Question about Kyocera Mita FS-3820N Laser Printer
Kyocera 3820n doesn't work right on my macbook OS X 10.5
I dowloaded this driver Kyocera OS X 10.4 v1.0.mpkg and it seemed fine, and communicates with printer, but it doesn't print correctly... just a garbled mess.
  • 622 Answers
If you have a mac os x operating system... you already have drivers built into your mac printer menu... try installing the generic print driver and see if that helps... sometimes it works better than the manufacturer's driver...
Posted on Dec 24, 2009
  • MrsKnowItAll Aug 31, 2011
    I had the same problem for two years and then when I installed a new fancy Kyocera printer at my office this week, my old Kyocera FS-3820N magically started printing too.
    I checked online and they put out a new drivers that work with OSX 10.5, 10.6, and 10.7 on 8/15/11. You can download them on Kyocera's website or by going tohttp://usa.kyoceramita.com/americas/jsp/...
Kyocera call service 4200:040797
Means that the laser unit is off. You should check the cables for the laser unit
Jun 27, 2014 | Kyocera Mita FS-3820N Laser Printer
Kyocera prints garbage
driver issue. download latest driver and update printer firmware
Feb 09, 2013 | Kyocera FS-920 Laser Printer
My Printer Kyocera FS-3820N keeps sending the print out pages to the back instead I would like them to come out onto the top loader.....please help
In order to get the printouts on the top bin, all you have to do is close the rear tray.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 20, 2011 | Kyocera Mita FS-3820N Laser Printer
Where can I find driver for KYOCERA FS1030D for MAC OS X LION ?
hi,
here;s the download center for kyocera you can download here the driver for your printer.just follow this link good luck!
Aug 11, 2011 | Kyocera FS-1030D Laser Printer
How do I install driver for Kyocera CS 5035 on MAC
Kyocera and Copystar models are the same just replace KM with CS.
The following instructions should help you. TO download the current driver use this link to th emanufacture website; http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?rid=18657.
Kyocera Printer Drivers and Mac OS® X 10.5 Leopard FAQ:
Is the installation for Mac OS X 10.5 the same as for Mac OS X 10.4 and earlier? Mac OS X 10.5 introduced a new printing architecture that requires changes to the installer and installation process. For this reason, Mac OS X 10.5 requires a new printer driver installer.
I cannot see my Kyocera AppleTalk® printer. How can I make it visible to OS X 10.5? AppleTalk is disabled by default in Mac OS X 10.5. Enable AppleTalk to discover your Kyocera printer.If you use the Kyocera installer, a message will appear, asking you to enable AppleTalk. Click Yes to continue the installation.
I cannot find Printer Setup Utility on Mac OS X 10.5. Is it still supported? Apple has removed Printer Setup Utility from Mac OS X 10.5. To install a printer, open System Preferences and click Print & Fax.
When I manually install a printer, multiple PPD files are listed for the same Kyocera model. Which should I choose? When manually installing a printer or changing a PPD for a installed printer, both Linux and Mac OS X PPDs are listed for some older Kyocera models due to a change in PPD handling in Mac OS X 10.5. Linux PPDs can be identified by the word Gutenprint in the PPD filenames.
Supported Multifunction Printers: KM-1650, KM-1815, KM-1820, KM-2050 ,KM-2530 ,KM-2550, KM-3035, KM-3050, KM-3530, KM-4030, KM-4035, KM-4050, KM-4530, KM-5035, KM-5050, KM-5530, KM-6030, KM-6330, KM-7530, KM-8030, KM-C830, KM-C830D, KM-C850, KM-C850D, KM-C2520, KMC2525E, KM-C2630, KM-C3225, KM-C3225E, KM-C3232, KM-C3232E, KM-C4008, KM-C4035E, CS-1650, CS-1815, CS-1820, CS-2050,CS-C2525E, CS-2550, CS-6030, or newer. Supported Printers: FS-820, FS-920, FS-1018MFP, FS-1020D, FS-1030, FS-1100, FS-1118MFP, FS-1300D, FS-1800, FS-1800+, FS-1900, FS-1920, FS-3800, FS-3820N, FS-3830N, FS-6020, FS-6026, FS-9100DN, FS-9120DN, FS-9500DN, FS-9520DN, FS-C5016N, FS-C5020N, FS-C5030N, FS-C8008N, FS-C8026N, FS-C8100DN, or newer.
I hope this is helpful,
Shawn
Mar 08, 2011 | Kyocera Copystar CS-5035 Copier
Check waste toner box
We have a Kyocera Mita FS-3820N and sometimes when the toner box message does not go away, even after emptying the box, we simply hit it a few times in the area of the box. Works every time!
Jun 02, 2010 | Kyocera Mita FS-3820N Laser Printer
Error code 4200-002678 call for service
best case scenario... laser scanner harness or cable loose or bad... medium case scenario... laser scanner unit is bad... worst case scenario main board is bad...
May 20, 2009 | Kyocera Mita FS-3820N Laser Printer
New MacBook with Mac OS 10.5.6 doesn´t print with Kyocera FS-2000
the print driver ... look for the latest print driver. Also you may want to ask a technician to do a firmware update of your printer.
Jan 09, 2009 | Kyocera FS-2000D Laser Printer
Kyocera Mita FS-3820N Laser Printer Logo
240 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Adorjani Laszlo
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
