Question about Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41)
I have a BEFSR41 and all the lights on the front are light up it says it is connected to the internet but it says it cant find the internet
  • 1 more comment
  • Karleab Mar 30, 2009
    I have two computers I want to hook up to the internet. The 1st computer is hooked up to Comcast modem. I followed all the instructions. Went to the website for the DHCP address. I unplugged the modem, router and reset the router. When I plug everything back in, still no internet on either computer. I have the modem plugged into the incoming line, modem line to the router (WAN) and the two computers plugged into #1 and #2 ports on the router. Still no internet. I called comcast and they tell me this should be working, but wouldn't you know it, it's not. I must be doing something wrong. Can anyone help....maybe step by step instructions? lol Thank you!
  • Chuck May 11, 2010
    unplug the cable modem wait 10 seconds plug it in. Now do same thing for the router.
  • Mr fix.it May 11, 2010
    you will ned to login the router and check the configuration through the HTTP setup page inbuilt in the router. Do you have the manual of this router a hand ?
My problem is my roueter can not be recognize. no router connected
Posted on Mar 23, 2009
I have a WRT54G router and want to daisy chain a Linksys BEFSR41 switch off it, but I seem to be doing it wrong...
Not sure if you just want to expand the amont of computer you can connect to it or the wireless range but I would setup the BEFSR41:
  • Disable DHCP
  • Set an address out of the DHCP scope of the WRT54G
  • Connect them LAN to LAN if not use xover to connect them
Aug 27, 2010 | Linksys Wireless-G WRT54G Router
I have a linksys router. model number befsr41 v. 3. i have a acer computer and some reason it wont recognize the network, calling it unidentified network, and internet does not work.. what do i do
The first thing is that the router model number you have is not a wireless router.
Now if you are connecting the computer to the router with the Ethernet cable then check the port light on the router. If you connect the computer to the port number 2 then port 2 light should lit up on the router.
Now check the IP address on the computer. If you are not getting proper IP address then check the DHCP server on the router is enabled.
If that is enabled and still not getting the IP address then assign a static IP address on the computer.
Click Here for more information about router and network
Feb 23, 2010 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
I set up my lynksys befsr41 ver4.1 using the set up disk. I hit enter at the password window and it goes to analyzing my computer. Then the password window shows up again etc. etc. etc. At the lower left I...
Are you trying to install the router.
You can do it manually without the CD.
First reset the router for 30 seconds. unplug the power to the router. wait for 5 seconds. Plug it back in.
Make sure that your computer is able to go online through the modem.
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Jan 14, 2010 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
When I turn on my BEFSR41 the POWER and PORT #4 lights up even though nothing is connected to it yet... what seems to be the problem?... is it defective?
If you are using the Uplink port, this may cause port 4 to show active. Disconnect the Uplink cable to see if the light goes out. If it doesn't, then yes, it sounds like you may have a bad port on your router.
Aug 30, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Internet wont work thru my Linksys BEFSR41 Cable/DSL Router W/4 Port Switch.....can i fix it or do i need a new one?
hi there, you need to configure the router first to connect over the internet.
checked if everything is properly connected, modem-router to the computer, checked the lights on the router and the modem as well if it is properly lit up.
if your ISP(Internet Provider) is cable then you need to clone the mac address of the computer, if you are running DSL, you need to input the username and password of your account from your ISP.
Accessing the router setup screen, open IE and type on the address bar 192.168.1.1 then nothing for username and password is admin.
on the setup screen you will see there Internet connection type, by default it is automatic configuration if you have cable connection as your Internet then leave it that way and look for mac address clone sub tab.
if you are running dsl for the Internet connection type you need to put PPPoE and input there your username and password from your ISP. then in everything you do you need to save the settings there.
tell me if it
Jun 26, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
My linksys router keeps dropping connectivity to the internet
does your router and your landline phone is in one connection in with a splitter..
does connection failed whenever there's a call?
if so your splitter might be broken
or you must insert your phone line with the splitter, it might be in your connection set up..
or make sure your utp cable is stable and not in exposure area of people or pet where it might be touch or something..
hope this helps...
Jan 13, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Cant get to internet thru linksys etherfast cable/dsl router
Reset the modem while the router is plugged into it. Do this by disconnecting the power to the modem and then reconnecting.
Nov 09, 2008 | Linksys EtherFast Cable/DSL Router
Router problems
try to check your cables .and connections.
Mar 10, 2008 | Computers & Internet
Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41) Logo
181 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
