Question about HP PL4260N 42 in. Plasma HDTV
Tv turns on but no picture. Then Tv shuts off by itself.
  • Jim Krause May 11, 2010
    I need a Make and Model # please?
  • 335 Answers
Try turning it on again and quickly press the source button several times until the source menu on the screen appears. Keep trying this method, and if the tv does not do anything then it needs to be serviced. If the tv turns on and functions normally after this wacky method then your power supply is developing a problem....its probably a bad capacitor or TO style diode.
Posted on Feb 26, 2009
The TV started turning itself off occasionally a
Most likley what it could be is an interferance in the TV. Modern TV's have a feature that will shut itself off when it is not receving a picture. For instance, after so many minutes of "snow" it will shut off.sometimes this can make the TV think there is no signal at shut itself off.Anyway, I suspect its an interferance issue. Perhaps moving the TV further from the source of the interferance might help.
Sep 17, 2009 | Televison & Video
The volume and picture on my LG 42LB1DR TV shuts off by itself
check the menu for power saving option if it`s on shut it off.
Aug 28, 2009 | LG 42LC2D 42 in. LCD HDTV
TV shuts itself off..red light blinks 7 times.
the only way is by bringing to a tech.i think there is no need fro self-fixing with problems like this.try tapping the tv several times then turn it on.
May 28, 2009 | Televison & Video
Tv turns off when I first turn it on
hi this s grizmofreak
solution to above problem
this s because of the secondary emissions of picture tube, and once the supply stops the emmissions from the picture tube wont stop for few seconds and horzontal scannin problem.
please do rete me on the above solution.
Feb 02, 2009 | Televison & Video
Tv continues to turn on and off by itself..
When it shuts off by itself, does the blue circle screen under the "Samsung" label show a picture of a light bulb? If so, it's probably time to replace the lamp.
Jan 24, 2009 | Samsung HLP5085W 50" Rear Projection...
Tv shuts off immediately after turning on
Does it shut off shut off, or is there audio present after the lamps shut off? When you shine a light to the screen do you still see picture kind of?
If still see picture, it's inverter/power supply or CCFL bulbs itself. If no picture, completely off, it's DEFINITELY the inverter/power supply.
Sep 30, 2008 | Televison & Video
TV turns itself off after a few seconds, no picture at all
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Mar 28, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Picture got bigger
Yes, you can adjust the picture by using your remote going to settings, or "Adjust" when your t.v. turns on and off by itself could have'ft to do with nasty weather near you, or the cord is loose and it needs to be pushed in all the way.
Nov 29, 2007 | RCA 32V550T 32" TV
Sounds like the typical Flyback and shorted horizontal output transistor. Problem is the transformer is NO Longer Available
Sep 13, 2006 | GE 32GT740 32" TV
HP PL4260N 42 in. Plasma HDTV Logo
210 people viewed this question
Top HP Televison & Video Experts
Tony
Computer Links
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
