Question about HP DeskJet 920c InkJet Printer
HP 920C no longer prints color
I have:
(1) downloaded new software
(2) changed out color ink cartridge
(3) cleaned cartridge holder
(4) cleaned ink passage orifice
What else do I check? How would I check electrical connections/contact?
Does ya thinks the issue is mechanical?
I have lots of ink for this printer -- it is used at a community center by middle school kids.
thanks for answering this request for information
Dennis
Dear ok_ME_3,
i have the 2610xi photosmart and i have teh same problem. it is a mecahical problom, and needs a new ink cartrige slot. i took it to geek squad and they fixed it for 10.00. I hope this works for you.if not, i would recomend an epson printer for your next prnter.
Thanks,
Matt MAlhiot
matt555@rocketmail.com
Posted on Feb 26, 2009
How do i reset ink cartridge cl511for my canon ip2700
1. Make sure that the power is turned on.
2. Open the Front Cover.
The FINE Cartridge Holder moves to the replacement position.
3. Remove the empty FINE Cartridge.
(1) Pinch the tabs and open the Ink Cartridge Locking Cover.
(2) Remove the FINE Cartridge.
4. Prepare the new FINE Cartridge.
(1) Take a new FINE Cartridge out of its package and remove the orange protective tape (C) gently.
5. Install the FINE Cartridge.
(1) Put a new FINE Cartridge in the FINE Cartridge Holder.
The Color FINE Cartridge should be installed into the left slot and the Black FINE Cartridge should be installed into the right slot.
(2) Close the Ink Cartridge Locking Cover to lock the FINE Cartridge into place.
Push down the Ink Cartridge Locking Cover until it clicks.
(3) Confirm that the Ink Cartridge Locking Cover is closed correctly.
6. Close the Front Cover.
Sep 20, 2011 | Canon Office Equipment & Supplies
Color printing problems
check the in printer settings about printing with color, and also on the pc side make sure its not set to black and white only.
Jun 20, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
How do I load the ink cartridges into the Canon Pixma printer MX320?
1. Make sure that the power is turned on, and open the Paper Output Tray.
2. Lift the Scanning Unit (Cover), then hold it open with the Scanning Unit Support on the right side.
3. FINE Cartridge.
(1) Take a new FINE Cartridge out of its package and remove the orange protective tape gently.
The Color FINE Cartridge should be installed into the left slot and the Black FINE Cartridge should be into the right slot.
(E) Closed correctly
(F) Not closed correctly (the cover is tilted)
6. Lift the Scanning Unit (Cover) slightly to set the Scanning Unit Support back to its original position, and gently close the Scanning Unit (Cover).
Oct 05, 2010 | Canon Office Equipment & Supplies
How do I change the ink cartridges in my Canon MP480? rn_bluediamond@yahoo.com
Step 1
Protect your desk, printer stand or work surface by placing an old newspaper in front of or next to the printer. The newspaper will provide you with a place to work without getting ink anywhere you don't want it. It seems as though no matter how careful or neat you are, a little bit of ink always manages to escape when replacing an ink cartridge.
Step 2
Prepare the new ink cartridge for installation. Remove the replacement cartridge for your Canon printer from all of its packaging. You may need scissors to remove the heavy wrapper. Leave the protective orange cap or tape in place for now. Set the new cartridge aside on the newspaper.
Step 3
Remove the old ink cartridge from the Canon printer. With the printer on, open the front door or panel of the printer. Wait a second or two and the ink cartridge holder should move to the opening where it is accessible. If it does not move, shut the door, turn the printer off for a moment, turn it back on and try again. Lift the small lever that secures the ink cartridges within their holder. On most Canon printers, it is colored green and located on the right side of the ink cartridge holder. Gently lift the old ink cartridge out of the printer.
Step 4
Place the new ink cartridge in the printer. Remove the plastic cap or tape protecting the ink cartridge, being careful not to touch the black and gold "sensor" area of the cartridge. Gently but firmly push the new cartridge into the empty slot left where you removed the old ink cartridge. The label should be facing outward. You should feel the cartridge pop into place. Then push the lever back down that you lifted in Step 3. Close the printer door. Use paper towel or wet wipes to clean any ink from your hands
Aug 11, 2010 | Canon Pixma MP480 All-In-One InkJet...
How do i change ink cartridge
While cartridge installation varies somewhat between brands and models, these general instructions apply to most major brands:
Purchase an ink cartridge made specifically for your printer.
  • Step 2 Turn on your printer and raise the lid or press the cartridge changing button.
  • Step 3 Wait for the cartridge carrier to slide out.
  • Step 4 Put your finger behind the ridge on the top front of the old cartridge and pull it toward you to remove. If you have an Epson printer, lift the cartridge holder lid, and the cartridge will pop up for removal.
  • Step 5 Carefully remove the tape from the ink opening on the bottom of new cartridge.
  • Step 6 Insert the new cartridge into the cartridge carrier. Make sure the new cartridge is oriented the same way that the old cartridge had been.
