Question about E-Machines eMachines Desktop PC
Black screen I guys, whar I start my pc, everything starts normaly, I see my desktop appear ad then the screen turns to black, but the led of the monitor stays blue (on and rfeceiving a signal). If i play with the button, onoff-on-off a couple of times I can get acouple of minut of screen back, but returns to black right after. what's my problem????
  • 2 more comments
  • b_robit Feb 26, 2009
    Ca n'a pas fonctionner :S
  • b_robit Feb 27, 2009
    It Didn't work:S
  • AngieB34 Mar 01, 2009
    After the initial setup and I get to my desktop the Tools config box pops up and started downloaded. It gets to 4 out of 7 steps and the screen flashed and goes to black. I was told it was the video driver that may not be compatible with my monitor. There is no books or CD to try and load other video drivers.
  • soniaeloy17 May 16, 2009
    i have a 1905 emachine black screen, power, but computer itself seems to not be booting in
You might have to connect to a different monitor. I found out that the drivers were set to high of level for the monitor. Once I found a monitor that it would come up on, I changed the driver to 800 X 600 pixels and everything is fine.
Posted on May 15, 2009
    Scholar:
  • 85 Answers
Unplug evry thing and check out the cmos battery on *********** board .remove that cmos battery and reinsert that.also remove the ram (the memory)from the mother board and refit it properly and then reconnect every thing as it was and start the pc it will work.
Posted on Feb 26, 2009
MY DELL DESKTOP WILL NOT REBOOT OR START
Try to replace the ROM. Also, try adding a new hard drive. See what happens.
Jan 24, 2014 | Dell Computers & Internet
Acer desktop power button faillure and STOP: c00021a BSOD problem
Can you do a system restore/recovery? Try boot to "last known good configuration" ? Have you added any new hardware or software?
Jan 07, 2013 | Computers & Internet
Black Screen of DEATH
well try finding someone who repairs coumpters from their home it is alot cheaper. explain your problem they should tell you weather they can fix it
Jun 30, 2012 | IBM NetVista PC Desktop
When I turn on my laptop, the screen will turn black then I had to move the screen back and forth to get the screen working
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Mar 11, 2012 | ASUS Eee PC 1005HA-PU1X-BK Netbook
When booting up after the logo the computer goes to black screen. There are no beeps at start up. When starting in safemode it stays with black screen with the safe mode written in the corners
In safe mode try pressing ctrl+alt+del, then go to task manager-->applications-->New task, then type: explorer.exe Now your desktop should appear. you could also try running: msconfig In the same way, and see wether explorer.exe is still in the startup. Adding it again will permanently solve your problem. I hope this helps, Yannick.
Jun 13, 2009 | Dell Dimension 4400 PC Desktop
HP laptop does not start.LED on.black screen "warning-battery low
Im not sure but there is normally a button somwhere on the laptop which acts a a reboot button. normally very small and have to press it using a pin etc. You could try that then turn it on but not sure if it will help?
Jun 12, 2009 | HP Pavilion a305w (DM181AR) PC Desktop
Dell Inspiron 6400 PC Notebook shows black screen after startup
I have a Inspiron 530 when I turn on it you can see that everything start ok but before I type my password everyting turn black an the only you can see is the litlle white arrow of the computer mouse
Jan 01, 2009 | Dell Inspiron 6400 Notebook
Black screen with only mouse pointer
well try to start pc in safe mode you can do this by pressing F8 key at windows startup after this remove your display(VGA) driver from device manager and then try to start window normaly if its start normaly then you have problem with your VGA.
And if its does not work then try to reinstall your windows
some times Asus and Msi motherboards have this problem,do nt know wthats is yours
hope you have got answer
regards,
Ali
Oct 30, 2008 | Computers & Internet
Screen is blank or black
it maybe sounds a little like a problem in explorer.
try to start you computer up, press F8 within the windows loader appears. then select :start up the same way as last time it worked.
now it should work. if not then format the pc.
if you have a lot of important stuff on it you can download the ubuntu livecd and use it the get all of your stuff out of the disk.
hope that works.
CS.
May 15, 2008 | IBM ThinkPad A21m 2628 Notebook
E-Machines eMachines Desktop PC Logo
95 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
