Question about Kyocera Mita FS 1000+N Laser Printer
Hi there i have fs kyocera 1000 and when i wont to print the printer tak the paper but the paper get empty and the printer stop .so i open the cover and close the printer resuom printing and the paper get out
  • 622 Answers
Sounds like paper is jamming... clean the rollers that pull the paper into the machine with rubbing alcohol and see if that solves the issue... if something is blocking the paper... take out your tray... drum and developer and search for the obstruction...
Posted on Dec 24, 2009
  • 27 Answers
Clean the paper feed roller with a damp cloth after removing the paper tray, otherwise call a technician since parts may need to be replaced, including the roller in case.
Posted on Mar 13, 2009
Kyocera 2020d WONT PRINT Load Mp Tray
load a4 paper in bypass or the mp tray as it is also called
Jun 08, 2017 | Kyocera FS-2020D ECOSYS Monochrome Laser -...
Kyocera FS 4000 DN printer stops printing for no reason.
Try the feed tires in the tray first. More than likely the paper is not being picked up and causing jam message. The separation roller also has a hub on it to prevent a second sheet from feeding. Sometimes these start to lock up ,a little oil on the hub sometimes relieves some of the tension.
Jun 03, 2010 | Kyocera FS- 4000DTN Laser Printer
Kyocera fS-920KX. Not printing
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem
YBC (/\)
Jun 01, 2009 | Kyocera FS-920 Laser Printer
Kyocera Ecosys FS 920
So what is your printer condition? Better know what is going on your printer so can solve the problem.
YBC (/\)
Mar 24, 2009 | Kyocera FS-920 Laser Printer
I have a Kyocera FS-2000D printer that will not print
first turn off your pritner power.
check open the front door pull your ink cartridge then clean dust and blur from it then check there is not any paper jam then refix ink cartridge.then turn on the power.
Mar 21, 2009 | Kyocera FS-2000D Laser Printer
The printer will not load the papers
Hi you may try:
1) paper input sensor dirty, clean paper input sensor usually near the tray input roler area there is a micro switch or a led light sensor with two wires.
2) paper input sensor fail or disconnect between sensor and socket on the board, you have to open the cover to check.
Dec 22, 2008 | Kyocera Mita FS 1000+N Laser Printer
Huge Margin with Kyocera FS 1000+
If the FS-1000 prints too far down the page or leave too much top margin or leaves a gap at the top of the page etc (<- for google searches). This is a problem with the felt pads on the three solenoids/clutch electro magnets that are under the right panel (2 under the engine/button board, 1 under the inner plastic cover, sometimes 4 in total on other kyocera printers). They get compressed over time meaning the metal leavers come into contact with the solenoid meaning they are released too slowly. Simply replace the felt pads with .5mm cardboard or another non-sticky non-metallic material. Too thick and it prints too far up the page.
Sep 28, 2008 | Kyocera Mita FS 1000+N Laser Printer
Printing Issue
sounds like it got hit by lightning and needs some serious repair... consult a service technician... in your area
Jun 03, 2008 | Kyocera Mita FS 1000+N Laser Printer
ERROR CODE 7410:0004729
Hi, switch off printer ,just open cover(door) on the left side of the machine and push Drum Unit in machine(to proper seat)
You have to hear "click" sound.Switch on printer.
Regards...
Mar 08, 2008 | Kyocera FS-2000D Laser Printer
Kyocera Mita FS 1000+N Laser Printer Logo
135 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Adorjani Laszlo
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