  • Step 7 Feel and hear the cartridge click into position. On some models, arrows will indicate the cartridge is correctly positioned.
  • Step 8 If you have an Epson printer, close the cartridge holder lid and press the cleaning button to charge the cartridge.
  • Step 9 Close printer cover.
  • Apr 21, 2010 | Epson Stylus CX6000 All-In-One InkJet...
    How do u change the ink in the epson 6000?
    Things You'll Need:
    • Replacement cartridge (black, cyan, magenta, or yellow)
    1. Step 1 Turn on the printer and press the Color button.
    2. Step 2 Lift up the scanner and wait for the ink cartridge holder to move into position. Remove the ink cartridge holder's cover.
    3. Step 3 Push the tab at the back of the empty ink cartridge to free it from the cartridge holder. Lift the empty cartridge out and dispose of it.
    4. Step 4 Prepare the replacement cartridge by shaking it gently while still in its packaging. Remove the cartridge from its wrapper, taking care to hold it by the sides.
    5. Step 5 Insert the replacement cartridge into the appropriate slot of the ink cartridge holder. Push down on the replacement cartridge until it clicks into place.
    6. Step 6 Close the cartridge cover and lower the scanner until it clicks into place. The printer is now ready for operation
    Nov 15, 2009 | Epson Stylus CX6600 All-In-One InkJet...
    Changing color cartridge on my epson stylus color 980 printer.
    If you need to replace an ink cartridge in your printer, please follow the instructions below:
    To confirm which ink cartridge requires replacement, please use the printer's control panel (there is a black ink out indicator, as well as a color ink out indicator ), or the Status Monitor in your computer.
    Red light flashing - Low ink
    Red light solid - Out of ink
    1. Open the printer cover and press the INK (Cleaning) button for 3 seconds. The print head moves to the center and the lights flash.
    2. Lift up the ink cartridge clamp. The cartridge rises up from its holder.
    3. Remove the cartridge and dispose of it carefully. If ink gets on your hands, wash them with soap and water. If ink gets in your eyes, flush them immediately with water.
    4. Unpack the new ink cartridge and remove the yellow tape. You must remove the yellow tape from the top of the cartridge. Do not remove the clear seal underneath the cartridge. Do not touch the green circuit board on the back of the cartridge, or you may inhibit normal operation and printing.
    5. Tilt the new cartridge toward you slightly as you insert it. Lower the cartridge so that the tabs rest on the hooks. Do not place the cartridge tabs under the hooks.
    6. Press down firmly on the ink cartridge clamp until it snaps in place.
    7. If you need to replace the other ink cartridge, repeat steps 2 through 6 before continuing with step 8 (to move printhead over to color (if black was replaced first) press the cleaning button once).
    8. Press the INK (Cleaning) button once, and close the printer cover. The printer begins charging the ink delivery system.
    9. Wait until ink charging is finished (the power light stops flashing and the red error light goes out).
    May 11, 2009 | Office Equipment & Supplies
    Ink problems....
    Take all carts out of the machine. Have a look into the cart holder. Is there ink swapping beneath the white plastic? (You might shake the machine ;-)
    If yes, the cart holder leaks and needs replacement.
    If not (your lucky!) it could be that the automatic cleaning procedure which starts when a cart is changed has soaked the carts empty.
    Do set machine with date and time and NEVER unplug NOR use a power switch which breaks the power supply.
    Do use constant power and switch off machine by pressing stand-by-fax-button!
    Everytime when machine comes to (new) power contact it runs an extensive ink cleaning procedure. thats why your carts are always near empty....
    The stand-by will prevent this and machine does some cleaning procedures which consumes only a few drops(!) of ink!
    The display asks you if you have changed the carts. Do answer this question by pressing 1 for YES or 2 for NO.
    This will reset the built-in inkcountermanagement to the correct settings
    Jan 22, 2008 | Brother MFC 210C All-In-One InkJet Printer
    Dell color cartridges
    this sounds wierd to tell you
    take out the cartige and if you can take out the cartige holders ( try to reach for the place where the ink flows out) spray it with a glass cleaning solution and let it pass inside where the ink pases and believe it or not it will clean properly the ink passages. try to clean the bottom of the cartige too.
    some 1 trid it infront of me and it worked.
    ps: an unproper positioning of the cartige will cause the printer not to work.
    Nov 09, 2007 | Dell 924 All-in-One InkJet Printer
    The color ink in my hp deskjet 920c won't work
    try cleaning the contacts (bronze like) with dry cloth both the cartridge and the cartridge holder most of the times there exist some liquid forms on both areas. since you frequently remove the cartridges; their might be a broken part on the cartridge holder. the broken part, use, is to make sure the cartridge is in absolute contact with the cartridge holder's. the size the said broken part is 2 mm in all sides. so small that it has a big function.you dnt even recognize.
    Nov 07, 2006 | HP DeskJet 920c InkJet Printer
    HP DeskJet 920c InkJet Printer Logo
    144 people viewed this question
    Seeker5211
    Seeker5211
