Most of the time, keypads and remotes are not compatible with other manufacturers. You would be better off getting a universal keypad, which should work. Double check the older opener to make sure it is on the list of compatible devices.
Also, make sure you check the balance of your garage door periodically to make sure your springs are counter-balancing the garage door properly. If not, the lifespan of the garage door opener will be substantially shortened. Click here for a
how-to video.
