Question about Vacuums
Replacing the bearing behind fan on a kirby heiritage II 2hd
Does the fan need to be removed before I can get to the bearing behind the fan cage? That would be my guess but have never torn one apart. A diagram of the way things go together would be nice!
  • Robert Pagliaroli May 11, 2010
    please provide your make and model
  • royzee May 11, 2010
    what is the make and model?
    Problem Solver:
  • 8 Answers
I don't know what model of Kirby you have but on all Kirby's that I know of you have to remove the fan.
Here are two vid's on fan removal for a generation series vacuum.
Posted on Mar 25, 2009
How to remove a Kirby Heritage II Armature
The armature that holds the fan on is reverse threaded. It turns to the right to remove it. You can put a nail or nail punch in the hole on the armature and tap it gently to the right. this should loosen it enough to unscrew. There's a washer, then the fan, and a spacer that fit over the shaft.
Sep 02, 2012 | Kirby Heritage II Vacuum
A Kirby Heritage II model 2HD Use and Care Manual
Hello, this is Ava with Think Crucial.
You may find the User's Manual for your Kirby model by clicking the link below.
http://kirbywhq.powweb.com/manuals/heritage2/18F36C000B8A1B4BC17B195AFA60B506/Heritage%202%20Manual.pdf
You can purchase a wide variety of high quality Kirby replacement parts for your Kirby vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Kirby
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Aug 31, 2010 | Vacuums
How do I get the case apart on my Kirby Heritage II (2HD) to replace the fan impeller? I can only find 3 screws holding it and there seems to be more.
From the rear, there are 3 screws on right and one on the lower left. There is 1 more on the front at the top just under the lamp.
You will also need to remove the safety switch - the plastic thing down and just right of the front screw. Take out the 2 screws. Pull the switch gently away from the case and try to get a look at how it's put together.
There is a bent rod inside with a plastic 'bar' holding it in. The flat end of the rod is on top - the round end at the bottom goes into a loop on a metal strip that is sticking out from the motor housing. By lifting up and wiggling, the rod will come out of the loop. Often, the plastic bar will come out and rod will just fall out. Just put the rod and the plastic bar back together (this is why you looked at it before). I tape the bar in place with Scotch tape or any thin tape and leave it that way.
The fan housing is sealed with caulking (or whatever the last person to service it used). A few raps on the side of the case with rubber mallet and/or sticking a thin putty knife in the joint should do.
You will need to scrape the joint clean and reseal it when you're done or it will blow dust like mad. Any caulking or gasket sealer will do. Just don't use high strength adhesive if you ever want to take it apart again without dynamite.
Btw, the fan pulley is a left-hand thread.
Oct 06, 2009 | Kirby Heritage II Vacuum
My Kirby 2HD has started making an odd roaring noise but still works fine. I have taken the front assembly off and cleaned and adjusted the roller and checked the belt. The noise seems to come from the...
It is quite possible, it just needs lubed. The motor comes in direct contact with dirt so, you have to make sure the front bearing has a drop of oil on it from time to time. If it starts to scream at you within one month, after oiling, the bearing needs to be replaced.
Oct 05, 2009 | Kirby Heritage II Vacuum
Looking for a manual for a kirby Heritage 11 modle 2HD
Hello
I did a search and found a very useful web site for owners of the same vaccum as yours im sure you will be able to get parts and possibly a manual, hope it helps
http://kirby-owners-club-shop.com/
Jul 23, 2009 | Kirby G6 Bagged Upright Vacuum
Old Kirby Heritage 2 (Model 2Hd ) won't power on
the power light is a 2 stepswitch make sure when u put yhe power head back on it is locking all the way back if so and not working the switch may have failed
Jul 10, 2009 | Kirby Vacuums
Kirby legend 11
Just got done fixing our Heritage II model 2HD, it had a dirty safety switch. Both the hose attachment and the roller housing depress a plunger to close the switch, thus sending AC to the motor brushes. You might want to try pushing this in and out repeatedly with your thumb, power removed of course, in an attempt to make better contact. If this works to restore power to the motor, it'll be just a short time before the problem repeats itself. You'll have to remove the switch to give it a thorough cleaning. I didn't have any contact cleaner handy, so I wound up using WD40. Hope this helps. Kevin H.
Apr 04, 2009 | Kirby Heritage II Vacuum
Fan and bearing replacement on a Kirby G6
if you run your vac to long after the fan is broke it will cause excessive vibration and the bearings can go out. in almost all cases i replace the fan only. most of the time if you have a bad bearing the vac will make a grinding noise. you can also tell a bad bearing by grabbing the belt pulley on the end of the fan and pull up and down if it moves alot then your bearing is also bad. you can get the bearings separate witout ordering the armature assy. when talking of replacing any of these parts besides the fan i would advise you to take your vac to your local repairman. working on motor parts of a kirby can get pretty involved. to replace the fan first take the housing off where your belt and brushroll are. you should then see 5 screws on the front of your kirby. remove all 5 screws. then remove the handle. at the very bottom of your handle you will see a piece that allows you to move the handle, on the back side of this you need to push in with your thumb and the handle should pull off. then you should see a plastic piece directly below that snaps into the top housing. remove the 2 screws from this. one where the cord boot is and one above your power drive neutral/drive lever. then under this plastic piece is 2 more screws on your top housing. when these are out your housing should pull off. if not then remove the bottom plastic housing of your outer bag. then go back and look at the front again and you will find since removing the top housing you have exposed 2 more screws in the front fan cover housing that also need to come out. after this pry this housing off and you should be looking directly at the fan. grab fan with pliers in one hand and with the other hand apply pliers to the silver belt pulley and turn this piece clockwise. it should unscrew and then you can pull your bad fan off and attach the new one. i hope this helps and remember its not as hard as i probably made it sound. good luck!!!!
Sep 24, 2008 | Kirby G6 Bagged Upright Vacuum
How do I change the fan on my model 2HD kirby
Generic problem for all Vacuums
How do I change the
posted by Rogor on Apr 18, 2008
How do I change the fan on my model 2HD Kirby
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
1st you need to remove the head with the revolving brushing by dialing off the belt and undo the Kirby lock @ the top o the bell housing. Remove the head and that will expose the fan and the fan housing. The fan housing is held on by a couple of screws and once you removed the screws then you need to separate the fan housing from the motor section, it is held on by a Kirby fan housing sealer that is clear – so try to separate the fan housing with a knife or screwdriver, once the fan housing is off the Kirby fan is screwed on I believe either clockwise or counter clockwise and un-screw the fan and follow the reverse situation on installing the fan but you need to use the clear Kirby Fan Housing Sealer to re-seal the fan housing and let it dry and wipe of the excess clear sealer before putting it back together again. Always remember on the Kirby vacuums – use genuine Kirby parts on the repairs, it does make a difference. Then go back and place the Kirby head back on the vacuum – lock it on place and then re-dial the belt onto the Kirby fan shaft, plug your vacuum in the wall outlet and test run the vacuum.
http://kirby.com Contact Us by Phone
United States and Canada 1-800-494-8586
Between the hours of 8:00 am to 5:00 pm EST
Monday thru Friday
www.A-1Vacuum.com 1-800-657-1874
Apr 18, 2008 | Vacuums
Vacuums Logo
150 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
