Question about GE GSL25JFPBS Side by Side Refrigerator
GE SxS GSL25JFPABS freezer will not freeze
The freezer on this unit will only maintain a 30 degree temp on coldest setting. I've cleaned everything I could get to behind and underneath. Even though it will not get any colder, the defrost system is still working because you can see the red glow in the back of freezer. It will go off, but I'm wandering if it comes on, or stays on too long?
  • 4 Answers
Model # gsl25jfpabs if you have this problem then i will tell you how to fix it with out all the bull. my fridges water dispencer stopped working (i could hear it trying with the buzz buzz sound when i pushed the lever) and water was leaking fron the drain pan down the front door. the fridge side was warm at the top and the bottom was cooler. the freezer side was cool at top and cold at the bottom. I pull the bottom crisper drawer out of the fridge side and felt the coiled up white water line mounted to the back and it was frozen. The fix was the motherboard located on the back of the fridge. unpluged the fridge for at least a couple hours to melt any unseen ice(i know this sucks, i lost a ton of food too) 1/4 inche bolts hold a 8x10 metal plate on. take it off slowly. there will be 4 little white pointy clips that you have to squeeze with needle nose pliars, unplug the wiring harnesses(dont be scared there is not hidden clips they just un pluge pinch and pull) and call the local appliance parts store with the model number. should be about 170 bucks. put it back in /(every thing will only plug in where it goes so dont worry about crossing wires) and you'll be good to go in a few hours.I hope this helped. It worked for me and i save myself over 200 in cash for service calls. takes longer to go get the part the it does to repar the problem. good luck.
Posted on Sep 28, 2011
    Scholar:
  • 85 Answers
When the refrigerator is running ( cooling mode ) the defrost timer contacts prevents any power from getting to the defrost heater. When the defrost timer turns off the power to the compressor and fan motor(s) the power is then redirected to the defrost system. The defrost timer motor
Defrost thermostat:
During a defrost cycle, the defrost heater causes the metal alloy in the switch to warm and as it does it curls back and breaks the circuit. As the metal cools, it makes a closed circuit again. A defective thermostat can prevent the defrost heater from coming on or allow it to overheat which could result in heat damage or fire.
The defrost thermostat is located near the defrost heater and is wired in series. It is usually located at the back of a side by side freezer, behind the freezer back wall of a top freezer or under the floor. It will be necessary to remove obstructions such as the contents of the freezer, freezer shelves, icemaker and the inside rear or bottom panel of the freezer. At room temperature the defrost thermostat is an open circuit ( no continuity ) and when cooled down the defrost thermostat closes the circuit ( has full continuity ) to allow the defrost heater to come on.
Posted on Feb 26, 2009
I want my frig to be 33 degrees
...???.. why.. it will freeze almost everything...my temp is 36* and if I leave a pitcher of tea for three days.. the top is 1/2" thick with ice..it freezes lettuce if its anywhere but the door... 33* is too cold for a refrigerator/freezer. My (GE) settings are from 0 (off) 1-7..7 being coldest.. I run mine on 1 except for July-August... then on 2.. and it freezes almost everything...(guess I have a good one?!)
Make sure the seal is good and its CONTACT SURFACES ARE CLEAN and the sealing area is not obstructed..
Aug 29, 2017 | Refrigerators
We just bought a GE gbe21dgkarww we are having trouble wth the crisper, they are freezing my fruit and vegetables. Temp. Cool on freezer on coldest
Fridge temps are actually cooled by the freezer,try turning freezer temp down somewhat-and I highly recommend buying a fridge thermometer,generally speaking I try to keep my fridge at about 34-35 degrees,you can go SLIGHTLY higher,is fridge section directly over freezer??
May 09, 2017 | GE Refrigerators
On my GE GTH21SCXSS, top freezer bottom refer, the freezer and refrigerator settings are on the coldest settings and the freezer won't go below 15 degrees and the refer won't go below 43 degre
Do you see any ice buildup on the back panel of the freezer? You may need to remove the back panel to see if the coils are iced over. Post back your results.
Feb 10, 2013 | GE GTH21SCXSS Stainless Steel (21 cu ft)...
I have a Kenmore bottom freezer fridge. Can't find the manual. Is 7 the coldest setting or 1? We keep the fridge in our garage and with the artic temps we are having we need to adjust it.
most refr's dont so well when the ambiant temps fall below 50 degrees. you should not need to adjust the controls must past the "midpoint" usually 4. but 7 is the coldest setting.
the best thing you can do is check what the actual temps are in your garage and if you can warm it up to above 50, then the unit should run properly again.
if the ambiant temps are too cold, the freezer wont be cold enough and the refr section will freeze things.
Jan 06, 2010 | Refrigerators
My GE side by side has started freezing everything in the refrigerator on the warmest setting and the freezer will not maintain less than 10 degrees on the coldest setting. Any ideas?
on the left side of the crisper drawer there may be a air return hole that you can adjust, if not try some duct tape where the air comes into the fridge, cover it by 1/4 then 1/2 till it is the right temperature
Aug 04, 2009 | GE Refrigerators
Freezer freezes, refrigerator is 55 degrees
All refrigerators also have a return air vent. You need to make sure this is not blocked by frost, the units own foam insulation or even by product placement. You should find it behind the crispers in the bulkhead between the freshfood and freezer compartments. You also want to verify the supply duct behind the damper is not blocked.
May 03, 2009 | Refrigerators
Top mounted freezer on refrigerator not working
Move the refrigerator to a room that is at least 50 degrees F.
Temps on most refrigerators are regulated by the fresh foods temp. If your garage is let's say 35 degrees, the fresh foods temp will most likely never raise enough to turn the refrigerator on. With the refrigerator never running, the freezer compartment will warm to 35 degrees, resulting in everything melting. Even if garage is a bit warmer, say 45, the refrig will not run long enough for the freezer to maintain a low enough temperture. If the garage temp falls to below freezing, say 20 degrees, the food in the fresh foods compartment will freeze. (outdoor beverage dispensers have internal heaters to prevent product from freezing !) Please don't rate this if not a Fix-Ya for you, as anything else lowers my score.
Jan 22, 2009 | Frigidaire 5 cu. ft. / 142 liter Chest...
GE sxs Not Freezing
See if freezer fan is running when the unit is on. If you hear no fan when it's running. You probably need an evaporator fan motor.
Also check for ice or frost build up around fan.
Nov 12, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSL25JFPBS Side by Side Refrigerator Logo
759 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
