlpool.com/webapp/wcs/stores/servlet/OCManualsLiteratureSearchView?catalogId=10561&langId=-1&storeId=10211&krypto=5QgxQhneFliXuEuX564wSQ%3D%3D&ddkey=http:OCManualsLiteratureSearchView .
Please recheck your model number and post a comment with the correct model number. I'll be glad to try to get the correct manual for you.
I wish that I could be of more help right now.
Dec 20, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
I would like to obtain an operators manual for a whirlpool electric range.
Whirlpool has the manuals for many of their appliances on their web site: https://www.whirlpool.com/webapp/wcs/stores/servlet/OCManualsLiteratureSearchView?catalogId=10561&langId=-1&storeId=10211&krypto=5QgxQhneFliXuEuX564wSQ%3D%3D&ddkey=http:OCManualsLiteratureSearchView . You need to provide the model number of the range to get the correct manual. From the Whirlpool site, click Search after entering the model number. For most ranges, the model number will be on a plaque behind the storage drawer on the rim of the unit.
If you add a comment with the model number, I will be glad to see if the manual is available.
I hope this helps.
Dec 10, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
I would like to see a operating manul for a whirlpool gas range.
For that manual go here http://www.whirlpool.com/owners-center/owners-center-homepage.content.html and enter your model number,on that link will be a place to click on to show you where to find model#
Aug 09, 2011 | Whirlpool Ovens
I was cleaning my self cleaning whirlpool accubake oven and a F1 and E7 code appeared. I have just bought my house and the prior owner did not leave any manuals. Help please
Most Whirlpool appliance manuals are available from Whirlpool: http://www.whirlpool.com/owners-center/owners-center-homepage.content.html . You will need the model number from the oven. This should be located behind the oven storage drawer on the rim. It will usually be on the left for a range and on the right for a wall oven. On rare models the plaque with the model number will be behind the door. If you add a comment with the model number, I'll try to post a direct link to the manual.
Are you sure about the error code? F1 and E7 aren't in my code books. I have an F7 and E1 code that indicates a short between the door switch or latch switch and the chassis or ground. (For double ovens, there are two of the switches for each door. The code doesn't specify which oven has a bad switch.) The F5 E7 error is a door latch that will not unlock. An F3 E7 error indicates that the warming drawer sensor has shorted out.
For the F3 E7 error, simply replace the sensor. For the other two errors, the solution depends on the door lock state. You start by unplugging the oven and checking all the wires and their connectors. See http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Whirlpool%20Range%20/%20Stove%20/%20Oven%20Fault%20Codes for the complete set of steps. If the wires/connectors are okay, you probably need to replace one of the door switches if the oven door was locked when the error occurred. If it wasn't locked, then you can check the voltage to the various switches and replace any that are bad. If it isn't a switch, then it is the control that has failed and must be replaced.
I hope this helps.
Jul 02, 2011 | Ovens
Kenmore double wall oven keeps beeping
I have a whirlpool stove and when I try to clean it after awhile it starts beeping and comes accross with E1 & F5 the oven when its to clean dosen't seem like its locking. How can I fix this problem. Ive missplaced my book somewhere and can't seem to find it. My timer and clock is digital. Can you help me solve this problem? Thanks!
Aug 22, 2009 | Kenmore Ovens
Whirlpool 465 Surface Hot Indicator Light stays on all the time.
Most likely a faulty burner limiter switch. Not sure if they can be purchased separately from the burner element.
-Dave
http://www.appliancepartspros.com/part_details.aspx?part_id=3767588
May 31, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Kenmore glass top
Your range was actually built by Whirlpool. the first 3 digits of the serial number determine who it was manufactured by.
It's possible that a battery somewhere is running low. This battery would be for the clock and timer.
See if you can find the service sticker and find the model nnumber - it would most likely be a couple of letters and some numbers. If you're from the US, you may be able to find a manual here: http://shared.whirlpoolcorp.com/product_literature/search.jsp
If you're from the UK, it'll be here:
http://www.whirlpool.co.uk/app.cnt/whr/en_GB/pageid/pgsrvifuhome001
Please let me know how you get on.
Jun 18, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore electric range F5 and F3 warnings
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
May 13, 2008 | Kenmore 30169 Electric Single Oven
Whirlpool 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
554 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
