Question about Microsoft Windows Vista Ultimate Edition
Usb drive not visible
When i plug in the usb it shows "installin device driver",but it is not visible in my computer.
  • 54 Answers
Whatever you are trying to plug is not recognize. Go to the manufacturer and get the driver for it
Posted on Feb 27, 2009
Toshiba 500gb hard drive is not visible on my computer, the hard drive has a light but it is not showing on my computer
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
hope this helps
Sep 03, 2012 | Computers & Internet
I am trying to download movies off my friends portable hard drive onto my laptop but when I plug in my friends hard drive into my laptop, my laptop don't recognize it and nothing comes up???
Your laptop's usb port may not have enough power to keep the portable hard drive running.
You may require additional power to the portable hdd by using a usb cable with 2 usb connectors.
or use a USB port that is powered.
Mar 03, 2011 | Computers & Internet
I have a Iomega 500G portable hard drive RPHD-U, when I plug the USB 2.0 in I hear a clicking noise on my HP computer. The portable haed does not show up in the my computer devices. This device use to be...
Hello
At the link below you will be directed to a tip i wrote on this exact issue. Click on the link below to navigate to page.
Click HERE.
Please feel free to let me know if you need any further assistance.
Thank you for using Fixya!!
Kind regards
Lock123
Jan 08, 2011 | Iomega eGo Portable Hard drive 500 GB ...
I have a WD 750 GB External USB drive which has worked flawlessly. However, now when I plug it into a usb port, the computer does not detect it and it does not show up under "computer". I've...
This is not a driver issue. Im assuming this is a passport. There could be a problem with the enclosure, however if it is a passport removing it from the enclosure will do you no good. More than likely there is a problem with the drive, possibly in the firm wear or a module. Either way it appears to be a hardware issue with the drive not your computer. USB plug and play should recognize it automatically without the need for drivers, especially if your device manager is recognizing it properly then the driver is not the issue.
Nov 11, 2010 | Western Digital Accusys ACS-7500 IDE...
Hai mr.igot problem when i install usb bf-810 iwas isntal driver but when i plug the port inthe PC it's show"USB devivice not recognice"can u solve my problem
Before you start installing the driver, please don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® 98 or Windows® ME driver 5.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 5.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 5.3 Select the “Next” to install.
Before you start installing the driver, please don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® 2000 driver 6.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 6.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 6.3 Select the “Next” to install.  Before you start installing the driver, please Don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® XP driver 7.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 7.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 7.3 Select the “Next” to install.
.1 Driver Installation (MAC OS X) 8.1.1 Power on your computer and make sure that USB port is enabled and working properly. 8.1.2 Insert the USB adapter software driver into CD-ROM driver. 8.1.3 Click "USB-SERIAL ADAPTER\DRIVER\MAC\OS X " folder run on "PL2303_1.2.1r2.dmg", it will auto run the program and appear "PL2303 driver" folder in the desktop. 8.1.4 Click on "PL2303 driver" folder , execute "USBSerialOSX1.0.9b6.pkg" will auto install, you may change the driver directory that you want to install. 8.1.5 System will demand restart computer. 8.1.6 Plug in the USB-Serial adapter into USB port. 8.1.7 To make sure that your computer can use the device, you have check the "Apple System Profile"-"Device and Volumes". It will show the USB Device.It will show in USB port "USB-Serial Controller". 8.2 Driver Installation (MAC OS 8&9) 8.2.1 Power on your computer and make sure that USB port is enabled and working properly. 8.2.2 Insert the USB adapter software driver into CD-ROM driver. 8.2.3 Click "USB-SERIAL ADAPTER\DRIVER\MAC\OS_89" run on "PL2303_OS9_v136b1.hqx",it will auto run the program and appear "ProlificUSBSerial" file. 8.2.4 Copy "ProlificUSBSerial" file into "system folder"-"Extension". 8.2.5 Plug in the USB-Serial adapter into USB port. 8.2.6 To make sure that your computer can use the device, you have check the "Apple System Profile"-"Device and Volumes". It will show the USB Device.It will show in USB port "USB-Serial Controller". Follow the steps below to install driver of USB-Serial adapter:
hope that helps you
May 29, 2010 | BafoTech BAFO BF-810 Serial Adapter
I want install my hard drive external to my compute
External devices I am familiar with come with a installin CD and/or Plug and Play.
It should be a simple matter of plugging the USB cable into your computer and starting everything up.
If you need the installing CD, Please visit the manufacturers web site (you dont mention the make or model, or I would have given you the link)
Thanks for using FixYa.com
Please vote
thank you
a
Nov 11, 2009 | Computers & Internet
Connect external hard disk IBM travel star 80GB USB port 2
Unless it's windows 98 you don't need a driver. If your computer can't see it, it's probably broken. Try plugging it in to another computer and see if it can see it
Oct 01, 2009 | IBM TravelStar 40GN 40 GB Hard Drive
Installin xp also
You have to install the software driver/s (thru your CD/DVD drive / internet download): of your computer motherboard to enable its system devices like audio, USB etc.... driver for VGA card, Printer driver & other software that you want to use in your computer. best regards
May 16, 2009 | HP FK784AA Pavilion Slimline s3650f...
SimpleTech 250GB External Hard Drive Installation problem
I suspect it's not getting enough power from the USB cable. Might need external power.
Dec 06, 2007 | SimpleTech SimpleDrive 250GB, 7200RPM,...
Microsoft Windows Vista Ultimate Edition Logo
55 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Brian Sullivan
Brian Sullivan
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
