Question about Panasonic Audio Players & Recorders
Panasonic av control receiver sa-he200
I'm trying to hook up my surround speakers to my panasonic av control receiver sa-he200. I can't seem to get the receiver to power tha speakers on channel A aswell as the speakers on channel B? How can I do A+B?
  • 1 more comment
  • Anonymous Mar 26, 2014
    speakers only 2 working
    only 2 speakers are working
    Front speakers working but not others
  • 121 Answers
On any 5.1 system without 2 zone capabilities when you press speaker "B" the receiver uses the rear channel amplifiers to send signal to the remote speakers. As a result the receiver cannot output signal to both the rears and the remotes at the same time.
Posted on Feb 27, 2009
Can you have just 2 channel by hooking up to right & left front speaker posts on 5.1 surround
short answer.....no. If you hook more than one speaker up to a single channel, it will lower the impedence and will damage the amp. You can hook up multiple speakers by using a speaker switch box between the speakers and the amp. This will match the impedence and should keep the amp from blowing.
Dec 21, 2014 | Panasonic Technics SA-G76 AV Control...
Can i hook up my technics sa-g76 to my tv
yes, using the the rca outs of your tv, and they will connect to an input on your reciever that may already be marked for a tv, or cable box
Jul 28, 2013 | Panasonic Technics SA-G76 AV Control...
How do I adjust 2 front speakers volume?
All speaker levels are set relative to the front, so they are not adjustable by themselves other than the overall volume control. Page 12 of the manual.
Dec 26, 2010 | Panasonic SA-HE200 Receiver
My Technics AV Control Receiver SA AX530 is in overload
An amplifier should never be turn on without speakers, it will overload internally.
make sure speakers work and try again.
Dec 04, 2009 | Technics SA-AX530 Receiver
Getting overload display i have 4 ohm speakers hooked up to it
Receiver is designed for 8ohm speakers. you can't use car audio speakers. they are 4ohm. Most receivers will tolerate 6ohms but not 4. This will short the mains and destroy your power amp!
Nov 17, 2009 | Panasonic SA-HE200 Receiver
Humming through speakes when on auxillary
Most humming in North America is either 60Hz or a harmonic of 60Hz. The number one cause of humming is a poor common. On co-axial cables this is the outside connection where as the signal is the male post in the centre. Corrosion, oxidation, poor contact are all possible things to check.
Jun 10, 2009 | Panasonic SA-HE200 Receiver
Video Issue with SA-HE200
You might want to re-wire your system so that the SA-HE200 only handles audio for the various components. Run video lines directly to the TV/Monitor. Always use the best (most advanced) matching cable type between the two.
I always setup my systems like this anyway. You end up using less and shorter cable runs and often get to use a video cable type the audio receiver doesn't support.
Mar 22, 2008 | Panasonic SA-HE200 Receiver
Panasonic
Because you have connected speakers that are not the same ohm you had damaged the output transistor or IC of your set, you have to get it replace and get the right the speaker
Jan 12, 2007 | Panasonic SA-HE200 Receiver
299 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
