Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Water leaking When I get water from the door dispenser, water leaks out from somewhere inside the refrigerator section. Took all the drawers out and can't figure out how to get the plastic cover off of the section where the water is coming from.
  • boyracerAU Apr 02, 2009
    Our GE Profile has a similar problem.
    I've had a look around the filtered water/ice cube outlet and it seems to me that in my case at least that it's only condensation on the external surface of the little flap that seals the aperture from which the ice comes out of the freezer compartment. There's so much condensation that drops eventually form and run down the ouside of the door.
    I'm not sure what the solution is. The 'leak' is quite intermittent, sometimes it's a solid drip, other times it's like there's no problem.
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 531 Answers
Water leaking in door or icemaker check water valve
Posted on Apr 01, 2009
Why do I get blobs of water on the inside of my salad drawer in my Fridgemaster. Fridge/Freezer
Leaking Refrigerators
I hear a lot of complaints from people that see water leaking into their refrigerator from seemingly nowhere. Water appears in different places and even inside or under a refrigerators that does not have a water or a ice dispenser! Frost free refrigerators defrost the ice that collects on the evaporator coil on the average of about every 8 hours so the water that accumulates during defrost has to go somewhere right?
APPLIANCE 911
Dec 15, 2015 | Refrigerators
Ice under the deli drawer
it could be that u have a leak.. sometimes this happens when to much water is delivered to the ice tray and it overflows a little leaking into fridge. if that is happening then u most likely have a problem with the water inlet valve at the back of fridge, u can buy the part on line at appliancepros.com. good luck
Apr 13, 2014 | GE Refrigerators
Samsung french door refrigerator ice maker no dispenser defroster leaking water into bottom and produce drawers
If it is a frost free unit the water collects in a well at the compressor , there is a heater element in the well that boils off the water , this is were the fault is.
Jun 04, 2017 | Samsung RF217ACPN - 20 cu. ft. French Door...
Formation of water
If your refer has a watering device on the outside of the door then it could be that the resevour is cracked and leaking into the refer. It is usually behind the meat drawer ot somewhere in the lower part of the refer. If you do not have a water dispenser but an ice maker then it is posible that the ice maker is leaking. but that is not that common. There is one more possibility that it is just condensation from the lettuce crisper or the drawers below where fresh vegies would be. If that is turned up too high or low then condnsation can accur and then leak to the bottom of the refer. Check these things out. and you can check you owners manual if you have one. you can download a manual for free online also for your brand and model #. they will have a trouble shooting section for this comon problem. Good Luck
Apr 10, 2012 | Whirlpool Refrigerators
FRIDGE WITH FRENCH DOORS AND FREEZER ON THE BOTTOM. WATER IS LEAKING FROM SOMEWHERE AND SETTLING UNDERNEATH MY DELI DRAWER TRAY. SOME OF THE WATER IS FROZEN. I HAD TO TOWEL THE WATER UP AND PRY OUT THE...
Your model must also have an evaporator on the top section because if the fresh food section deli has water below the trays you either have a door seal leak allowing moisture in or the fresh food section evaporator drain is also blocked. I really think your defrost drain is blocked and now everytime your refrigerator goes into defrost the condensate remains inside your refrigerator. Click Here=> Leaking Refrigerators Just What may Be Happening and read that page and then click here=> Leaking Refrigerators Read over all of the different ways leaks happenn and if this solution is helpful please rate the solution because I need all the rate's I can get. If you have questions I will be here so please ask, Thanks, Sea Breeze
Jun 29, 2011 | Refrigerators
A 2 to 21/2 year old Samsung bottom mount freezer RB217ABPN purchased from Costco. Water is starting to collect under the crisper drawers in the fridge section. This is the third time in a couple of months...
You have a leaking water tank behind the crisper drawer. You will need to get back there to determine if the tank is leaking or the water connection is leaking. This will only leak if you close the door and dispense water from the dispenser.
Jun 22, 2011 | Refrigerators
Leaking water
the water reservoir tank could be your problem, take out the drawers and operate the dispenser and see if water is leaking from it. if so replacement of the tank is very easy
May 21, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Water if leaking inside the refrigerator -- in the drawers and under the drawers and on the shelves! Please help!!
Probably a plugged drain in the freezer compartment. Open it up and investigate. You may need a hair dryer to thaw it out. Hope this helps!
Jan 05, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Water Leaks from front door
My tenants informed me that water was showing up on the floor in front of the refrigerator. I checked the back where the evaporator tray is and it was dry. When i looked inside the refrigerator I notices water pooled inside, under the plastic bottom drawer. Anybody have any idea what i should do? thanks.
May 29, 2008 | Refrigerators
Water leaking from refrigerator...
You may have a small hole in the internal water pipe. Possibly from rubbing against the motor.
Take the end of the pipe comming from the back of the fridge (water inlet) and blow as hard as you can into it. If air passes through then you have a leak for sure.
Get a second set of hands to run along the pipe while you blow and you should be able to feel where the air is comming from.
Had this problem years ago with an Americana double door with ice dispenser.
Apr 13, 2008 | Kenmore 53092 / 53094 Side by Side...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
178 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
