Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Door opens and then closes wright away
I just changed the gears in the craftsman 1/2 horsepower opener and when I tried for the first time the door opens 2 feet and then closes right away.I tried all the adjustment screws and nothing seems to be working.Can someone please help.Thanks
  • lawnofficer Feb 27, 2009
    The main drive gear was stripped so I got a kit and replaced it, now the sprocket only turns a few revolutions and goes back again.
  • dsblox Feb 28, 2009
    I have the identical problem in the other direction (goes down 8 inches, up 8 inches and then stops). I just replaced the gears and reassembled the unit--so I must have put something back together improperly??? But it all looks right. What I've tried:
    * Light is not flashing so I don't think it is the safety sensors
    * I'm not even close to the limit contacts in either direction
    * Identical behavior no matter how I adjust up/down force in any combination.
    Any help would be appreciated.
I figured out that when I replaced the gears, I damaged the RPM sensor. It was easy to swap out the old for the new and now it works fine.
Posted on Feb 28, 2009
Don't know if this is everyone's problem, but it turned out to be mine. When I reassembled the opener after replacing the gears I had not properly re-attached the electrical connection to the limit switches. So it turned out to be "user error." After properly seating the electrical connector the opener operated properly.
Apparently, if the limit switches are not connected the garage door does what we've seen: move about 8 inches down, then 8 inches up, then flash the LED in groups of 5 blinks.
What does the purple button light flashing on 1/2 horsepower craftsman garage door opener
I think the adjustment mode is on.
For example, that's from Craftsman manual:
Setting the Force
The force setting button is located on the left panel of the motor unit. The force setting measures the amount of force required to open and close the door.
1. Locate the purple button on the left panel of the motor unit (Figure 1).
2. Push the purple button twice to enter the opener into Force Adjustment Mode (Figure 2). The LED (Indicator Light) will flash quickly.
3. Push the remote control or control console (Figure 3). The door will travel to the DOWN (close) position.
Actually, you should just read carefully your garage door opener unit's manual.
Craftsman Garage Door Opener Remote
Jun 21, 2014 | Sears Craftsman LiftMaster Chamberlain...
Have a Craftsman 1/2 horsepower garage door opener. When oporating the chain does not move so door will not open.
You have a bad drive gear. It is white nylon and is just in front of the motor. The part number is 41A2817 and is available at any good door opener service company. It comes with instructions.
Feb 06, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have the 1/2 horsepower opener with the green (Sears)
Sometimes the sensors will be aligned closely enough that the logic board will turn on the receiving units light but it will act like yours. If you look real close at the light you will see that it is flickering ever so lightly. Tweak the sensor so the light is on steady.
Nov 10, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener is malfunctioning
It sounds like the gear and sprocket assembly has gone bad. This would cause the symptoms you have.
Sep 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opens about 2 feet and then closes in same cycle
There is an issue with the limit settings. They are the three white screws you can see with the cover off. Put the door in the down position. take the small white piece off the bottom of the gear and sprocket assembly. Turn the center screw until the silver "wing" is at the bottom position. Put the white piece back on the bottom of the gear and sprocket. Adjust the up screw until the door opens fully. Check the force settings. They both should be set on 4-5.
Feb 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
Only opens when remotes are close
The problem is in the receiver on the logic board. You will have to replace the logic board. You can get a replacement part at searspartsdirect.com. Thanks BB
Feb 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 1/2 horsepower not working
Five flashes indicates possible RPM sensor failure. First try unplugging opener for five minutes and plug back in. If it still does not work replace RPM sensor.
Jan 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
Changed gear box in craftsman garage door opener
you did not give enough info. If it closes completely and right away goes up, if bulb blinking. if it is, something on door is blocking safety beam. If light is not blinking, DECREASE down travel.
Jan 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain 1/2hp won't open/close and learn LED flashes 5 times
The gear needs to be changed kit #41c4220a. Be sure to change the bottom bushing on the motor mount.
Jan 02, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman GDO Will not close
readjust the sensor controls on the side of the unit
Dec 28, 2007 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
220 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
