Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Garage door opens about 2 feet and then closes in same cycle
I just changed the gears in the craftsman 1/2 horsepower opener and when I tried for the first time the door opens 2 feet and then closes right away.I tried all the adjustment screws and nothing seems to be working.Can someone please help.Thanks
  • 118 Answers
There is an issue with the limit settings. They are the three white screws you can see with the cover off. Put the door in the down position. take the small white piece off the bottom of the gear and sprocket assembly. Turn the center screw until the silver "wing" is at the bottom position. Put the white piece back on the bottom of the gear and sprocket. Adjust the up screw until the door opens fully. Check the force settings. They both should be set on 4-5.
Posted on Feb 26, 2009
What does the purple button light flashing on 1/2 horsepower craftsman garage door opener
I think the adjustment mode is on.
For example, that's from Craftsman manual:
Setting the Force
The force setting button is located on the left panel of the motor unit. The force setting measures the amount of force required to open and close the door.
1. Locate the purple button on the left panel of the motor unit (Figure 1).
2. Push the purple button twice to enter the opener into Force Adjustment Mode (Figure 2). The LED (Indicator Light) will flash quickly.
3. Push the remote control or control console (Figure 3). The door will travel to the DOWN (close) position.
Actually, you should just read carefully your garage door opener unit's manual.
Craftsman Garage Door Opener Remote
Jun 21, 2014 | Sears Craftsman LiftMaster Chamberlain...
Craftsman garage door opener problem
If you have eliminated the obstruction sensor, I would suggest a few things. Is the door spring set at the proper tension - usually check by releasing the door safety and manually closing/opening the door. It should balance about halfway up/down. Openers have limit switches for travel, if one is incorrectly positioned or faulty, it can cause similar issues. Openers have torque limit controls, if the motor thinks it is working too hard it will stop. Is the door greased and moving freely when you manually tested it for the spring tension? Are the gear sprockets firm and greased?
Sep 22, 2017 | Home Security
My door opener is a Searcraftmans 1/2 hp. The door opens about 2 feet and stops. Press the button and it closes. Door moves freely when disengaged. Any suggestions
You most likely have a stripped drive gear. Remove the cover from the motor unit and it will be obvious if this is the case. It is a white nylon gear just in front of the motor.
Jan 24, 2011 | Sears Craftsman LiftMaster Chamberlain...
Have a Craftsman 1/2 horsepower garage door opener. When oporating the chain does not move so door will not open.
You have a bad drive gear. It is white nylon and is just in front of the motor. The part number is 41A2817 and is available at any good door opener service company. It comes with instructions.
Feb 06, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener is malfunctioning
It sounds like the gear and sprocket assembly has gone bad. This would cause the symptoms you have.
Sep 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door opens and then closes wright away
I figured out that when I replaced the gears, I damaged the RPM sensor. It was easy to swap out the old for the new and now it works fine.
Feb 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
Only opens when remotes are close
The problem is in the receiver on the logic board. You will have to replace the logic board. You can get a replacement part at Thanks BB
Feb 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
You say it only opens two feet?? Then closes?? If I may if you a little bit more costly option. Dont replace the gears. They used to be really good 8 years ago but the way they make the gears now there too soft and often strip out much faster. I would suggest that you do what we call a motor head change out. Take off your old chain drive motor head and buy a new one. Pretty simple. Two things though one always make sure you put the new one in with the door down. And the traveler in the down position ( The traveler is the metal thing hooked up to the chain) but far and your gear that you have it sounds to me that you dont have the gears close enough.. but 100 percent on that but a door should never close on it own. It's not safe.
Feb 09, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman GDO Will not close
readjust the sensor controls on the side of the unit
Dec 28, 2007 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
166 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Are you a Sears Building Material Expert? Answer questions, earn points and help others
