Question about Sony Handycam CCD-TRV81 Camcorder
I have a very old sony handycam but I can no longer play my old tapes on this.Small white cloud flashes up on the screen.Can anyone help
  • dannomaher Feb 26, 2009
    It is CCDFI5OE
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    what is the model number of that old camcorder?
  • 10,594 Answers
Wow, pretty old model.
You need to replace all electrolytic capacitors on its all boards. These models has problem of capacitors leakage.
Posted on Feb 26, 2009
Constant ejecting
This is already an issue with the hardware. There is a rubber bond inside the cassette that is no longer intact and needs to be replaced. Possible cause by repetition of single and old cassette tape and improper tape position.
Apr 06, 2010 | Video Cameras
When i put a tape in it ejects it..then a tape with a slash appears on the screen
you are prohibited from recording on thips tape. This is because the red tab on the side of the tape that faces you when you are inserting the tape inside the camera has been put in 'SAVE' position . to be able to record o the tape you need to use your fingernail to slide the red tab to the 'REC' position.
Ive extracted the following article for you from wilkepedia to help you understand this issue:
Tape and recording protection
250px-8mm_cassette_erase_tab.jpg magnify-clip.pngThe write-protect switch (right) prevents accidental erasure. .
To prevent the recording on the tape from being erased, there is a small write-protect tab that can be moved to one of two positions, labeled "REC" and "SAVE". Comparing the sliding tab to a door, the tape is in the "REC" position is when the "door" is open and the "SAVE" position when it is closed. (Not all tape cases have markings for this information!) The tape can only be recorded on (or recorded over) when this tab is in the "REC" position. This is an improved version of the VHS write-protect tab, which prevents erasure after it has been (permanently) broken off.
Dec 02, 2009 | Sony Handycam CCD-TRV318 Camcorder
Sony Handycam CCD-TRV21 won't play tapes.
no that u must remove ur camera and try to clean all strip that connect with board and mechanisum and all connectors legs solder then it will work .any doubt call u.a.e no 00971503853766
Jul 04, 2009 | Sony Handycam CCD-TRV21 Camcorder
Handycam won't play tape
i have thi problem to it is the x700 sony one :/
let me know if you have sorted the problem and tell me the soluvtion as i haven't yet :/
thankyou
Jun 25, 2009 | Sony Handycam CCD-TRV408E Camcorder
Viewing SONY 8mm Tapes -- Please help
The older tapes were shot on a 8mm camcorder and the camcorder you have wil not play them becasue it doesn't have backwards compatability with the older format. The tapes you recorded are on a digital 8 camcorderr and it is different encoding than the one you recorded the other 60 tapes with. You will need to find either a dcr-trv 350 trv 530 trv 730 ect as these have the ability to play all the tapes.
Or find an older 8mm camcorder to play your tapes with.
Hope this helps
Cheers
Al
Nov 01, 2008 | Sony Handycam DCR-TRV280 Digital Camcorder
Old tapes won't play in different Handycam
Were your tapes recorded in extended play? Sometimes that will make it impossible for a different tape deck to play it back correctly. The tolerences on Hi-8 are very small so it is possible that a tiny alignment difference will make it impossible to play back a pre-recorded tape. Try fast forwording and rewinding the tape and try it again. Also try playing it from different parts of the tape. Go to the middle of the tape and try it there.
Jul 10, 2008 | Sony Handycam CCD-TRV608 Camcorder
Black and white playback with sony handycam dcr-hc20
There is no problem on your camera, DCR-HC19E is PAL system(European system) DCR-HC20 is NTSC(American system). Are you in US or Europe? I think your TV is NTSC, cause the tape recorded on DCR-HC19E you played has no color. To confirm, connect your HC20 to TV in camera mode, not recording yet, just look at the TV as your monitor, If its in color, no problem, just erase the old video recorded on the HC19E, but if its important to you, you can convert it to NTSC using a PC. thanks
Sep 12, 2007 | Sony Handycam DCR-HC20 Mini DV Digital...
Tape rejection - droplet symbol shown
Hi there, the small water type symbol means that the internal dew sensor is activated. Please use the fan (low temperature) or leave it in a warm place for some time. If you need more info please advice.
Apr 26, 2007 | Sony Handycam DCR-TRV130 Digital Camcorder
Will not playback or record
I have a Sony handy cam ccd-trv108 Hi-8 and I can not get it to play or record, everytime I insert the tape and hit play the display screen flashes c:31.22 Please help me?
Aug 10, 2006 | Sony Handycam CCD-TRV108 Camcorder
Video Cameras Logo
214 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
