Question about IBM Lexmark Z715 InkJet Printer
Lexmark Z715 printer
Got Dell laptop w/ Vista
downloaded driver for Lexmark Z715 printer
not printing..but recognizes the printer...
1. is this a 32 bit vs 64 bit issue and if so..how do I resolve?
2. will this printer work w/ OS VISTA?
  • 3 more comments
  • miller_gray Feb 26, 2009
    ok...I'm a learning..........how do I find this out?
    ok....soon as I get home I'll try this...and once I determine if VISTA is 32 or 64....what would be my next logical step?
    oh...then down load the correct driver...right?
  • miller_gray Mar 02, 2009
    I've identified the I'm using 32 Bit Vista.
    Driver is downloaded
    PC "sees" the printer because it shows ink levels, etc..the printer will sound like it's going to print..but then it stops.
  • Mr fix.it May 11, 2010
    what is your operating system, is it 64 bit or 32 bit ?
  • 78 Answers
Ok so go to the control panel and there you should find an icon called system. double click on that and a screen with some details will come up. you should have system type and there it should tell you if its 32 or 64.
Posted on Feb 26, 2009
  • Mr fix.it Feb 27, 2009
    it depends because but if so follow the link below to access the driver required.
    Link
  • Mr fix.it Mar 02, 2009
    Ok then if the printer can be seen then the driver should be fine. Can you try printing a test page from the printers section under the control panel or else try printing using word or excel just to make sure its not a software issue.
    Thanks.
Describe your 946 All-In-One InkJet Printer Problem I'm running windows 7 on a Gateway laptop and managed to get it to print at one point but then installed some other items to get it to recognize...
This printer is not a wireless rpinter, so I guess you were trying to attach it to a print server of some type.
Try using these Recommended Wireless Router Settings,I use channel 11. I would make a new SSID to make connecting easier.
If your computer came with Windows 7, then follow the procedure below. If you upgraded your computer, the did you install the chipset drivers first. If using a Dell Computer that was upgraded, the desktop/notebook system utility and the chipset drivers need installed first or the rest of the drivers will fail to install. How to Download and Install Drivers in the Correct Order
First run Delete Print Jobs to remove any stuck print job in the queue.
Disconnect the printer.
Download and run the patch(printer cleanup utility) until it prompts you to restart your computer.
Restart your computer. Make sure the printer is removed.
Manual Printer Driver Removal
Download the Vista 32-bit drivers for Windows 7 32-bit or the Vista 64-bit drivers for Windows 7 64-bit. Install the Vista drivers in the Vista
Compatibility mode You'll get a message, the printer is not connected. Connect the printer at this time(powered on).
Links to the patch/drivers can be found at...
Dell 946 Photo All-In-One Printer owners thread (W7)
Virus programs and firewalls will block communications.
If you need more help, please post in the Dell Printers Forum
Rick
Aug 24, 2011 | Dell 946 All-In-One InkJet Printer
Good morning, I bought a acer aspire 7540G laptop with Windows 7, 64 bit. I connected the Lexmark Optra S 1855 printer with the USB but my computer cannot find the driver. Where can I find the correct...
You may click on the following links below to download the available printer driver for this printer model.
http://bit.ly/oLHVX3 - 64-bit PCL XL Emulation Print Driver Universal Print Driver
http://bit.ly/p0RF71 - 64-bit PCL 5 Emulation Print Driver Universal Print Driver
http://bit.ly/oOi99g - 64-bit PostScript Level 3 Emulation Printer Driver Universal Print Driver
For further assistance, please contact Lexmark Technical Support
Jul 26, 2011 | Lexmark Optra S 1855 Laser Printer
Won't communicate with windows 7 laptop. I have a dell inspiron laptop. Printer works with HP netbook, but not with laptop??
Use the Vista driver in Windows 7. Check if your Windows 7 is running on 32-bit or 64-bit operating system by going to Start menu > right click on Computer > Properties. Then, download the Lexmark Z600 driver at http://bit.ly/cd4MzI(for 32-bit) or at http://bit.ly/c4xCtN(for 64-bit). Execute the file and follow the instructions in the software. Thanks.
Sep 30, 2010 | Lexmark Z600 InkJet Printer
Is there any way to get Lexmark z600 working on win7? OS recognizes the printer but when one actually tries to print the printer goes offline. Are there any suitable drivers for my OS or I'll just have to...
There is no Lexmark Z600 driver specific for Windows 7, however, the Vista driver works. Check if your Windows 7 is running on 32-bit or 64-bit operating system by going to the Start menu > right click on Computer > Properties. Download the driver using this link: http://bit.ly/cd4MzI(for 32-bit) or this link: http://bit.ly/c4xCtN(for 64-bit). Execute the file to install the driver. If you need further assistance, you can also contact Lexmark technical support. Thank you for choosing Lexmark.
Sep 16, 2010 | Lexmark Z600 InkJet Printer
I just got a Pro 205 printer . The software that came with it microsoft dosn't recognize so I need one that microsft will recognize. Thank you. arrow13@verizon.net
Hi. There are Microsoft drivers available for download in the Lexmark website. If your using Vista or Windows 7, check if it's running on 32-bit or 64-bit operating system by going to Start > right click on Computer > Properties. Then click on this link to the Lexmark website. http://bit.ly/9faEwK . On the bottom of the page, you'll see dropdowns for Microsoft, Macintosh and Linux/Unix operating system. For Vista, choose Microsoft Vista for 32-bit or Microsoft Vista X64 for 64-bit. For Windows 7, choose Windows 7 for 32-bit or Windows 7 X64 for 64-bit. Download the Driver but not the Firmware update. Hope this helps.
Mar 15, 2010 | Lexmark Office Equipment & Supplies
Can't find disc
I suggest emailing lexmark and telling them u need a disc for a Lexmark X2550 printer. Maybe tell em yours didnt come with one when u bought it and be firm...or you can continue to try and download it from the internet.
Aug 23, 2009 | Lexmark X2550 All-In-One Printer
Printer wont install to laptop
hi... if u don't know the lexmark tech support #... its this: 1800 332 4120... or u can live chat online on support.lexmark.com
if u r the do it yourself type... go to www.lexmark.com. in the search box on top right corner type "x1185". click search. scroll downwards & click on download driver & select windows vista. before u start download check whether urs is vista 32 bit or 64 bit. right click on computer entry in start menu & click properties. check what it says there under operating system type: 32 bit or 64 bit. if its 64 bit... download vista_x64 driver from the lexmark site else select just vista. after download... comes the long process of installation which would take even more instructions. i think u can just call the tech support & it will be a first call resolution
May 21, 2009 | Lexmark JetPrinter X1185 All-In-One InkJet
Compatibility between new computer and potential new printer
the x5650 is compatible with XP, Vista and Vista 64
Nov 26, 2008 | Office Equipment & Supplies
I,m trying to get free downloads for mylexmark z715 printer.
Click the link below. Download your printer software & drivers for Windows Vista. Please read File Details before downloading files. Creat a folder on your desktop. Name the folder Lexmark Z715. Save your download to this folder. If you have a CD writer your can burn this download to a CD. Lexmark does not sell this software on CD.
http://www.downloaddelivery.com/en/cpddrivers/441.html
Before you install the Z715 software. Power off the printer, open Control Panel & open Add/Remove programs. If your printer & it's software is listed, try to uninstall programs. If the uninstall fails than just run the downloaded Z715 driver & software.
Good luck & best regards.
please vote...
Mar 06, 2008 | Lexmark Z715 InkJet Printer
IBM Lexmark Z715 InkJet Printer Logo
199 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
