Question about Amana Dryers
Dryer quit after about 20 minutes-see more details below
Dryer quit after about 20 minutes drying time and would not restart. After allowing dryer to sit for about 3 hours, I tried to use it again. The heating element got really hot. (So hot that I could smell it getting hot.) Immediately shut it down. Took kick panel off lower front. Had quite a bit a bit of lint in the unit. Cleaned that out. In the area just below the electrical hookup there was some lint that looked like it had been hot. Do we need to take cover off electrical hookup and check for lint under cover? Do you think the heating element needs to be replaced? Or is there an overheating limit switch that needs to be checked out? When I first turned the dryer on it sounded like the motor had a hard time starting. Any ideas? Do you need any more info? If so, ask me some questions about something I didn't supply here.
  • 686 Answers
Do you have clothes on top of dryer? if so, i'll say it again never ever stack clothes or anything on top of it. Things on it insulate it and will overheat the machine. Yes it has a overheat linit switch but to get to it you have to take it apart and pull the drum out depending on the style of heat element you have. Some are in the back of drum and others are in a tube on the floor of the unit inside. If yours is behind the drum then drum needs to come out to check for the problem
Posted on Feb 27, 2009
  • James Chandler Mar 02, 2009
    Change your thermostat it's not telling your heat element to shut down at the right temp
Bosch Nexxt 500-series electric dryer problems - Dryer never finishes complete cycle of drying clothes. When attempting to restart, the display will show 20 (mins) even though I've pushed something di
did you clean the LINT filter? try vacuuming the lint trap area. wet or damp lint can get built up in the lint trap area. it is good to regularly clean the area as it is a Major fire hazard.
Mar 12, 2014 | Bosch Nexxt 500 Dryer
Dryer had been working fine. A load of sheets was drying and had been for apprx.20 minutes. The dryer quit in the middle of the cycle and will not restart. There was no sound or any indicator of a problem...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Oct 18, 2010 | Frigidaire Dryers
MY BOSCH NEXXT 500 ELECTRIC DRYER IS RUNNING ON 20 MIN AIR DRY BUT WITH NO HEAT. SOMETIMES BY SLOWLY MOVING THE DIAL WILL ALLOW THE HEAT TO RUN FOR A FEW MINUTES. THEN LINT SENSOR GOES ON. HAVE CLEANED...
Did you check this FIXYA LINK below? Appears to have lot's of answers!
Also I WATCHED the YOUTUBE video I recommended and NOTICED his DRIVE BELT is WAY too loose! Methinks THAT is why his dryer has problems!
Be SURE your belt is not to aged because they can STRETCH and then TRIP the "RESET SWITCH" he's talking about. Note the way his PULLEY shakes so violently... AND the action of the belt itself...
20 Most Recent Bosch Nexxt 500 Dryer Questions Answers
Here is another Link!
Bosch Dryer Won Heat 3 min FIX
And yet another!
(DON'T waste your time with the FOUR oval Links to the right! )
Dec 22, 2017 | Bosch Nexxt WTMC 6300 Electric Dryer
My electric dryer shuts off after about 20 minutes of drying
ok sounds like you are using dryer sheets,,,dryer sheets coat the automatic dry sensors and fool the unit into thinking the clothing is dry,,,,replace the sensor or try to clean it if possable with a green scrubbie,,,,also try the time cycle it dose not use the sensor.......www.myabcspace.com/washerwizzards
May 17, 2010 | Dryers
Maytag LDG 712 shuts off before clothes are dry.
First, The most common part would be the over limit safety, it will be mounted to the element housing. Second, there is a thermal fuse usually a small disk with a little fuse inside. You can find these (with your model no.) at www.Repairclinic.com .Good luck.
Apr 20, 2009 | Whirlpool LER5636P Electric Dryer
Maytag Neptune MDG 5500 AWQ heats sporatically
your dryer has a safety feature that it will not run or heat when the door is opened. It is so no gas fumes are exhauseted into your home. Once the safety is engaged, It will not allow the dryer to restart for a short while. It should clear itself after only a few minutes. Hope this helps, good luck.
Apr 18, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Shutting off every 20 minutes
Your thremal fuse is getting hot. OR There are overloads attached to the element housing and one of them is getting hot and automatically resetting itself once it is cooled.
Apr 17, 2009 | GE Profile Harmony DPGT750EC Electric...
Kenmore Dryer Model 66801692
at leas 15 yrs old??? think it's done its time, its a great machine andwould reccomend replacing with a whirlpool/kenmore unit again.no tworth servicing in my opinion, average call here in new york 150-225, anbd those are for simple issues. id rather put money into new unit! bit be sure to check your venting id say 85% of dryers taking too long to dry are vent related issues
Nov 13, 2008 | Kenmore 62872 Electric Dryer
Dryer Rack
On mine, nothing "clamps down". There are 3 positions in the plastic rack into which you can insert the wire rest - "F", "H", and "A". God knows what they mean (I think the one rack is intended to be used in various dryers, of different depths), but if I use the rearmost position = "A", the back end of the wire rest rests on the non-moving rear of the drum, and the front of the rack rests on the lint screen holder. Seems to work, but the instructions leave a lot to be desired.
Dec 09, 2007 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
62 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
